Question about Panasonic E-Wear SD SV-SD85 128 MB MP3 Player
Am unable to transfer music to a 1Gb SD chip
When I put a 1Gb chip in, it is recognized as an SD chip, but when I try to move a song, the software states "file not recognized. Please format (or close to that statement)". So I format. Result = zero. Same thing. It is an endless circle. Help Thanks, mbb55
  • 175 Answers
SOURCE: AAC Files Transfer
Yes look in the net to get a mp3 converter toacc then just drag those files you converted to your SD card it will work. search google mp3 to acc.
Posted on Jul 19, 2006
0 characters
1 Points
How to transfer music from sd card to my mp3 stix
Hi sfarmer1983...
Plug your SD card into an SD card reader...the plug the card reader into the computer.
The computer will recognize the card reader and open a will select "see files"...
Highlight the songs and put them in Windows media Player...plug your mp3 player in while the computer is running and Media player is running...Media player will recognize your mp3 player
Highlight your songs in the SD card reader...drag and drop the files to Media player...
Please take time to rate me
Sep 21, 2011 | Ministry Of Sound Stix Lite MP076 MP3...
I Have 2 problems, I put songs on my player and it says that the file doesnt exist on some songs. The player does support the format of the song but its not recognizing it. The other problem is that I...
File Doesnt exist, means the music is not MP3 that your putting on, make sure its MP3 format. In regards to SD card support, the unit doesnt combine the internal and external memory. You would have to access the SD memory from the Explorer icon on the main menu.
Jul 10, 2011 | Coby MP828 layer
Can't locate the music on the player in windows explorer. Every folder seems to be empty. The player itself recognize and plays about 230 titles...but where are these files located on the player and why...
The location of all the music on your Sansa is Clip+/Internal Memory/Music.
If the folder is empty, you should now think on which mode you you transfer the songs MTP or MSC. If you transfer songs on MTP, you can only see them on that mode and vice versa.
Try to check the current settings on your Sansa by going to MENU/SETTINGS/SYSTEM SETTINGS/USB MODE
Try changing the USB modes and check the folder again.
If songs are not showing on both modes, possible that the files are hidden or corrupted.
Mar 02, 2011 | SanDisk Sansa Clip MP3 Player
Unable to put music on my mp4
The Sansa Clip can only recognize certain file formats (mp4 is not one of them). Your best bet is to only download songs that are in mp3 format. iTunes format will not work. Some WMA's will work, but others will not - it all depends on whether the WMA files has a fixed-term license or whether it has a license that allows transfer to portable devices. Songs in mp3 format will never give you trouble.
Mar 08, 2009 | SanDisk Sansa Clip MP3 Player
Adding music to player
If your mp3 player truly is a Nextar MA933A - which I doubt - you can't do it directly. You would have to transfer the songs from your SD card to your PC, and then move them from your PC to the Nextar.
-Tha Mp3 Doctor
Jan 29, 2009 | Nextar MA933A MP3 Player
Problem with videos stored in SD card
The Sansa Media Converter (SMC) software is required to convert and transfer videos as appropriate to your Sansa or your microSD card.
Dec 15, 2008 | SanDisk Sansa e250 MP3 Player
I uploaded pictures, songs and videos into 1GB micro SD card. But in Sansa e250 am able to see only songs in it. am unable to view pictures or vidoes stored in SD card. please help me.
The Sansa will only show photos and play videos from its internal memory, not the microSD card. You can put music on the card, but not photos or videos.
Mp3 Player not reading SD 1GB Card
The Sansa is unfortunatley one huge mess up the programming has failed its working on a database with only 4 levels but for grphics and songs you need at least 7 lhopefully you can return it and get another if not you can try putting another type of chip hopefully that will work
Apr 11, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa e130
I have a 1GB SD card in my E130 Sansa. I had fill it up to 998MB. The only problem is that I have to leave 3MB in the flash unit. I guess it need it for constructing the Music Library.
The Flash (512MB) and the SD card (1GB) are both in FAT32.
I guess that it may be a problem of the SD card itself and not a problem of the Sansa.
1) Have you tried to read the SD card with a card reader (without the Sansa)?
2) Have tried formatting the SD card (not a quick format, but a real one) in FAT32 (be careful about that).
Sep 03, 2007 | SanDisk Sansa e130 MP3 Player
Panasonic E-Wear SD SV-SD85 128 MB MP3 Player Logo
Top Panasonic MP3 & Digital Media Players Experts
Gyula Lacz
Dave Rojas
Dave Rojas
Level 1 Expert
 Mike M
Mike M
Are you a Panasonic MP3 and Digital Media Player Expert? Answer questions, earn points and help others
