Question about Cobra Radio Communications
I hooked silver streak 250 linear to my cobra 29 lx not working
I hooked up a silver streak 250 linear to my cobra 29 lx and it dont seem to help at all
    Genius:
  • Cobra Master
  • 1,795 Answers
How is the radio getting out without the 250 hooked up?
Posted on Dec 22, 2014
2 Suggested Answers
  • 773 Answers
SOURCE: cobra 29 ltd classic antenna calibration ??
Wow. That's not at all a solution to what this guy is asking. And why all the caps??
The one point jm77437 has that is correct is that you do not set the radio, you set the antenna. The rest is blah blah.
Here is how you tune your antenna for you radio. First off it depends on what kind of antenna you have. most fiberglass antennas have a tunable tip to adjust the height of the antenna. Metal whips either have a collar at the base that the whip will either slide up or down in to adjust the height. The other type of metal whip's you have to physically clip to shorten the antenna, you must be careful with this type because once its clipped, that's it. You cannot add what you cut off.
I am going to give this example using a metal whip with an adjustable collar.
First after your radio is hooked up in the vehicle, drive to an open lot. Buildings and other structures can cause extra reflection. turn to channel 1. Flip the meter to CAL. Key the mic without talking. Now turn the CAL knob up until the needle reaches the little upside down triangle all the way to the right marked CAL. Now you have just celebrated your radio for your setup to measure you SWR. Now while still holding the key, flip the meter switch to SWR. The needle will move, and where it stops is your SWR reading. The lower the better. Anything under 1.5 is considered really good. But still, the lower the better.
Make note of what your SWR was on ch 1.
Now flip to channel 40. Repeat the SWR process. You must recalabrate each time you take a reading.
Now like jm77437 said. If your SWR reading is higher on 40 then 1, then your antenna is too long, and you must make it shorter. Loosen the collar and lower the antenna in the collar 1/4 inch at a time. check the swr each time you adjust the antenna.
If your SWR reading is higher on channel 1, then your antenna is too short. You must make your antenna longer. Do this by loossening the collar and pulling the antenna upward in the collar 1/4 inch at a time, again checking the swr each time you adjust the antenna.
What you want to achieve is having the same SWR reading on channel 1 and 40. then you have the best match you are going to get with that antenna.
If your swr is under 1.5 on all channels, you don't need to fuss unless you are a perfectionist. then by all means go ahead.
If your reading is higher then 3, or your ant light comes on, something is really wrong. Make sure your antenna is connected all the way, and the coax is not damaged.
Its important to have an appropriate SWR because if you do not, you are reflecting too much signal back into the radio, and eventually you will burn out your final transistor, and your radio will be toast.
Some tips: make sure you check the swr with the doors and windows shut. Make sure you are in an open lot. Remember to calabrate ecah time you take a reading. If you have had your radio peaked by a radio shop, and they have lowered your dead key, or have done a swing modification, then the meter in your radio will not work when taking an SWR reading and you will have to use an external meter.
Posted on Apr 24, 2009
Why the clock on the cobra 29 lx keep cutting out
jay I am not sure what you mean by the clock cutting out. I enclosed the manual in PDF form look at page 17 and see if this helps. If not ask the question with more detail.
https://www.cobra.com/sites/default/files/manuals/29%20LX.pdf
Oct 05, 2014 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
Cobra 29 lx
without a speaker hooked up to youe PA it wont work.Actually it should be a bullhorn type speaker that can both transmit and receive.this way you should be able to hear yourself talk.
Aug 22, 2014 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
How do i repair finals in cobra 29 lx
first of all are you sure its a bad antenna. I can key the mic with no antenna hooked up and nothing will happen the the finals but you may key it down with a brand new antenna and burn them also.Lokk and see how they are connected in the radio before you take it out and replace it the same way.You may want to replace your driver also.
Jun 13, 2014 | Cobra 29 Lx Full-featured Cb Radio
My cobra 29 lx is saying that my rf gain power failed why is that
you may have burnt the diode that a variable controls or you messed with it and burnt it out.
Jan 21, 2014 | Cobra 29 Lx Full-featured Cb Radio
Cobra 29 Lx turn power up
one of the few radios that won't allow you to turn up. the most you will get is 4.5 watts . if you want power buy yourself a 250 watt liner amp and leave the radio where it is . turn VR 4 up for max modulation and go for it.
Dec 01, 2013 | Cobra 29 Lx Full-featured Cb Radio
My muticolored faceplate won't light up on my cobra 29 lx le lcd
you can fix it but you have to take it one step at a time. go to www.cbtricks.com they have the manual you need.
Mar 26, 2013 | Cobra 29 Chrome LX/LE 40 Channel 4 Color...
Cobra 29 LTD LX LE vr pots
vr1 "s" 9 setting on the tx meter vr2 voltage setting vr3 squelch vr4 amc vr5 p4 display on tx signal meter.
Mar 22, 2013 | Cobra 29 LTD CB Radio
Cobra Lx with no Tx ,recieves fine and antenna and mic work fine
Hi dubster,
You are on the ball with the 'burn-out' quote.
join a yahoo group specific to Cobra LX series of radios and they'll give you all the info you need.
Cheers,
Peter
Mar 02, 2013 | Cobra 29 LX
My cobra 29 lx won't go off of channel 1
what else did you do to mess up this radio.
Feb 23, 2013 | Cobra 29 LTD CB Radio
Radio Communications Logo
388 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
