Question about KitchenAid Dishwashers
Dishwasher won't hold water
The water won't hold during the water heating heating or wash cycle - so the element heats up dry, and no water sprays inside. The water comes in and runs right out again.
Joe_Rex
  • 114 Answers
SOURCE: dishwasher problems
TURN POWER TO OFF ... REMOVE THE LOWER RACK. THE SPINNING SPRAY BAR USUALLY WILL LIFT SRAIGHT-UP AND OUT ... INSPECT TO SEE IF ANY THING IS IN THERE TO PREVENT IT FROM SPINING FREELY ... THEY SPIN BY WATER PRESSURE SO THE NEXT THING TO CHECK IS THE WATER SUPPLY VALVE (MOST OF THE TIME IT IS RIGHT UNDER YOUR SINK.) AND THE STARAINER is LOCATED WHERE IT CONECTS TO THE DISH WASHER. MAKE SURE YOU HAVE A BUCKET AND RAGS HANDY FOR SPILLS... CAREFULLY TURN THE VALVE OFF AND REMOVE THE COMPRESSION FITTING NUT THAT IS ON THE "SIDE CLOSEST TO THE WASHER".... THEN CRACK THE VALVE OPEN AND FILL THE BUCKET UP A FEW TIMES TO ENSURE GOOD WATER FLOW. TURN VALVE "OFF" AND GO TO WERE THE LINE OR HOSE CONNECTS TO THE WASHER. REMOVE THE CONNECTION ... INSIDE YOU SHOULD FIND A STRAINER THAT MAYBE CLOGGED UP. CLEAN-IT AND MAKE SURE TO TIGHTEN ALL THE CONNECTIONS BEFORE STARTING A TRIAL RUN. NOTE: THERE IS A SOLENOID INSIDE THE MACHINE THAT CAN STICK AND GET CLOGGED BUT USUALLY ITS THE VALVE OR THE STRAINER. GOOD LUCK AND STAY DRY ... Joe_Rex
Posted on May 01, 2007
  • 1314 Answers
SOURCE: Problems with my dishwasher
You need to replace the dispenser or possibly the wax motor on the dispenser. I would be more than happy to help you. But need to know the brand an model # so I can make sure that I give you the proper advise.
Posted on Jan 01, 2008
SOURCE: dishwasher pump will drain but not force water into spray arms
If the washer is not used regularly the shaft can stick to the seals and prevent the motor from spinning. This happens quite regularly for me if I don't use the washer often. You can just take off the bottom panel - after shutting off power to the dishwasher - and access the motor. you should see some fins and then just try to spin the motor by hand. It usually takes about 90 degrees of rotation before the motor breaks free from the seal. You'll have to fight through the spring-like resistance created by the seal-shaft adhesion. After it breaks free the motor spins freely and you should be all set to go. I haven't found a more permanent fix for this other than running the dishwasher more regularly.
Posted on Feb 09, 2008
mosesclive
  • 191 Answers
SOURCE: Indesit DI620UK Dishwasher fault
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Posted on Jul 19, 2008
aborcass
  • 2651 Answers
SOURCE: Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Posted on Jan 25, 2009
My kenmore dishwasher doesnt heat during drying
The heating element is burned out or the heating circuit is fubar.
Sep 08, 2016 | Kenmore Dishwashers
Kenmore ultra wash dishwasher gets stuck at 42 on the control panel
Be aware that all (well, almost all) dishwashers have a "thermal hold" period in their cycles. This is the point in the main wash cycle where the heater is turned on to heat the water to the optimum wash temperature (about 150 to 160 deg F), and during this time, the timer will stop advancing. Once the water has reached the desired temperature, the cycle will continue. IF it does not, then you have a water heating problem. This could be caused by a bad heating element, a bad controller, a bad thermostat or temperature sensor.
Mar 20, 2015 | Kenmore Dishwashers
How do you turn up the heat on the dish washer drying cycle?
