Question about Nikon Laser 600 Rangefinder
Powers up, but doesn't post a range.
Powers up fine and displays 88.8 w/ the 'm' & 'y'. When attempt to shoot a range, will not post any numbers. Have 3 horizontal lines and displays the 'Y' for yards, but will not post a number. Mode toggles 'm' to 'y' fine.
  • RICHMURPHREE Jan 24, 2009
    Powers up, doesn't post a range. Tried new battery and tried to make better contact with the battery - no help. HELP!!
4 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: lines on some pictures
This is a failing processor. Check out repair costs from Nikon A new camera may be the better bet.
Posted on Aug 30, 2007
SOURCE: Horizontal white lines
Contact Nikon on thier website, they will send you a reply and a link for return service and fix it for free. This website is no help, they want you to subscribe to a service before they reveal any info.
Posted on Dec 18, 2007
keemo68
  • 1263 Answers
SOURCE: I have a Nikon D100
you can try and reboot the camera, if this doesn't work then consult the repair shops and see if your display can be replaced for a low cost. For warrenty ifo con tact Nikon at their customer service center at www.nikonusa.com and click the service and support tab. this should help you .... pleqase rate this...thanks
Posted on Sep 23, 2008
Hi there.. I have A Fuji sl240 camera.. Was at a studio photo workshop today & on attempt to set up with studio lighting camera would not play...is there a particular setting that I would use here on...
Oops I thought I already did answer that. The settings you are looking for are shoot in P, A, S, M or C mode. page 88 of the manual.
Read my other post too.
Oct 21, 2014 | Cameras
RCA P56950 Powers on then 10 mins later powers off, repeats cycle. Then channel display in TV changes by itself
may be some thing is stuct on the controt pannel power button or others check. try this it may work
Jun 04, 2012 | RCA P56950 56" Rear Projection Television
The microwave display shows "Door" and it won't
I could have been more specific with a model number, but if this general answer doesn't do the trick, feel free to contact me with your full model and specific symptoms here.
It's usually a bad door switch or door switch mount. My helpful text file on door switches is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If it's one of those overdesigned Whirlpools, it can be one of many components. See the example photo at the bottom of this reply.
Aug 03, 2011 | Whirlpool GT1195SH Microwave Oven
I can't thread my bobbin. I get a error on the number guide and it is 88. so what is wrong with it not working.
Do you have a manul for your machine?
you can download it from here http://www.singerco.com/uploads/download/467_7466_efs.pdf
I can't see anything relating to error message 88 in the manual.
So I would suggest you start by trouble shooting the bobbin case, go to page 76 in manual and folloing images, take out bobbin case, clean and replace it. Turn machine off first and once its back in turn it on and see if the 88 code has reset.
Then redo bobbin winding, and threading up. Start with the manual instructions on this page 18 and 20 and work through it step by step. Make sure bobbin is in the right way so thread is feeding off in the right direction. Also just a thought, you haven't got a stray bobbin in there that isn't a Singer one??
I hope that this helps you to eliminate your machine problem, obviously if this doesn't solve it you may need to take it for a service and see if the 88 display relates to something within the machine circuitry.
Aug 01, 2011 | Singer 7466 Mechanical Sewing Machine
My Gateway NV52 will not display anything on the screen. it stays black. The notebook powers up, but nothing is shown on the screen. How can i fix this?
First :
Try connect your laptop to other monitor ( crt or lcd ) if it looks normal on the monitor, it means your LCD laptop is broken.
Somestime often open-closed this LCD Laptop, may broken your Flexy data kabel of your LCD laptop.
Anyway Thx
Jun 23, 2011 | Gateway NV5215u Notebook
Attempted to adjust the color display on my brand new Cobra 29 LX and now the display shows only the number 88 and some rows of digital blocks-the CB display is completely locked up and nothing i've...
The display on this radio uses firmware. I fear there may be a glitch in it. Maybe it was flashed wrong. If you hit the dim button, and it doesn't go back to normal, something is not write with the firmware.
There is not much out there yet about tweaking this. You will probably have to send it to cobra. It should still be under warranty.
Jun 18, 2011 | Cobra Radio Communications
How do I set the clock on a Maytag gas range, I
If your range is the same model as you posted this question under, the time is set by pressing the "CLOCK" button. The word "TIME" will begin to flash on the display. Using the keypad, press the corresponding numbers of the current time.
NOTE: If the oven has been programmed, or is in use, you cannot change the time. Cancel all other functions before attempting to set the clock.
If the model number is not correct, please post back with your correct information so that I may be able to provide you with better assistance.
Nov 01, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Door won't unlock after attempting the self clean. Self clean failed
Usually an F3 code means the temp sensor has failed. The oven control thinks the oven is to hot to open. You may have a failed control, but I would try replacing the sensor first.
Post back with any questions. Have been very busy at work and have not been online answering questions much lately but will answer back when I can.
Thanks, Mike
May 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
Nikon Laser 600 Rangefinder Logo
81 people viewed this question
Top Nikon Optics Experts
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
