Question about Nespresso Romeo E350 Espresso Machine
Nespresso Romeo 350 leaks from small portal on bottom. Access seems
3 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: I need the instructions for
It is fairly complicated, but luckily I found the manual for the device that goes into detail on exactly how to descale it. You want to go to page 8 of the manual. I will provide the manual at the end of my answer here...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://www1.nespresso.com/precom/sav/pdf/HD_RO_en.pdf
Thanks
Tim
Posted on Oct 13, 2010
emissionwiz
  • 76630 Answers
SOURCE: My coffee nespresso is leaking from the bottom from a small hole directly under the water tank. is there suppose to be plug there or something???
The seal at the bottom of the water tank is rotted out from age, you must replace the machine
Posted on Nov 08, 2016
Nespresso Essenza 90 leaking at the bottom seam underneath the used capsule holder, HELP
Try gluing the seam with lock tight glue or similar plastic gluing compound. Let it dry overnight and try again.
Oct 16, 2014 | Nespresso Essenza C90 Espresso Machine
My romeo nespresso wont leave the descaling mode
"DESCALING" is not a "mode." When the display says "DESCALING," it means that it needs descaling. Follow the directions in your instruction manual.
Jul 20, 2014 | Nespresso Romeo E350 Espresso Machine
Water leaking from reservoir
I had the same problem. All of a sudden my kitchen top counter got filled with water. The water was leaking from the Nespresso C190 water resevoir at the bottom. Exactly where the reservoir meets the coffee machine base. I had by chance an "O" rubber ring left from a faucet which I inserted at the base of the water rervoir right on the small **** which when it sits on the C190 base lets a valve open in order the water to flow through. The "O" ring was 2 to 3 mm in diameter and about 1 mm thick, You might experiment with different ones until you solve your problem.
Jul 02, 2011 | Nespresso C190 Espresso Machine
WHEN SWITCHED OFF, WATER LEAKS AT THE BASE OF NESPRESSO C100 MACHINE
I opened mine when this did this - it also happened to my second Magimix Nespresso Manual machine. A short pipe carrying pressurized water had burst. I called Nespresso . parts were not available and they offered me a new half-price machine. We are talking a 4 inch piece of plastic tubing here. Shame on you Nespresso for encouraging me to throw what is otherwise a fine machine....
Nov 14, 2010 | Nespresso Essenza C100 Espresso...
I need the instructions for descaling the Nespresso Romeo E350 Espresso Machine, I have the descaling solution but not ... Solve It! Solve It! ...
Thanks
Tim
Oct 13, 2010 | Nespresso Romeo E350 Espresso Machine
Nespresso essenza en90,o
I opened up my krups nespresso xn 2105 essenza C100N machine today. It was not starting up quick enough, so silly me decided to dunk it in hot water. My nespresso is an automatic, it has the on/off switch down in the back. My guess is the water that went in there is what is killing the house fuse now. So I really needed to open it up. Not knowing how to proceed, I looked at fixya first, No details yet. So here is what I did.
I looked at the screws, (post on fixya suggested they are screws) at the bottom. There is 6 of them. They look like rivets as if they have been made into round blobs after putting them in. So I took a dremel-like small grinder (a really small drill would do better) and made two small notches on the side of each one. Be careful not to chip away too much plastic of the machine ;) Then I used very small and long pliers to get them turning. That is actually easy, they are lightly set in plastic. Hard part is to keep the pliers from sliding off. Actually once loose the most of the turning I did using a narrow rubber tube, I guess you could use the rubber on the back of a pencil as well. So, remove 6 bottom screws, actually you can remove the sides now. This gives you access to the area where you can see all the wiring and many of the parts. For me I needed access at the bottom, so I removed two more screws near the bottom, and removed the bottom plate. The on/off switch for the automatic sits down the back of the machine, there is one additional screw (six pointed star shape) in the internals for this. I did pull off the switchy bit of the switch - do not do this as springs andcontacts fall out... Mine also still has water in there so I guess I found my problem.
Well, thet is how to dissassemble. I will have to find out how to reassemble tonight, to be able to get my wife het coffee in the morning ;)
Apr 17, 2008 | Nespresso C100B Essenza Single-Serve...
Nespresso Romeo E350 Espresso Machine Logo
94 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
