Question about Air Tools & Compressors
What is h.p. of aspera 115 volt compressor mo#T6215Z
Need to know the H.P. of aspera 115 volt compressor,mo.#T6215Z,so I can replace the plug in relay and the overload with proper one
  • 1462 Answers
SOURCE: Refrigerator not cooling.
compressor has failed. not a diy job
Posted on Apr 25, 2007
22yooper
  • 828 Answers
SOURCE: compressor short cycling
If the compressor is run off of a relay then you could install a delay timer to prevent short cycling.
http://www.climatedoctors.com/items/item.aspx?itemid=429504
Posted on Jun 04, 2008
peyton32034
  • 410 Answers
SOURCE: replacing overload relay/capacitor on compressor of maytag fridge
replacing a start relay is very easy to do. usually its a swap the part wire for wire operation. in some cases you get a different looking relay but they normally have good instructions for the replacement part. if you'll post the model numebr fo your unit i can give you detailed instructions. thanks peyton
Posted on Mar 16, 2009
SOURCE: small refrigerator compressor overload relay cuts out
I am told if you measure two terminals and note the two with the highest resistance. Then measure each of the two terminals with the highest resistance to the common terminal they the two additional readings should read the same as the two terminals with the highest resistance when adding them together. If after adding the two there is more than 1/2 ohm difference one of the windings is shorted.
Posted on May 06, 2009
  • 1253 Answers
SOURCE: compressor runs constantly, fridge cools, but not as cold as new
If unit is running constantly, and not nearly as cold as it used to be, most likely a freon leak. Possibly a partially frozen over evap too. If evap is mostly clear except for about 5% of it, most probably a freon leak. Changing controls will probably not fix anything. Need to look into this a little deeper.
Good Luck and hope this gets it done for you.
Posted on May 10, 2009
Wire 230 volt air compressor wiring diagrams
On 230 volts you have 3 wires 2 are 115 volt and the third wire is ground. As long as you hook the ground wires together correctly the other wires don't matter. Usually the ground wire is either white or green. The black wires are hot (115 volts).
Feb 11, 2014 | Air Tools & Compressors
I want to convert my compressor from 115 V to 220volt? There is nothing in the owners manual on how to do this. Can you help me?
Your garage mate unit was made to operate on 120 volts. That one reason there is nothing in the owners manual. To convert it my be costly.First your electric motor must be able to handle 220 volts. you will need to look on the motor tag and see if it has 120v/230v. if not you will have to purchase a new motor that will handle 220/230 volts.If your motor will handle 220/230/volts you need to look at the the wiring diagram attached to the motor. you then will need to purchase a 220 v plug and outlet and correct wire size to install.
Jun 21, 2011 | Ingersoll Rand - Rand 2 - hp 24 - gallon...
I have an True t72f bought in late 2005 it as a nema 14-20p plug on the data plate it shows 115/208/230 volts?? how do i know what to hook this unit up to ??
If the plug has 4 poles on it, that means it should be connected to two lines of power, one neutral, and one earth ground. The unit probably has a 208-230 volt compressor, with 115 volt control and heater system. Let me know if you need more info
Jan 26, 2011 | True 72 cu. ft. / 2039 liter Commercial...
Need to know how to put the wires in the right order on a AO Smith 5.0 56 spa pump red white and black
Red and Black should each be connected to the individual power legs, for 230 V operation. The white wire should be connected to ground.
Nov 25, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Dewalt D55155-QS 220 volts can it convert to use 115 volts?
The short answer unfortunately is no. The internal motor that drives this compressor requires 220 and will not work properly with 110. Your only option would be to replace the motor with one compatible with 110. The cost of that would approximate a major portion of a replacement unit.
Sorry about the bad news.
Dan
Jul 08, 2010 | Black & Decker Dewalt #D55155 2HP 4GAL...
Well it is not an AO Smith, but I have an older Eneregair compressor with an Energair America motor 2 HP, 230v 12 amp. It says on the compressor that it is a 115/230, so I am wondering if it is possible...
Thank you for posting your question here on Fixya.com.
A 2 HP motor is usually only going to connect to 230V 1~ because of the high amp draw if ran on 115V. The motor itself should say 115/230 V and then would also read 24/12 Amp. It seems based upon your post it is not a dual voltage motor, likely for the reason I stated. You can not reconnect the motor from series to parallel because the winding connections to the leads are not brought out for you to do so. Otherwise it would be labeled for 115/230. You can of course try to get a 2 HP 115 volt rated motor or try to reconnect a circuit where you wish to use the compressor to bring the 230 V to it. In the long run, you would be better off running the motor on 230V.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 05, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
I have a 2hp compressor motor that keeps tripping the breaker after about 5 minutes of use. i have changed the caps but it keeps popping the starter cap. is the motor just bad?
Our 2 HP Speedaire horizontal tank compressor is rated 115 / 230 volts at 24 / 12 amps, respectively. This means at 115 volts, a 30 amp circuit breaker is the bare minimum. That also means that the wiring should be #10 copper wires for short runs, but the next size up; #8 copper wires would be better connected to a 40 amp circuit breaker. Running at 230 drops the amperage requirement by half, to 12. A #14 copper wire is minimum for short runs with a double pole 15 amp circuit breaker, but #12 copper wires connected to a double pole 20 amp circuit breaker would be better choice.
If the compressor is cord connected (or even directly wired) with the minimum sized wires, it will likely a voltage drop problem unless very close to the panel. This problem is more pronounced as the distance between the circuit breaker and motor increases, or when smaller wires are in the circuit. All the voltage at the circuit breaker does not reach the motor, as it is lost as heat; so the compressor only sees 90 to 105 volts instead of the 115 volts it expects.
If the cords, connections, etc are getting hot, it is a tell tale sign of under-sized wires and /or poor connections. Once you solve these problems, the compressor should run "as advertised " because motors usually don't "go bad" but fail all at once. Unless you have a bearing problem - or there is a problem with the load itself (compressor).
I hope this helped.
Nov 12, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Randell 9601/Aspera compressor replacment?
I searched till I found a Randell vendor in our state. They had the answers I needed.
Nov 11, 2009 | Randell 9601-7 Refrigerator Commercial
Air Tools & Compressors Logo
138 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
