Question about Sewing Machines
How do I thread a huskylock s21 serger - Sewing Machines
  • 255 Answers
SOURCE: Need threading diagrams for Huskylock A234D Serger
Try http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Posted on Jan 11, 2010
SOURCE: threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Posted on Oct 20, 2008
Zenqi
  • 208 Answers
SOURCE: I need a threading diagram for a Viking Huskylock 560ED serger
Call Husqvarna Viking at 440-808-6550 and they will email you a PDF of the manual.
Posted on Oct 01, 2009
  • 371 Answers
SOURCE: I have a huskylock 1002lcd serger. The cutting
See an authorized husqvarna viking dealer for parts (and service). It's possible you might find the part at third party vendors on line but your best bet is with an authorized HV dealer. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 14, 2010
  • 1116 Answers
SOURCE: Huskylock 910
Here is a video - http://www.husqvarnaviking.com/us/421.htm
Posted on Mar 15, 2010
Viking Huskylock 560 ED threading diagram
Viking 560 ED Huskylock Handbook
Threading Serger this may be helpful even if it is not the same model. The sequence of threading loopers is VERY important. If you thread them out of order, be prepared to be frustrated beyond belief!!! Something else (I don't think she mentioned) is to ALWAYS RAISE the presser foot when threading your machine. This is true for sergers AND sewing machines!
How to thread Serger
Nov 17, 2016 | Sewing Machines
Threading huskylock 530 serger
Hello
Here is the link for the Huskylock 530:
http://manuals.husqvarnaviking.com/
Enter "huskylock 530" in the empty window and select "Search".
This will bring you to a new page. Click on the blue line containing the descriptions of all overlockers contained in the same manual.
You will be on a new page again where you may choose to download the manual.
Happy overlocking!
Sewingirl/
Jan 31, 2014 | Husqvarna Sewing Machines
Huskylock 936 will not form a 4-thread overlock stitch
It may be difficult to solve a computer controlled machine with as many options as the 936 serger. Stepper motors control many of the functions. You can check out this video I made 4 years ago to get an idea of where to look.
Nov 19, 2013 | Husqvarna Huskylock Computerized 936
Huskylock 910 starts to serge normal and then begins to take extra thread and make a mess. what can I do to fix this?
try changing the needles
make sure the serger is threaded correctly
check for any burrs in the needle plate area, or on the loopers
also make sure the tension is adjusted correctly for the fabric
May 15, 2012 | Husqvarna Huskylock Computerized 910
I have a Huskylock 936 Serger and used it last week, no problem. I changed the threads for a new product and one thread came out and had to rethread. I know you have to thread the upper looper first then...
Recommend you remove all the threads and rethread from the beginning. ALWAYS RAISE THE PRESSER FOOT when threading and thread the upper looper first, the lower looper second. Sergers sometimes are temperamental about threading. When in doubt, start over from the beginning.
Jun 14, 2017 | Husqvarna Huskylock Computerized 936
Threading a huskylock 234d serger
I have seen some models with a diagram for threading. Look inside the cover, in front of the machine.
Jun 01, 2010 | Sewing Machines
Sep 30, 2009 | Sewing Machines
Sewing Machines Logo
400 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