There is no way to turn up the heat of the dishwasher during the drying cycle. As part of the current ecological, energy-saving, environmentalist-wacko movement, dishwasher makers have cut back on the heating used to dry dishes. But you can do these things to help with drying:
1. It is imperative that you use rinse-aid (Jet-Dry). This allows more water to flow off the dishes and what flows off does not need to evaporate.
2. If the dishwasher has the options, turn on high-temperature wash and sani-rinse. This gets the dishes hotter for better evaporation during the dry cycle.
It is possible that the heater may not be working at all, and that will cause poor washing performance and no drying. That problem can be caused by a bad heating element, or by a bad controller.
Sep 21, 2014 | Whirlpool Dishwashers
AEG F60873 temperature problems.
The problem when the dishwasher does not heat is failure which requires to remove the qualified personnel and therefore error code is not shown on the display but it is visible in the service mode.
Possible error causes:
faulty heating element
wiring between heating element and PCB
PCB (printed circuit board)
Dado
Aug 24, 2014 | AEG Dishwashers
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Sep 07, 2011 | Westinghouse Dishwashers
What does a thermometer symbol with up arrow mean on an shx68
Hello Jsg5,
That symbol means that the dishwasher is heating the water, bringing it up to the required temperature to properly sanitize your dishes.
This symbol can appear during the wash and rinse cycles. It is nothing to worry about. Most dishwasher will heat up the wash and rinse water, it's just that Bosch decided to add an indicator, so users would know that any delay in the wash/rinse cycle, is a result of getting the water up to the proper temperature (typically around 140 degrees F)
Even if you've got your hot water heater or hot water supply set to a very low temperature, the dishwasher will use the built-in heating element (the drying element in the bottom of the dishwasher) to heat the water.
Hope you find this Very Helpful and best regards!
Dec 10, 2009 | Bosch Integra 800 SHX68M0xUC Dishwasher
Water does not get hot. Takes hours to wash and dishes wet when done
Dishwashers have a heating element underneath the lower spray arm. It is used to heat the water during the wash and rinse cycles and most use the same element to heat during the drying time.
Now, when a heating element fails, the other common symptom is poor cleaning, with a film on the glassware.
The first thing to do is inspect the heating element for breaks and/or "bubbles" on the surface of the element. Replacing it should clear your problem right up.
Good Luck! Please report back what you find. OK?
Apr 21, 2009 | Dishwashers
Our Whirlpool KUDP01ILBS2 dishwasher isn't working like it used to. Dishes seem to be getting partially clean, they aren't getting dry at all and it seems they may be being rinsed/washed with dirty...
Heat that is retained in the dishes is largely responsible for drying in this dishwasher. Since plastics do not retain heat very well, they will not dry as well as glasses, ceramics or metal dishes. Rinse aid must be used so that the final rinse water will sheen off of the dishes to accommodate this drying process. The heater element at the bottom of the tub is used to add heat during the drying cycle to aid in this process as well. This model of dishwasher does not have any forced air circulation system. Here are some tips that may help you resolve your drying problem:
  • Make sure that you are using rinse aid. Failure to properly use rinse aid can prevent proper drying. Adjust the amount that is dispensed if necessary. Also, check to make sure that rinse aid level decreases over time indicating that it is being dispensed properly.
  • The NORMAL WASH and POT & PANS cycles heat the final rinse water up to 140 degrees F. Use these cycles to help the drying process.
  • Do not choose the air dry option. This option cuts off the heater element during the drying process. NOTE: The heater element is not turned on during the first 6 minutes of the drying portion of the cycle.
  • Do not overload the dishwasher. Load the dishes to allow for proper water drainage.
This dishwasher has a heater fault detection circuit. If the heater is not working, the control will detect the lack of increase in water temperature. The dishwasher will stop and the CLEAN light will blink seven times repeatedly. The dishwasher would not be able to be used until the problem is corrected and the control is reset.
Feb 10, 2009 | Dishwashers
Heating element
Drying fan
Thermostat
Jul 19, 2008 | Dishwashers
Dishwashers Logo
224 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
