Question about Garden
Pull start on a polaris atv - Garden
SOURCE: how do you adjust chain on polaris atv
I have polaris 250 trailblazer,2001. If you'rs is like mine, you have to loosten those 2 vertical bolts behind the axel on the very back of the swing arm, I don't know if you have to or not but I removed the brake caliper & loostened The 2 bolts holding the protector plate. Then you turn the axel between the 2 vert. bolts. Remember, When you'r machine is in gear the chain is tighter than when not in gear so leave a little play. Good luck, & be safe!
Posted on Apr 12, 2009
  • 3 Answers
SOURCE: ATV will not start. no power to lights, starter.
make sure that your battery terminals are clean and are making good connection, sometimes when alot of mud builds up on my bikes battery it wont start also try to start it by the recoil is it has one or the kick start cuz when the battery is dead and you stuck in the trails you can start it by this and it should start
if this doesnt work let me no
Posted on Jul 23, 2009
  • 16 Answers
SOURCE: Brake fluid for a '91 Polaris Trailboss ATV
you dont need to check it just make sure that when u change the fluid that you fill it up to the top.
Posted on Jul 24, 2009
  • 45 Answers
SOURCE: Polaris Atv free online guide
Polaris manuals:
http://www.polarisindustries.com/en-us/Vehicles/Pages/Home.aspx
Posted on Aug 19, 2009
  • 38 Answers
SOURCE: When trying to start our 1998 Polaris Explorer ATV
your battery is going bad you always have it check by going to battery shop or garage and get them to run a lod test
Posted on Oct 02, 2009
89 Polaris Ranger500 6x6 side by sideis coughing,spitting and backfireing thew carb.whats the fix
I would start by pulling and cleaning the carb, air filter and spark plug. Usually the cause starts with dirty air filters that gets the carbs dirty which then cause the polaris to run rich and the plug will start to foul. The unburnt fuel ignites at the wrong time and back fires. A less likely problem would be out of timing.
Feb 13, 2017 | Polaris ATV
I have transmission fluid leaking out of hole in clutch cover where the pull start rope goes in. Is that normal on a Polaris sportsman 500 ho.
Gasket or a bolt is loose. Dont use til u fix. Get a manual by clymer etc for repair details...utube is helpful
Oct 21, 2015 | Polaris ATV
My 2001 500 ho sportsmen starts with choke on while running she pulls back choke and shuts off
It sounds like the main jet is plugged. While the enrichner is pulled, it pulls fuel to run. Remove and clean the carb and the air cleaner.
Feb 20, 2015 | Polaris ATV
2008 polaris sportsman 500 won't start, but relay clicks and will start when relay terminals are jumped
I have seen this on a few machines. Start tracing wires. Ground wire from the key is the first on Id check. Grounds on these machines go bad from vibration and rough terrain. Not to mention silt in the water.
Feb 16, 2013 | Polaris ATV
1995 polaris 425 magnum lights and ignition do not work
If you have cranked the atv without a battery connected it will blow your light bulbs. Replace the bulbs not burning, leave a battery connected even if its dead and pull start if you need to. A battery must be connected. I read and found out myself the hard way, hope it helps.
Jan 15, 2013 | Polaris ATV
2007 polaris hawkeye won't start
If I try and pull start it and it just makes noises tried to jump start it and dose nothing what could it be I bought a new battery but no way of checking if it's charged or not
Jun 26, 2012 | Polaris ATV
How do i pull start my 1998 Polaris 400
you pull the pull rope until it startes
Dec 07, 2011 | Polaris ATV
Where is compression release for polaris sportsman 4x4 atv
Polaris uses an automatic decompression that sits in the exhaust cam. There is not an external lever as there is on older Kawasaki's and dirtbikes. What seems to be the issue as to why you're looking for a compression release?
Sep 21, 2011 | Polaris ATV
Won't start after pulling safety tether Polaris Predator 90 2006
as long as the tether is back in correctly it should start. try checking the battery. if the battery is fine then look at the battry and make sure your tether wires arent shorted anywhere
Apr 02, 2009 | Polaris ATV
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
