Question about Linksys Wireless-G WRT54G Router
Wireless connection to laptop
The WRT54G is working well with two computers hardwired together, but, when I attempt to connect my laptop I do not have the required information. I have misplaced my linksys information and therefore only have the codes present on the bottom of the unit. A friend brought his laptop over and had no trouble connecting to internet wirelessly ??
  • JUDITHM47 Nov 03, 2008
    I have the wireless g cable router and I have recently purchased a laptop. The router works with both desktop computers, and also if I hook up the laptop through the ethernet, but I can't hook it up wireless.
    Brigadier General:
  • 6,966 Answers
Initially, pls verify that your laptop is set to "Obtain an IP address automatically". Additionally, pls post back the laptop brand/model, the WiFi card the laptop is using (add-on or built-in) and your OS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 30, 2008
Have a WRT54G lately my hardwired desktop connection has been loosing it connection while my 2 laptops will stay connected with no problems.. only way hardwired connection will reconnect is to reboot...
How long have you been using the router? Might need to update the firmware on your WRT54G. But do it EXACTLY as instructed on the Linksys website, as incorrect attempt can result in need for new router. I know that sounds drastic, but you can do it just fine - just be aware that you have to follow the steps precisely as they are stated and in the correct order. Never had a problem myself, but have heard of those who did, and it was ALWAYS because they did not follow directions. If you are not comfortable doing it, get a "techie" friend to do it for you.
Sep 25, 2010 | Linksys Wireless-G WRT54G Router
Hardwire ports on wireless router not working
You could
1) Reset the router to factory default by hitting the reset on back
2) You could visit the router over the wireless link (http://192.168.1.1) default password is "admin" username blank.
Check on the page to ensure the ports are enabled.
3) Update the firmware on the device. see if it works.
Note there is a port called "uplink" which is designed for the internet connection and not the local computer.
Jul 22, 2010 | Linksys Wireless-G WRT54G Router
Was working fine, moved to another apartment down the hall, now it won`t even show under wireless connections, but i can connect to any unsecured network in our building and hardwire my laptop into the...
Considering How thick the walls are... the signal from your router may not be able to go through plus all the other EMI devices like Chordless phone etc.
Try Setting up the router in an open area suitable for a better signal for your laptop.
Apr 04, 2010 | Linksys Wireless-G WRT54G Router
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect to wireless router
Make sure you are connected via hardwire connection. Restart router and select 'Start->Run' and enter 'ipconfig -renew'. If you are still not able to reconnect to router try pressing and holding the reset button on the back. This will restore it to the default settings including username and password.
Feb 14, 2009 | Linksys Wireless-G WRT54G Router
Cannot access the internet
try this :
1. it seems that the power outrage had caused your wireless settings to be restored to its factory settings .... so there is a need to reconfigure it again ...
the settings that are saved to my computer do not match" --- this usually pertains to the network settings saved on your laptop, if it is vista you must delete the old profile,it also applies for xp OS ....
VISTA :
>network and sharing center
> manage wireless connections
>under networks you can view or modify, highlight the old profile then remove
XP :
>netowrk connections
> right click on wireless network connection and go to properties
>click on wireless tab
>under preferred networks (box in the middle) highlight then remove
2. to check this do ipconfig on the cmd line
•check the default gateway if it is still 192.168.1.1 or 2.1 ( the default gateway is the rtr's address)
•open your browser, then type the rtrs ip
• leave the username blank, password is admin ( small caps)
• then you are in the set up page
• check the wireless tab, and very the ssid if it is still or the name of your network which you used to connect to ...
• just save the settings if you want to make changes
****** very impt : while doing this changes, your main pc or dsktop pc must be hardwired to the router ,, never make changes wirelessly coz the connection is very instable you will be kicked of everytime ..... ***********
GOOD LUCK!!!!!
Oct 21, 2008 | Linksys Wireless-G WRT54G Router
Wireless connection
Possible you did reset the router. Its okay to connect to that linksys network name. But if you want to customize you network name.
MAKE SURE TO USE THE WIRED COMPUTER TO SETUP WIRELESS CONNECTION.
Example : The Desktop computer that is connected to directly to router.
Just follow the steps.
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3967&p_created=1159257209&p_sid=aNKUFggj&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODExJnBfcHJvZHM9MCZwX2NhdHM9MTcyMSwxNzIzJnBfcHY9JnBfY3Y9Mi4xNzIzJnBfc2NmX2xhbmc9MSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PUNoYW5nZSBTU0lE&p_li=&p_topview=1
Hope it will work..
Oct 14, 2008 | Linksys Wireless-G WRT54G Router
Lose Connections over and over...
You may need to set specific ports on your router to use the voip. log onto router and go to the applications and gaming tab to set the specific ports voip needs to access Internet.
Jul 07, 2008 | Linksys Wireless-G WRT54G Router
We have one router hooked to our main computer in one room, we have a lap top that is functioning perfectly through this router. We are having problems adding an additonal desktop to this router? What...
hello!
if you will connect the desktop hardwired or dierctly to the router, make sure that the ethernet adapter is properly installed and the ethernet cable is working.
if you will connect the desktop wirelessly, make sure that the wireless adapter is properly installed on the desktop and make sure that the wireless settings are properly configured.
May 06, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
