Question about Ryobi Garden
4 stroke ryobi weed eater will not run or dies at full throttle
  • 61 Answers
SOURCE: Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Posted on Apr 29, 2010
  • 64 Answers
SOURCE: MY RYOBI S430 WITH THE EGDE ATTCHMENT WILL NOT RUN
too much drag on the edger, try putting some oil or lubricant spray where the edger spins on the attachment.
Posted on May 04, 2010
crapiemael
  • 241 Answers
SOURCE: Weed Eater Problems
If it runs with the choke closed then it's not getting enough gas. Check the gas filter on the end of the gas line in the gas tank. Remove the gas cap and using a piece of wire with a hook on the end, reach in the tank and pull the gas line out through the opening. Check the filter on the end of it. You could also have a burst-ed diaphragm in the carburetor. This sucks the gas from the tank to the carb. If that's the case a new weed eater may be in order unless you can find someone with the parts to repair it. Also check the gas lines for leaks or breaks, 2 of them.
Posted on May 17, 2010
  • 15 Answers
SOURCE: Ryobi weed eater runs at full choke, but stalls
does it blow out alot of blue or dark exhaust? if so adjust screw on carberator as it maybe be running rich, if this doesnt work have the switch checked for malfunctioning
Posted on May 31, 2010
rycgl
  • 1545 Answers
SOURCE: replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Jul 10, 2010
I have a Ryobi S430 4 stroke Weed Eater Trimmer. How many times do i pump the choke (primer) to start cold?
Page 4 and 14 of the manual. A choke is just a device that reduces air flow to the carburetor by closing a flap. You don't pump it, you just move it to the full choke position. I think you may be confusing the 'primer bulb' which pumps fuel from the tank to the carburetor.
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/s430_ry34441.html
To start a cold engine:
? Slowly press the primer bulb 10 times.
NOTE: After the 7th press, fuel should be visible in the primer bulb. If it is not, continue to press the primer until you see fuel in the bulb.
? Set the choke lever to FULL CHOKE position.
? With the throttle trigger at idle, pull the starter handle sharply until the engine attempts to run. Do not pull the starter handle more than 4 times.
? Set the choke lever to HALF CHOKE position.
ryobi s430 4 cycle weed eater manual Google Search
Mar 20, 2018 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    My Weed Eater FL1500LE gas leaf blower will not run beyond the full choke setting. If I move the lever to half choke the engine will stop. Or if I move the throttle from full throttle to a lower speed...
    This is a tell tale sign of a lean fuel mixture. By choking the unit you are manually creating a richer fuel mixture. I would purchase a compression tester from a local parts store and check compression. If that's ok, I'm willing to bet the problem is still carb related. Two stroke carbs are tricky to clean because of high/low ports that are one way and sometimes impossible to clean. Did you remove high and low needles when cleaning carb? Another trick is to mix seafoam with your gas, then mix two cycle oil to proper ratio. Use 2 ounces seafoam to one gallon of gas, then mix two cycle oil to proper mix. Hope this helps! Good luck and happy wrenching!
    I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
    Sep 22, 2013 | Weed Eater Fl1500 Le Leaf Blowers
    Weed eater head spins on its own, no power.
    check the compression on your weedeater low compression will cause this
    Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
    Can I use 4 stroke oil in a ryobi cs 26 weed eater?
    only if you want to buy a new weed eater.
    Jun 20, 2013 | Garden
    My Ryobi cs30 weed eater tends to shut off after I release the throttle.
    Find the idle speed screw (not the jet screw) and turn it CW until the engine idles without dying. If too high, the string head will turn all the time. Hope this helps
    Sep 06, 2010 | Ryobi Garden
    Apr 27, 2010 | Ryobi Garden
    I have a ryobi weed eater clean carb change filter and spark plug wont run off choke
    I have the same problem. It will run if I put it halfway between Half Choke and Full Choke. But, just dies if I put it on Run or Half Choke. Don't ever loan your WE to anyone, They might just try to run it on straight gas--That is what happened on another week eater that I had.
    Mar 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
    Garden Logo
    274 people viewed this question
    Top Ryobi Garden Experts
    Jim Parker
    Jim Parker
    Rexter1
    Are you a Ryobi Garden Expert? Answer questions, earn points and help others
