Question about Elgin 0518709FA
How much is base metal bezel m.z. mbs 507138
It is embassy
How much is a ELGIN men's Diamond Base Metal Bezel FG007 017 PC21 Japan Movt stainless steel back wrist watch worth
probably not as much as you think it is worth. There are to many varibles to consider value. An item is only worth what another person is willing to give you for it. If you truly want its value, go have it appraised. That will cost you to get a qualified appraisal.
Apr 24, 2016 | Elgin Watches
Tip
Watch glossary: E
EBAUCHE
Incomplete (jeweled or non-jeweled) watch movement without regulating organs, mainspring, dial and hands.
ECO-DRIVE
A name for a patented power mechanism found on some Citizen watches. This mechanism uses ordinary light to keep a rechargeable battery powered for watch operation. This technology is very sophisticated allowing some watch models to remain powered for up to 5 years in the dark. Watches with Eco-Drive technology will never need to have the battery replaced.
ELAPSED TIME ROTATING BEZEL
A graduated rotating bezel used to keep track of elapsed time. The bezel can be turned so the wearer can align the zero on the bezel with the watch's seconds or minutes hand. After a period of time passes, you can read the elapsed time off the bezel. This saves you having to perform the subtraction that would be necessary if you used the watch's regular dial.
ELECTROPLATING PROCESS
Process of covering metal articles with a film of other metals. The article is immersed in a chemical solution; electric current (D.C.) flows through the solution from a piece of metal (anode) to the article (cathode), depositing metal thereon by electrolysis.
ENDSTONE
Undrilled jewel, placed on the balance jewel with the tip of the balance-staff pivot resting against its flat surface, to reduce pivot friction. Sometimes used also for pallet staffs and escape wheels.
ENGINE-TURNED, see guilloché.
EQUATION OF TIME
Indication of the difference, expressed in minutes, between conventional mean time and real solar time. This difference varies from -16 to +16 seconds between one day and the other.
EQUINOX
The time when day and night are of equal length, when the sun is on the plane of the equator. Such times occur twice in a year: the vernal equinox on March 21st-22nd and the autumnal equinox on September 22nd-23rd.
ESCAPEMENT
Positioned between the train and the balance wheel and governing the rotation speed of the wheel - train wheels. In today's horology the most widespread escapement type is the lever escapement. In the past, numerous types of escapements were realized, such as: verge, cylinder, pin-pallet, detent and duplex escapements. Recently, George Daniels developed a so-called "coaxial" escapement.
ESCAPE WHEEL
A wheel belonging to the mechanism called escapement
on Jan 11, 2010 | Watches
Timex expedition indiglo wr50
The battery is a CR2016 as noted in the description. Hard to find these days.
Aug 31, 2017 | Watches
How much is a elgin base metal bezel japan movt is worth?
mcdevito75 here, Elgin a great name in watches, usually the back of the watch is base metal while the bezel or fron of the watch is plated, almost any jeweler can give an approx. value to your watch, of couse it"s age and condition count for alot.
Jun 14, 2010 | Elgin 0518709FA
The black plastic ring, w/ white markings (bezel ?), that goes on the metal (dial) which moves around, fell off. Is this part avail., and if so, for how much ?
This part is called the bezel, you are correct. They are available to buy as a separate item for certain watches, but not all. You didn't mention what type of watch it was. Most major brands, like Rolex, Omega, Tag Heuer etc all sell bezels for their watches, brands though like Diesel, Rotory, Seiko etc, do not sell bezels as a stand alone item. Should you wish to let me know the make and model of the watch, I will see if I can obtain one, or failing that I will see if I have one that will fit.
Apr 24, 2010 | Casio Marine Gear AMW320D9EV Wrist Watch
I can't pull the bezel out to change the time on this watch! Help
The bezel is metal ring surrounding the crystal. What you can not pull out is called CROWN. Unscrew it first and then pull out.
Mar 29, 2010 | Guess 11040L2 11040 Watch for Women
A metal jewel fell off of the watch face and is loose on the dial
I suggest you take it to a watch shop and ask them to repair it for you.
It can be more difficult than it appears to remove and replace backs particularly.
Feb 25, 2010 | Watches
Elgin 0518709FA Logo
44 people viewed this question
Top Elgin Watches Experts
jdthefixer
Andrew Taylor
Andrew Taylor
Are you an Elgin Watch Expert? Answer questions, earn points and help others
