Question about GE Microwave Ovens
Our microwave is a GE Spacemaker, Model # JVM1630WB004, mfg. in Mar, 2001. Just today it suddenly decided not to function other than the light in the oven coming on when activated, etc. It does not cook anything right now. Is there some kind of a fuse or similiar place where we can access the power unit to fix this problem?
  • 728 Answers
You may either have a short or another electrical problem. You might have to get it checked up in a shop to see if the heating element inside the microwave is faulty and if it is, you might need a new element or some electrical things inside to get fixed. If it is a short, it might have overheated the circuit board that controls the heating element to stop working, only allowing the light to come on when activated.
Posted on Oct 27, 2008
  • GE Master
  • 13,433 Answers
If your microwave oven doesn't seem to work at all, check these:
Fuses
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
  • Ekse Oct 27, 2008
    if the fuses are ok and the door switch works also.
    It may be a circuitboard or other component problem. if you need to get inside the unit, you need to take the cover apart but I warn you if you don't have electronics repair experience.. at all it may be best you contact a repair man, as its alot more dangerious when working inside a appliance that works with the current that comes out of the wall socket which can kill, than working inside a computer or other low voltage device.
We have moved to a home with a GE Spacemaker Microwave/Vent Model JVM1630WB004. I need installation instructions as it has been removed from it's previous space. I also would like to get an operating...
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave #JVM1650WB008 is not heating.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Mar 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker model # JMV1640BB002
magnatron went bad need new one, cheaper to buy new unit
Feb 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1631BB005 making noise
Many thanks to e3enigma above! I removed the synch motor under the turntable; all other microwave functions work fine and the grinding noise is gone, hooray! A trip to the appliance parts store tomorrow for a replacement synchronous motor and all should be well. Thanks again!
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Oct 13, 2007 | GE Countertop Microwave Oven
Microwave Ovens Logo
160 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
