Question about Grilling
Why is my traeger smoker is blowing fuses - Grilling
5 Suggested Answers
  • 332 Answers
SOURCE: Hi, i have a traeger smoker and am trying to find
Simplest it to go to treager.com and match the pictures
Posted on Mar 10, 2010
gcken
  • 140 Answers
SOURCE: Our traeger smoker is smoking but is not emitting
You need to replace the element inside the smoker!
Posted on Apr 04, 2010
  • 13 Answers
SOURCE: Traeger smoker - the flame ignites but the fan stopped working
Use White Lithium Grease from a spray can. Blow into the shaft side of bearing.
Posted on Jul 25, 2010
SOURCE: Err message on my Traeger
I had the same problem; I talked to Traeger talked to their rep and he walked me through fixing the problem. There are two wires leading from the temperature probe, these lead back to the thermostat digital controller. With the unit unplugged, unscrew the two screws holding the temperature controller in place. Slowly and carefully pull out, and check that both wires are running into the controller. If either is disconnected, strip a little more wire off the loosened wire, put back in hole and tighten the wire back down. That was the trick for my grill. Reassemble and reconnect power and test it out.
Posted on Oct 17, 2011
Why is there no power to my Traeger grill
There is a fuse that you can check. There is a possibility that it is the ignitor, the auger motor, the controller, or the fan.
The process to tell which item is bad, is to disconnect all but the power and the RTD wire, plug it in and turn it to smoke, If the fuse blows it is the controller, if not turn it off and start hooking up the other wires one at a time, When you find the one that fries the fuse, you know what is bad.
Aug 08, 2016 | Traeger Industries BBQ125 All-in-One Grill...
Burner not working
Traeger Industries burner not working Grills & Smokers ...
www.fixya.com > Forum > Tags > burner not working > Grills & Smokers
Traeger Industries grills & smokers burner not working related questions and answers. Ask your ... Question about BBQ075 All-in-One Grill / Smoker. 1 Answer ...
Traeger Industries water pump not working Grills & Smokers ...
www.fixya.com > ... > Tags > water pump not working > Grills & Smokers
Traeger Industries grills & smokers water pump not working related ... Question about BBQ075 All-in-One Grill / Smoker ... our auger stopped working how can we fixthis. it is not the electrical .when you put pellets in the burner it will light and ...
Support - Traeger Wood Pellet Grills
www.traegergrills.com/support.html
Traeger Pellet Grills, LLC. ... Why won't my grill light? ... Why is my grill running so hot on smoke? .... Large Commercial Trailer. Download manual. View All ...
FAQS - Traeger Wood Pellet Grills
Jan 01, 2016 | Traeger Industries BBQ075 All-in-One Grill...
Where is the fuse located on a Traeger
The fuse is located on the back side of the control panel, in a light green plastic housing. It should have a spare fuse zip-tied to it, which will also let you know the location of the old fuse.
May 04, 2014 | Traeger Industries BBQ070 All-in-One Grill...
Treager grill blow fuse over and over
As you might imagine. If your Treager is blowing fuses, it has an electrical short somewhere. The tricky part is usually finding it. However, on the unit, it will likely be the hot rod. Replace it before the short causes other damage.
May 03, 2014 | Traeger Industries BBQ075 All-in-One Grill...
My Traeger (BBQ070) will feed the pellets, but there is no ignition to burn the pellets.
Be sure check the fuse behind the control board when pellets auger in but do not ignite.
Dec 09, 2011 | Traeger Industries BBQ070 All-in-One Grill...
I turned off my grill yesterday and it kept on smoking. There seems to have been a fire at the base of the pellet bin. How can I fix this fast? I have three events beginning on Saturday, where my...
Whenever you finish using your Traeger it is always best to lift the lid and turn the controller down to the smoke setting and allow the temp to drop for a few minutes. This will also slow down the delivery of fresh pellets into your firepot thus starving the fire of fuel.Once the temp drops below 200 deg F than shut off the controller. If you have any wind blowing remove your Traeger out of the draft of the wind and the fire will go out on its own.
Jun 30, 2011 | Traeger Industries BBQ125 All-in-One Grill...
I couldn't get the temperature to regulate. The digital readout showed it getting hotter and hotter, then the GFCI would blow. I finally got it to work but I don't know how I did it. The next day I tried...
I answer quite a few questions about Traeger Pellet Grill/Smokers, but this is a new one. My best advice is to contact Traeger's Technical Support Dept @ (800) 872-3437 and let them sort it out.
Apr 04, 2011 | Traeger Industries BBQ070 All-in-One Grill...
I have an electric Traeger grill. I plug it in
Make sure your grill is unplugged. Them take the controler out and there is a fuse on the back side of the control. There is also a new fuse there to replace the old one. If the fuse is blown, you could have a bad hot rod or other component that is bad. Usually the hot rod is the problem and they should be under warrenty so call Treager and get a new one sent. If the fuse blows after it is replace, you can un hook the purple wire and replace the fuse and see if it will work them. If it does, it is the hotrod.
Apr 10, 2010 | Traeger Industries BBQ100 All-in-One Grill...
Is the fuse a 2 amp or a 7 amp
They are a 3 amp fast blow fuse, and Radio Shack does carry them.
Mar 07, 2010 | Traeger Industries BBQ075 All-in-One Grill...
Grilling Logo
422 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
