Question about IBM ThinkVision L170 17" LCD Monitor
Hellop i have exact same problem with the ibm 17", my is also the power invertor power circuit is dead, and the one of the 4 small IC that is @ back of the monitor, do u know what are they? or do u have one that is also borken but at least one of the IC still good? b/c i could use one
  • 1 more comment
  • allenpan Oct 28, 2008
    it is the power circuit, and is located at back of the power ckt, the ic i belive are either 8 pins or 10 pins, and marking= 4800 (or might be 4600) a03f12. one of the pin it on the ic is torched and i belive that is only problem, i dont have much experiance with DC to AC ckt, so i dont know what to test, can u advice me where is a proper vm test point?
    i will upload some photo next week, too much asg and labs to do
    thx for ur time greatly, fully appreshiated
    Allen
    ahhh thx so mcuh, the "A04800 dual MOSFET " that is the one is torched, right now, none of the tube light up, i think is just due to this defected mosfet, do u knwo where can i pruchase those MOSFET...what is funny is we jsut covers MOSFET in class
  • Noel Rusnell
    Noel Rusnell May 11, 2010
    I do not have possession of the unit as the customer retrieved the parts (why...who knows?) without waiting for me to locate a replacement transformer. what are the markings on the four small IC's and on what section of which board are you working on--power supply or video processing? Are there visible indications of failure? what are the symptoms you are dealing with? do you have any voltages present on any of the circuits?
    Problem Solver:
The only numbers that come up for me are the 4800 as in an A04800 dual MOSFET array whose datasheet can be found here. http://www.aosmd.com/pdfs/datasheet/AO4800B.pdf
Remove the single retaining screw from each of the CCFL tube holders, remove the epoxy from the connectors and then disconnect the tube connectors and remove the 2 CCFL tube holders in plain sight (keeping the tubes themselves contained in the holders) from their places in LCD frame--so you can lay the holders in plain sight, then reconnect the tubes. Observe the tubes during power up...just be careful not to allow metal parts to make contact with other components or anywhere on the trace...if you observe one or more tubes dim or refusing to ingite, swap tube connections to isolate and determine whether the problem is faulty tube or power supply to the tube. If the issue is that no tubes light, check the pins of the BIT3105 Controller on the power supply circuit
whose datasheet can be found here: http://pdf1.alldatasheet.com/datasheet-pdf/view/78519/ETC/BIT3105.html
you should see similar values to these:
ϑ 7.43V on AVDD and PVDD
6.96V on CMP
1.25V on RTDLY
ϑ 7.4Von NOUT2, NOUT1, POUT1, and POUT2
1.52V on EA
213 Kω on PWMOUT
1.3V on CTPWM
.6V on DIMDC
3.9V on SST
0~.4mVon CLAMP
If you do not have INN voltage, check the the four 25v47µf caps connected to the BIT3105 CCFL controller (top-center of the board) and then the large electrolytic caps 10v1000µf cap (C551), 25v470µf cap (c661). visually check for domed tops or bulged sides. if these all check good, check the rectifier and regulator on the heatsink by the two large caps. then check the rest of teh electrolytic caps as before. continue working back in the circuit until you reach the Main A/C-D/C circuit.
Posted on Oct 28, 2008
Greetings! We are using IBM E74 model CRT Monitor, The monitor was dead, No power, no display How can i rectify that? please give me the instruction
Jun 11, 2011 | IBM E74 17" CRT Monitor
Blank TV screen after switch on
Hi.
The most common problem for this fault is the invertor failed.
The invertor is a HT circuit with 2,4,6,8, transformers on one or more of the tranformers will be open circuit.
Its relatively easy to replace but could be dificult & expensive to buy.
Chris..
Nov 24, 2007 | Relisys RLT1720 17" LCD Monitor
2 X IBM T41 laptops, both with extremely dim displays. I'm guessing the inverter has gone, any thoughts? Any availability ideas for replacements for either inverter, ot complete LCD assy, including...
When the invertors fail, it is common to be completely dead not showing a little light.
Maybe they have both failed but I would check the power save settings first.
Hope that helps.
Feb 25, 2011 | IBM ThinkPad T41 Notebook
When power on SMPS is totally dead chek the fuse; fuse is ok switching transistor also ok pls help
If power out of the SMPS is the issue then a short on the secondary side can also be the issue in which the optocoupler can shut off the feed to the SM driver.
So if your voltage is present at the SM driver and the oscillation of the invertor chopper is good, check on Sm transformer for fault or the secondary ccirrcuit may have short.
If oscillatiion is not present , check and change the Oscillator IC.There are feedback loops into the circuit and the diode/capacitor can also be faulty.
Aug 31, 2010 | Health & Beauty
BenQ FP71E 17 - how to open
There are 4 pieces 2 each around yellow invertor transformers.
Check visually for darkened back of the transistor.For reliable testing you need to desolder and test with an ohmmeter.Also check the FET Fu9024 or D10Pf for similiar problems.
What is your actual symptom?
Samir
Aug 20, 2008 | BenQ FP71E 17" LCD Monitor
Monitor goes on/off in 2 seconds
Problem is related to Invertor .If you are Technically able ,resolder power transistors 2sc5707 on powerboard near invertor transformers.
Please rate the solution and provide feedback.
Samir
Jun 01, 2008 | BenQ FP71E 17" LCD Monitor
Display
Problem is with invertor board.You need to open the monitor and check Invertor transistors 2sc5707.Test all 4 transistors and replace defective,also check /resolder associated circuitry.Also check fuse with PFxxx circuit reference no.
Samir
May 11, 2008 | BenQ FP767 17" LCD Monitor
BenQ FP72G 17" LCD Monitor NO DISPLAY
Check the ribbon from the video card to the back of the panel. It has to be aligned perfectly and locked down in the right position at the video card side, and pushed in corrctly to the panel.
The section that contains the inverter circuit is totally seperate from the rest of the power supply. Seperated by the fuse link marked FBxxx.
Apr 22, 2008 | BenQ FP72G+ 17" LCD Monitor
About the Regulator ic
your welcome, just info me if you done to test the regulator ic.
Feb 22, 2008 | Acer AL1716 17" LCD Monitor
Need new power/invertor board for Acer AL1711
R1 will be blown, replace it with a 10 ohm resistor. Also replace C6 and C22 with 220uf 25v Capacitors.
Dec 11, 2007 | Acer AL1711 17" LCD Monitor
IBM ThinkVision L170 17" LCD Monitor Logo
658 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
