I have a samsung LN37A550P3F LCD tv it is hooked up a sumsung home theater and warner cable . The problem is the tv will shut off on its own . We still have sound through the theater and when its turned back on it will play from 10 minutes to a hour before going off again .
Coldcut
  • 1554 Answers
SOURCE: LG 47" LCD TV - 47LC7DF Clicking Noise
the old saying is that any issues will likely show up in the 1st 3 days if you run it for 72 hrs. if it dosent fail then it will last.
other than going to the show room and seeing if their unit does the same.
they will likely want to send a service guy to check it out and decide for himself.
Posted on Feb 25, 2008
I was told that these clicking noises (which happen on my Magnavox LCD too) were due to the "power required" at the internal switch. Seems that the power required to immediately turn on the TV is too much for a standalone household outlet, so it "surges" power in a series to get enough there. Hence, the clicking sounds are actually mini power surges to send more power to the internal circuits to turn the TV on.
If your set is like mine, these noises generally stop after a minute or two, correct?
Posted on Mar 29, 2008
  • 3 Answers
SOURCE: My Samsung 50" HLS5086W wide screen tv keeps shutting off....
I have a Samsung DLP 61". The TV continued to turn off with no indications from the panel. I did some tests and determined the TV was not getting enough air circulation due to its poor fan inside. I installed a 110v computer fan on the outside of the vents on the rear of the TV to **** the heat out. Worked great and I have never had a problem since. Need further help or pictures let me know
John
Posted on Apr 27, 2008
SOURCE: Sony KDF-46E2000 LCD Projection TV
4 flashes is a bad fan, 3 flashes is lamp door switch
Posted on Jun 29, 2008
  • 98 Answers
SOURCE: Samsung LN37A550P3F shadow image
It seems new TV.
But that kind of problem is related LCD panel.
If you can replace LCD inverter first.
then not working need to replce LCD panel.
Posted on Feb 09, 2009
My my Samsung HT-TZ522 home theater system will just shut off for no reason.
Sounds like a power issue, do you have it all hooked up to a surge protector?
Apr 24, 2012 | Audio Players & Recorders
I don't know how to hook up my LG lht854 to my time warner cable box so that it plays the tv audio. please help
Treat the Cable Box like any other audio device.
IF the cable Box has optical digital output, run it to the LG. Run the analog audio output of the Cable Box to the TV so you can watch lo-fi shows without the LG turned on.
The best Cable Box Video should go directly to the TV.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/LG-LHT854-Home-Theater-Systems-manual/id/19697ci566/t/2/
Mar 19, 2011 | LG LHT854 Theater System
System shuts it's self off at start-up repeatedly, then will stay on indefinately. hooked up to samsung lcd 52" and samsung blu-ray w/hmdi cables and optic link
LCD
BLU-RAY
HDMI
OPTIC LINK
Could it be that the system is adjusting itself to your custom choices and then functioning normally?
Apr 26, 2009 | Samsung HT-Z310T Theater System
Ihavea 37'' dynex lcd and want to hook up a samsung home theater
cable box needs to be dolby digital to allow surround sound to work
Dec 26, 2008 | Samsung HTZ-510 Theater System
Connecting samsung home theater to samsung lcd tv and direct tv
Need to get more granular on this, Does the volume work HT remote, for like radio, cd, ipod audio? For you to use the tv audio through the HTB the tv's audio settings should be on the "fixed" output option. This gives a line level to the Amp independant of the tvs volume adhjustment. Otherwise you will need to adjust tvs volume 75% or so before the audio amp will reproduce a good volume. Turn down audio amp prior to making any adjustments. Let me know thx
Nov 23, 2008 | Samsung SCH-a650
I have no surround sound when watching normal T.V
Hi there, in order to listen to t.v you need to purchase an optical cable and plug this in the optical out of the tv to the optical in on the blue ray then select D.IN.1 on the blue ray and press mode on the remote until it says matrix . This will allow you to listen to the t.v through all speakers. hope this helps. Also remember to take the rubber protectors off the ends of the optical cable, a lot of people forget this :)
Nov 17, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
It seems new TV.
Jul 22, 2008 | Samsung HP-P3761 37 in. HD-Ready Plasma...
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Televison & Video Logo
Top Televison & Video Experts
