Canon pc6re, how to clean corona wire - Office Equipment & Supplies
checkitright
  • 1362 Answers
SOURCE: Cleaning corona wire on Toshiba e-studio 810
Clean with an eraser by rubbing back and forth ( careful it can snap)
use a tissue w/ water
Posted on Jul 16, 2008
  • 158 Answers
SOURCE: What is the code to manually clean the corona wire Konica 7165
47 mode output 046 p00p for charge 47 mode output 047 p00p for transfer
Posted on Oct 03, 2009
komguy
  • 2306 Answers
SOURCE: Get a clean the corona wire. Have removed the
Try using canned air to blow out that corona area, and then a Q-tip moist with alcohol to gently wipe the corona wire, if all that fails you will need a new drum.
Also press the go button 3 times so you get a printout and check that you are getting a clean the drum error or something else.
Posted on Dec 18, 2009
Jimsta01
  • 405 Answers
SOURCE: HOW TO CLEAN THE CORONA WIRES
You need to open the front cover of the machine and remove the cartridge( drum and toner) On the tope right there is a tab that you need to slide from left to right about 20 times, then bring back to home position
Posted on Apr 05, 2010
  • 59 Answers
SOURCE: HOW CAN I CLEAN MY CANON NP6050 CORONA WIRE?
Hi canon 6050 have a biltin crona wire cleaning sysyem witch work when u turn on main power its work automaticly if u want to clean by your self or may be you want replace crona wires just there ar to crona assambly in the machine charge crona and transfer crona charge crona is upper side of drum witch u can acess removing three secrew of toner hoper unit, the transfer crona assambly you can clean just slide out the unit u ca acess without removing any secrew.
thanks
Posted on May 14, 2010
My canon ir5000 has a deletion in some papers White area accross the paper
This is usually a corona wire problem. There are three corona wire units in the copier. You probably need new corona wires strung, or units. You may get lucky though and just have a hung transfer/separation corona wire cleaner. This is visible if you slide out the transport unit by opening the front door and releasing the green handle, then sliding the drawer assembly out. Look for the unit with the 3 thin, hair thickness wires running front to rear in the silver cavity located just to the right of the black rubber wide transport belts. The unit will have a white plastic "bridge" on it. Look to see if there is an assembly that has cleaner pads on it stuck somewhere along the wires. If it is, be careful and slide the assembly all the way to the front of the corona unit. If there is a problem though, the next time it cleans the wires it will get stuck again. You will probably have to contact an authorized Canon dealer for repairs and parts. This model is very old now, and discontinued/obsolete. Getting parts may be an issue.
Jan 26, 2017 | Canon imageRUNNER 5000 Copier
CAN any one help me for solve this problem. My canon copier Clc 700 show error message : E061 thank tour for your help.
this is hardware technical problem if you can do that then follow the following thing or show it to service center.
changed the temperature and humity sensor, cleaned the door switch, and changed the primary corona .first check the primary corona assy. are the corona wires in the proper place on the the little end blocks in the proper groove. they should be in the groove thats closets to the grid wire the wire on top of the unit. Both ends of the corona wire, should be in that top groove, not one on top and the other on the bottom. )61 is a laser code, or should say potential voltage on the drum. Since it is not equal both sides, one side being darker, sounds like the corona wire is out of place.
Have a nice day and do not forget to rate please...!
Dec 24, 2010 | Canon CLC-700 Copier
Canon NP 3825 printing problem.The print appears like erase with rubber or fade looking.If problem with corona wires,how can I adjust corona wires?
If the copies are faded you may first need to remove the glass board for copying with the power switched off and power plug disconnected. Then clean the long mirrors that run on a cable assembly and are fitted from the front of the machine to the back sliding to the left to scan. In the machines resting state the assembly housing the mirrors, will be all the way to the left with a white lamp beside them. There will also be a miror to the right behind the lens. Try cleaning the lens as well.
After that, then clean the corona wires by pulling out the front draw where you will see two of the wires.
Aug 20, 2010 | Canon NP 6050 Copier
Canon ir5000 copies have horizonal bands of light copy quality. How do I get even, good quality down the entire page?
The machine probably needs a service paying attention to the development and the cleaning areas. Also, clean or replace the corona wires and check that there is no flat spots on the fuser roller.
Jun 18, 2010 | Canon Office Equipment & Supplies
I have a canon pc6re copier. I used a compatable \...
I'm guessing you used a compatable toner/drum cartridge. It sounds like you have a bad cartridge. If its a refilled drum cartridge its bad, either the drum blade is bad or charging is bad. Take it, or send it back and get another one. I recommend genuine "Canon" products. All toners and units are not made to the same standard as the Canon products.
May 18, 2010 | Office Equipment & Supplies
May 14, 2010 | Canon NP 6050 Copier
Some lines missing inthe middle of the printout
Check and see if the corona wire cleaner is stuck in the middle of the corona , either transfer or primary corona. Most often it is the corona up top. If it is the cleaner u can move it by loosing gears and turning shaft until it moves to one end of the wire.
Apr 16, 2010 | Canon Office Equipment & Supplies
Dark copies, copier pc-6re needs cleaning, no manual
Clean the optical parts (mirrors,lens and lamps),charge corona wire and the transfer /separator corona wires and unir and make a copy.If not good tell me.
Nov 30, 2009 | Canon Office Equipment & Supplies
We have a Canon IR-7105 which keeps jamming , then codes out with code Error E000069-00000 (the tech was just in and did a PM)
it is a transfer corona problem ,clean it first.even its not ok change the corona wires.
if its not ok finally change the transfer corona .
Jan 21, 2009 | Canon imageRUNNER 7200 Copier
Copier canon NP 7130, the images donĀ“t show
what actaully you need? if you need a manual is another issue but if you need your machine to work do this.
1.check the corona wires in corona units if broken replace if not
2.clean the corona units so that they will be free from discharging.
please vote me
Nov 14, 2008 | Canon NP 7130 Black and White Copier
87 people viewed this question
jasbo
jasbo
