Question about Dishwashers
How did I get the Bosch silence plus dBa dishwasher to dry?
I don't think we have the settings right, but we don't know how to set it to get it to dry the dishes.
4 Suggested Answers
SOURCE: Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Posted on Apr 19, 2008
SOURCE: bosch dishwasher she45m
These dishwashers are designed for "passive drying" -- in other words, they do not heat the dishwasher in order to dry the dishes but leave them wet.  It calls the process "condensation drying" -- which is a fancy German term for "not dry them at all".  I greatly regret buying this dishwasher, for this reason and others.
Posted on Mar 30, 2008
  • 5 Answers
SOURCE: Kenmore Quiet Guard
You dont really need it, when the washer gets done Open the door for a minute and let the steam out and shut the door dishes will then dry. the reason there still wet is because of the steam from the Hot water
Posted on Sep 18, 2009
Bosch silence plus 50dba not washing dishes! using Jet dry, recently cleaned the screen. any other troubleshooting ideas? ThNk you!
Check to make sure the spinner washing parts are loose and spinning. You can turn them by hand. Many times plates are too tall and block the washing arms from spinning. Push all the baskets in and look into machine and spin the arms. If that's not it then it's somehhing rlectronic that's not taking the machine thru the cycles.
Apr 08, 2015 | Bosch Dishwashers
Bosch silence plus 50 dba dishwasher not draining it says E24
Error codes are cryptic but usually indicate the obvious. Probably drain pipe blocked with junk build up. Clear blockage. Spring curtain rod up the pipe. Ouch....
Perhaps a little draino.
Mar 02, 2015 | Bosch Dishwashers
Why do i have a problem with my Bosch diswasher mod:she9er55uc/51 ...sanitize and refil rince are flashing when i start the machine
The rinse light is telling you the resiviore is empty and should be refilled the sanitize means that option is choosen try resetting options
Jun 25, 2014 | Bosch 800 Plus Series SHE9ER55UC 24...
Bosch silence plus 50 dba is showing error code h01
I believe this is a filling or water flow error. Make sure all the plumbing stuff is OK look at the valve under the sink that feeds the dishwasher. make sure it has not gotten turned off. Sometimes with hot water and cold also a chunk of crud will break off somewhere and get lodged blocking or restricting the flow. You may also have a filter somewhere on the DW to prevent junk from getting in. If there is a piece of crud a likely spot for it to be is at the valve connection under the sink where the DW hose connects to the hot water line. You can try unhooking the DW supply hose from the shut off(turn the shut off OFF first) and seeing if there is any junk in it. Shake the hose about 8" back from the end to try and send any junk in it flying across the kitchen. Also open the valve a bit with a bowl under it to blast any junk out. also see if it seems like a decent amount of water comes out to rule out any upstream plumbing issues.
Apr 05, 2014 | Bosch Evolution 300 DLX SHE43P26UC Full...
Bosch silence plus 50 dba has error code h01
The statement below can be found at: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html,
The SHU4326 and 4326 models use "Regular Wash" and "Rinse Hold" to begin the test while the other three series in this section use "Scrub Wash" and "Delicate/Econo," but all use the same set of fault codes, shown not as lights but as numbers on the Cycle Countdown display. Here, 1 is an aqua sensor fault, 2 is a heating fault, 4 is a filling fault, 8 is an NTC fault and 0 means that everything is working as it ought. During an actual wash, when you aren't testing, the Cycle Countdown display may show the letter "F," which also signifies a filling fault.
Read more: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html#ixzz33JutQVQR
Our Bosch Silence Plus 50 dBA shuts off and turns back on by itself.
You mean that you have to open it and slam it shut for it to finish?
Apr 25, 2013 | Bosch SHE3AR55UC Ascenta Series 50 dBA 42...
How to cancel cycle on dishwasher
On my dishwasher you have to press and hold the Stop or Cancel button for 5 to 10 seconds.
Sep 28, 2012 | Bosch Dishwashers
Related Topics: turn beep off beep turn
Hello Craig,
You can use Affersh dishwasher cleaner (link here) http://www.affresh.com/our_products/affresh_dishwasher_disposal_cleaner and to achive "Super hot" wash you can reset your hot water heater to a super high setting and the run a few cycles of the dishwasher....once done be sure to reset the hot water heater to the usual setting...also a very effective cleaner in the dishwasher is white vinegar ,try that along with setting the water heater higher
Good luck,
thanks for using Fixya.com
GENE
Nov 25, 2011 | Bosch SHX4AP05UC Dishwasher
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
3,589 people viewed this question
Top Dishwashers Experts
Owen Barnes
