Question about Sewing Machines
What's your problem?presser foot lever for elna model 683 presser foot lever cracked
The lever for the presser foot cracked and i need the part number
4 Suggested Answers
isaiahpro
  • 35 Answers
SOURCE: Elna serger 925 presser foot lift lever broke off.
Purchased an Elna Pro 925 DCX and it was missing the sewing cover to do sewing without using the blades. This is a plastic cover piece that snaps on to the machine when coverstiching. Where can I fing this part?
Posted on Aug 19, 2010
SOURCE: presser foot lever does not lift presser foot
It could be that yours is frozen like mine was. I followed the directions for resetting the screw, but it still wouldn't go. I had to sand off the rust and tap the end with a hammer! Now it goes up and down just fine! I have a Singer 9005, but like the techie said, they are all a lot a like in this part.
Posted on Dec 06, 2010
canwoodjc
  • 3301 Answers
SOURCE: When pressing the foot control
check the connections, if they are good, your foot pedal has a short in it, so its not completing the circuit when depressed
Posted on Jul 15, 2011
Hi, My Elna 7000 doesn't easily feed medium or thin fabrics. Presser Foot tension lever is position 2 and the Feed Dog is rising normally. Any thoughts please? Does the F Dog wear out in any way?
Generally, the lighter the fabric weight, the heavier the presser foot pressure. Yes, feed dogs do wear with use. Do not run the machine without fabric between the presser foot and the feed dogs--the feed dogs constantly rubbing against the presser foot will quickly wear the feed dog points. Store the machine with the presser foot down with a pad between the presser foot and feed dogs (even a scrap piece of fabric will do). Also, be sure to clean the feed dogs of any gunky build-up. If the feed dog points are worn, it may be worthwhile to have them replaced.
Jan 23, 2017 | Elna Sewing Machines
Where is the foot lever on the Elna Pro 4 DE,
Am unable to locate information on your machine. However, the presser foot lever is usually located behind and above the presser foot.
Instruction Manual Elna Lock PRO 4DC 4DE Overlocker
Nov 14, 2016 | Elna Sewing Machines
How do we fix reverse lever on Elna 3230 sewing machine?
This sounds like a job for a repair shop. More than likely the presser foot lever is broken internally. Newer model or not. I think a repair shop will be able to repair this easily.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Nov 29, 2014 | Elna Sewing Machines
Elna 905 presser foot
here's a link for parts, if this isn't the right model,, then let me
know
http://www.sewingpartsonline.com/elna-905dcx-sewing-machine-parts.aspx
Aug 13, 2012 | Sewing Machines
How do I change the presser foot on an elna mini sewing machine?
I dodn't know your model really well but it will be one of the following:
a clip on foot that you just pull down on to remove,
a clip on foot with a button at the back of the pressure foot holder - press the button to release the foot
a clip on foot with a little lever at the back of the pressure foot holder - lift the lever to release the foot
If it is a clip on foot, then you just need to raise the pressure foot lever, put your fingers onto the pressure foot and press downwards, it should unclip.
To put one on, place the pressure foot onto the needle plate under the pressure foot bar and lower the pressure foot bar down onto the foot, lining up the base of the foot holder with the little bar on the foot, it should click into place.
Oct 10, 2011 | Elna 2007 Mechanical Sewing Machine
Here are 2 dillers that will repair it for you.
Sew Pros Inc 393 Broadway
El Cajon, CA 92021 (619) 442-3100 4.61 mi Burdick's Chula Vista Sew 278 Third Ave
Chula Vista, CA 91910 (619) 422-5325 10.56 mi
Good luck and please rate
Sep 16, 2009 | Elna Sewing Machines
Elna walking foot
If your SU is an Air Electronic model i.e. 80's model, Elna didn't make a walking foot to fit. However, if you've got a walking foot that is the same height from sole plate to the screw fitting as a standard Elna foot then you could give it a try. The walking foot connects to the presser bar with a screw but the needle bar also needs to hook into a secondary lever on the side of the walking foot to make the foot actually move. Probably sounds very confusing . Check the movement of the foot manually by hand turning the fly wheel to see how it works before you actually use with the motor to minimise any problems if the foot doesn't fit.
Also you'll probably only be able to do straight stitch with this foot due to the clearance around the needle plate.
Oct 27, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
23 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
