Question about Boating
Owners manual for Die hard Minnkota trolling motor
frcs68
  • 1605 Answers
SOURCE: Converting From 12/24 to Starght 24 Volt
if it is 24v. then you need to connect 2 battery in parallel. since the battery is only 12v.
if one battery is shoing red and the other is sohwing green, that means you are using 12v only, not the 24v.
connetion as follow:
positve of battery 1 to the motor, the negative of battery 1 to postive of battery 2. the negative of battery 2 to the motor.
Posted on Oct 20, 2008
  • 8 Answers
SOURCE: motor won't run
Look at the red indicator arrow when you hit the foot pedal. If it lights up, the motor should run. If not, inspect the splices under the top cover on the shaft. They will stop the motor if corroded or burnt.
Posted on Nov 28, 2008
Editor925
  • 285 Answers
SOURCE: Mounting a sonor/transducer on a MinnKota Riptide ST
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
Posted on Mar 17, 2009
  • 4 Answers
SOURCE: minnkota trolling motor prop removal
remove the nut and the prop will come right off. Just be careful not to loose the shear pin.
Posted on Apr 30, 2009
  • 53 Answers
SOURCE: I need an owners or repair manual for my Motoguide
Here is a link to motorguide manual. click here
Posted on Nov 05, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Minnkota endura c-50 shear pin size
    You can get the appropriate pins in the prop not kits sold by minn Kota or thru major retailers.
    Trolling Motor Replacement Props Minn Kota Motors
    You will find prop nut kits here just follow the link.
    Sep 28, 2014 | Minn Kota MinnKota MK110P Marine Portable...
    Looking for parts brakesdown minnkota 101
    Google the Make and model...dozens of web sites, including MinnKota,
    Dec 16, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Lcx26hd screen gets black when minnkota trolling motor is on has got good picture when off
    Sounds like a simple voltage problem due to the current draw from the trolling motor. You will need to have a seperate isolated battery to run the trolling motor.
    Sep 15, 2009 | Boating
    Online manual needed
    I have minnkota riptide i had to take the handle off and a little spring & white plastic piece poped out of the handle i just wanted to see where it goes
    Jul 11, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
    Minnkota trolling motor prop removal
    Apr 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Boating Logo
    51 people viewed this question
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
