Question about Hitachi 53FDX20B 53" Rear Projection Television
Power on After the tv has been turned off, it will come on automatically at random times
  • 149 Answers
Try and look under a menu or something in the tv maybe it is on some kind of timer..
Posted on Oct 27, 2008
I have a Panasonic TC-P65VT60 Plasma TV that seems to randomly turn itself ON. What PC board is causing this?
That is a plasma and usually power supply board. ebay search your model number. Also look for blink codes on front if it locks up. lastly check for software upgrades for you model thru google
Dec 02, 2017 | Panasonic Televison & Video
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Why does my tv shut off randomly
Could be the timer is set to automatically turn the tv off after a set amt of time, or perhaps your power cable is loose
Aug 11, 2015 | Televison & Video
Shuts itself off periodically
If the period of time in question is reasonably consistent - say 45 minutes after powering up it shuts off - you could be suffering from an overheating issue inside the unit. Temprature sensors can override manual operation and shut the unit off to avoid greater damage (or even a fire) occuring. Have the TV serviced.
If you find it happens at random time intervals from cold this is less likely to be the case and it could be relative to the mains power supply going to the TV. If you suffer from 'dirty power' (power that dips and surges instead of giving a consistent voltage) this could also cause an automatic shutdown condition within the TV. This could happen at any time after the unit has been turned on. An unterruptible power supply (UPS) would help with that.
Aug 18, 2009 | Vizio L32 32 in. LCD HDTV
TV Turns Off Automatically While Watching
Stop trying to turn on the set. You are causing more damage. The hissing sound you are hearing is either a High Voltage Transformer on the SMPS (Switched Mode Power Supply) indicating a short somewhere in the set or some capicitors that have shorted out. Also there can be a CRT that is leaking cooling fluid onto the Main bd or the Power/Deflection bd or both bds. Have a trained Samsung tech troubleshoot the set.
Jul 15, 2009 | Samsung HCM4215W 42" Rear Projection...
LCD TV Randomly Powers off and then back on
I would worry about polterguists
j/k
Check your remote batteries.
I had a TV remote that would do some weird things when the batteries were dying, like the problems you describe.
Jun 15, 2009 | Norcent Technologies LT-2720 27 in....
TV Automatically Turns Off
There are so many different places where an intermittant problem of this kind could occur, it will be nearly impossible for anyone to give you any clear guidance on this one. The most common failure in modern sets is related to the power supply but that kind of problem is one that appears sometimes as a gradual decay of its time to power up or a decreasing length of operating time and finally a failure to turn on at all.
There is a section that is kept 'alive' by a small part of the power supply so the set can accept commands from your remote to power up the rest of the set and the receiver of the remote's IR output stays turned on as long as AC is connected. This section could have a semiconductor that is intermittant so that it sends a command to turn the set on or off without you using the remote to send the command. There are tens of thousands of individual active and passive components in our modern sets and only one single part needs to be randomly failing to cause your problem.
There is a slim chance that the remote is the culprit since they too are never completely 'off' and it could be sending commands on its own. To eliminate this possibility, either take the battery out of the remote or put a pillow on top of it so the IR signal is absolutely disabled.
If the set still does what it pleases, then the remote is OK and the trouble is then definitely in the set itself.
The remote receiver electronics in the set could be part of the main board or a separate item on a small auxilliary board so whoever gets this to repair will need the whole set available.
Nov 07, 2008 | Memorex MLT3221 32 in. LCD TV
Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Oct 17, 2008 | Televison & Video
Powers on and off randomly
one of your tubes are bad...call tech
Nov 26, 2007 | Toshiba TP55H60 55" Rear Projection...
Hitachi 53FDX20B 53" Rear Projection Television Logo
32 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
