I have A Vizio WXR100 router and no manual, i have reset it and don't have the key. any solutions?
Just need a factory key number after resetting
Dionnow
  • 61 Answers
SOURCE: Reset problem, router won't start again
If the powerlight flashes the entire time.. even after a hardreset, your router is probably only good for a brick....
Posted on Dec 31, 2007
XRAYRON
  • 156 Answers
SOURCE: Factory Default Reset Procedure
Hold the reset button in for 10-15 seconds... Now its defaulted back to factory and the user name and pass will both be admin
Posted on May 07, 2008
marked
  • 6487 Answers
SOURCE: reset to factory default
To reset the router to factory defaults just press and hold the reset button of the router for 30 seconds while the power is ON use a pen or a paperclip to reset the router, then after 30 seconds unplug the power of the router after that the router should be reset already...
Posted on Oct 25, 2008
  • 59 Answers
SOURCE: Hi, I am trying to reset my 2wire 1800HG router in
you have to open internet explorer and type 192.168.1.254. then go to broadband link at the top of the page. hit the advanced settings then you have to re enter all you information like your username, password etc... i hope the helps you if i doesnt let me know.
Posted on May 18, 2009
kakee
  • 1269 Answers
SOURCE: I lost my wpa key number and have now reset the router - help!
You need to connect your computer hardwired to the router and reconfigure it. On your wireless computer, you need to delete all the preferred networks and add a new wireless profile.
Posted on Oct 06, 2009
Don't the user name or password for my motorola SB900 can you help ?
That's depends...First, do you have the password to log into the modem? it seems that the default is admin/motorola. If that hasn't been changed, you could log in and remove the WEP key.
In addition, most modems and routers will reset to factory defaults if you press and hold in the reset button for around 30 seconds with the device turned on. Forgetting the password is a common problem. Don't be worry...Or if these all can not work, you can call or ask directly to the customer service of Most modems and routers will reset to factory defaults if you press and hold in the reset button for around 30 seconds with the device turned on. Forgetting the password is a common problem. Don't worry... or if the above ones all didn't work, you can call or ask the Motorola customer service directly, maybe they know the solutions because they produce it!
May 30, 2012 | Computers & Internet
How to reset netgear xet1001
You can reset your Netgear router/wireless xet1001 router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless xet1001 router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the router has been reset.
Feel free to get instant online Netgear router support athttp://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router issues.
Mar 29, 2012 | NetGear Powerline Network Xet1001...
HOW TO RESET THE ROUTER
You can reset your Netgear router/wireless WGT624 router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
Step 1: Check that your Netgear router/wireless WGT624 router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Feel free to get instant online Netgear router support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router issues.
Feb 06, 2012 | NetGear : WGT624 108 Mbps Wireless...
I don't know how to reset password for d-link DIR-625
Section 1 - Product OverviewHardware OverviewConnectionsUSB Connect a USB 1.1 or 2.0 flash drive to configure the wireless settings using WCN.Reset Pressing the Reset button restores the router to its original factory default settings.LAN Ports (1-4) Connect Ethernet devices such as computers, switches, and hubs.Internet Port The auto MDI/MDIX Internet port is the connection for the Ethernet cable to the cable or DSL modem.Power Receptor Receptor for the supplied power adapter.D-Link DIR-65 User Manual
If you don't know it you can check our list of default router and modem password list here.
If you have changed it and don't remember it you may have to reset your device to factory default using the reset button on most routers.
Sep 23, 2011 | D-Link DIR-625 (790069292637) Wireless...
Its asking for a eight number code
It is asking for your security key. If you do not have it, you will need to reset the router:
How to reset D-Link router to the Factory Default Settings
In general, to reset the D-Link to the Factory Default Settings, please follow these steps:
1. Turn off the router
2. Locate the Reset button on the back of the router.
3. Use a paper clip to press the Reset button and power on.
4. Hold for about 5 seconds (don't hold too long) and then release. (Or, release when M1 and M2 flash at the same time.)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 13, 2011 | D-Link 802.11g Wireless Router WBR-1310...
I have a linkseys Router and need to retrieve the passcode key to synchronize my ipod touch. How can I retrieve the key when I don't remember it.
You need to login with your I.E. browser and type:
http://192.168.1.245
You factory user: admin
Your factory pass: admin
Then try to check for the password.
Another way to do this is to do a 30/30/30 reset.
30 seconds hitting the reset bottom, (DO NOT RELEASE)
Unplug the power cord (Keep Holding the reset button and HOLD FOR 30 seconds)
Plug the Power Cord (Hold for 30 seconds)
Reset.
Then you can try setting up the router again with the manual IP method or with the software provided by Linksys
Hope it helps.
God Bless You
Remember to rate to keep fixya.com working for you
Jul 30, 2011 | Linksys Wireless-G WRT54G Router
I just brought my tv in 3 days ago 55 inch led 240 hz it's just shut off randomly
THE VIZIO XVT553SV has a know problem of random power cycles and random shut offs. It is recommended you call Vizio Technical Support for a proper and permanent solution.
Toll-Free: 877.698.4946 (877 MY VIZIO) Technical Support if you don't get proper assistance at that number call the Executive Office at Phone: 949.428.2525
Jul 18, 2011 | Vizio XVT553SV 55 in. LCD TV
I need to rest my router
YOU CAN RESET THE ROUTER TO FACTORY SETTINGS
You may reset router to factory setting from the reset button on the back side of the router. Use a paper pin to press the button for few seconds, the lights on the front would blink and the router would restart with factory setting. Please not that ALL SETTING WOULD BE LOST...AND YOU WOULD HAVE TO MAKE CONFIGURATIONS AND SETTING ALL OVER AGAIN
HOPE IT HELPS...Let me know if you need any further assistance
CreativeTECH
Nov 16, 2010 | NetGear Computers & Internet
How to reset Netgear RangeMax NExT Wireless Router WNR834B
Do a hard reset (20sec hold reset button, unplug for 20 sec still pressing the reset button and another 20 sec to turn on the power while holding the reset button). That should reset to defaults.
Jul 04, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
