Question about Philips 60P8341 60" Rear Projection Television
Philips 60p8342 chassy ptv 916
Replaced projection fluid. turned on screen flashed red and then a red horizonal line at top of screen and no sound..went back in today and power light comes on no picture or sound. fuses tested ok.
  • 905 Answers
Check all your solder connection and test the resistors on the conversion IC's , also check oscilating circuts
Posted on Oct 27, 2008
  • jason Oct 28, 2008
    need more help?
Why is my screen red when it should be black?
Search Results
    Philips Magnavox 8p6031c Crt Lens Fluid Repair Questions ...
    www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/page-11
    Recent Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & answers. Free expert ... Philips flat screen tv, Red flashing light. Light.
    Popular Philips Magnavox 8p6031c Crt Lens Fluid Repair ...
    www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/popular
    Popular Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & fixes. ... My son accidentally spilled water on our Philips tv and when i turned it on ... I need a screen replacement of philips tv 60" ... Why the tv come on but a min after the red blinking come on an it turn off by it self what the problem?
    Magnavox Projection TV problem... ' Techlore
    www.techlore.com/forum/thread/.../magnavox-projection-tv-problem
Jan 13, 2016 | Philips Magnavox 8p6031c Crt Lens Fluid...
Philips 60p8342 projection tv 1)Color distorted, whitish and dull 2)Picture bowed at top and bottom 3)Set turns off by itself 4)I can't turn on set unless its been off and unplugged for many hours and then...
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 16, 2010 | Philips 60P8342 60" Rear Projection...
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
  • Dull looking video
  • White looking video
  • Red/Orange looking video
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
No picture/ power button flashes twice constantly. 2 flash code?
Sorry, but there is no simple answer to your problem.
Bottom line, it needs to be repaired by a qualified technician.
The blinking is a code for what circuit area of the set called for the shutdown.
No matter what it is, there is nothing more you can do.
www.mcveyelectronics.com
May 03, 2009 | Philips 50P8341 50" Rear Projection...
I HAVE A PHILLIPS MODEL 50P8341 REAR PROJECTION TV THAT COMES ON ,THE RED POWER LIGHT BLINKS FOR A SECOND AND THEN CUTS ITSELF OFF
Try the power supply. Look on the one in your TV for the part number ; mine is PH3501705441. I ordered one from partstore.com and it was less than $60 shipped. Hope this helps, mine works fine now........and I have a 50P8342 chassis PTV 916
Dec 10, 2008 | Philips 50P8341 50" Rear Projection...
Philips 60P8342 picture blurry with orange tint
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Oct 30, 2008 | Philips 60P8342 60" Rear Projection...
Autolock on my philips magnavox 60p8342
I am sending the user manual to your email address it will explain the auto lock procedure.
Jun 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 55P8342 Bow in picture
Replacement IC's suspect...did you use generic ? For all my repairs where originals are STK392-110,120 or 150....I use the
up-grade STK394-160E Mfr by SANYO with Hitachi part number
CZ 01341...they are expensive,but NO RE-CALLS ! Also,did
you check the resistors close to the IC's for over-heat damage ?
...........................................T.
Feb 21, 2008 | Philips 60P8342 60" Rear Projection...
Blue screen with sound but nothing else!
I, too, acquired a Phillips without a manual and was experiencing a similar problem. My model is PTV 916, but if your TV has a "source select" button, say a prayer and press the button. From that point, I don't know what else I did, but I do get TV programs now.
Jan 04, 2008 | Philips 50P8341 50" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
133 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
