I have a barely-used Whirlpool dryer (wed9050xw1) bought and shipped to a house in Costa Rica last year. If there are too many (which means even a small load) or too few clothes in it, it won't run -- the Wet sensor light just blinks. Any ideas?
  • 489 Answers
SOURCE: lg wd-3243rhd front load washer and dryer combo "le" error message
LE error code means the motor sensor has failed.  The motor sensor is located in the back of unit inside the motor.  You will need to order a replacement motor sensor from LG.  You will need a 17 mm and 10 mm socket tools to do this job.
Posted on Apr 28, 2008
aborcass
  • 2651 Answers
SOURCE: Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Posted on Nov 20, 2008
  • 1122 Answers
SOURCE: kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Posted on Dec 06, 2008
SOURCE: Washer Spins But Clothes Still Wet
I replaced the Clutch Assembly.
Posted on Dec 11, 2008
jsrock516
  • 5911 Answers
SOURCE: My Whirlpool Washer lets the water in but it will
Is this a TOP LOADER? Or is this a FRONT LOADER?
If this is a TOP LOADER you may have something as simple as a lid switch malfunction. Symptoms may include, no spinning, no agitation, stopping at the rinse cycle and no draining. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. You should hear the switch "clicking" as you open and close the lid. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between these sites, so shop and compare. Verify if these sites offer international shipping.
If this is a FRONT LOADER, your problem may be attributed to a defective drive motor, or motor control unit (MCU). If the problem were attributed to a clogged drain pump filter, the washer usually does not perform the initial fill. The cycle usually stops before the washer can fill and an error code will be displayed. Depending on the model number, you will receive an error code of "F02", "F21" and/or "SUD". Please post back and let me know if you have a FRONT LOADER, and if you are getting any error codes.
If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing so I can provide you with better assistance. Please include your model number (located on a nameplate along the wash tub rim under the lid) if its different than the one you listed the question under so that I may be able to assist you better. I hope this information is helpful to you.
NOTE: You do not have to drain the wash tub to perform this repair. However, if you wish to drain it due to stagnant water, you can use simple gravity by placing the drain hose in a bucket (messy). Or, you can use a wet/dry shop vac to pull a vacuum on the drain line.
Posted on Jan 04, 2010
I BOUGHT A GARMIN ( GPS ) NUVI 250W I WANT TO USE IT IN COSTA RICA CENTRAL AMERICA. I NEED YOUR HELP.
Hello, are you missing the map of costa rica or can you clarify the problem?
Oct 08, 2008 | Garmin GPS
Repair shop costa rica
It might be best to fill up this form on the internet and mention your problem and location. I am sure someone from Fisher and Paykel US team will answer you.
Contact our Customer Service Fisher Paykel
Jan 29, 2014 | Fisher and Paykel Dishwashers
I need to buy this wire one guy burn it where and how much cost this , if you ship to costa rica?? Tahnks
Try Ebay to look for the cable or wiring harness you need for your car audio system, the international shipping is available from some Ebay sellers.
Mar 06, 2011 | Car Audio & Video
I have an error code 43 for fax KX-F 1050, i am trying to send a fax to costa rica , it is an overseas fax . I can send localy with no problem , i even tried to get a deferent fax from costa rica and i...
try using seperators/pause break between the no. if the Fax is to be sent overseas,
The manual for your fax machine can be downloaded from this link
http://www.devicemanuals.com/guide/Telephone%20and%20Fax/Panasonic/Panasonic-KXF1050-FAX-TkRZeE9RPT.html
Jun 23, 2010 | Panasonic Office Equipment & Supplies
I downloaded a Costa Rica map but I can't pull it
The only workaround for this "problem" is to connect the garmin to the PC, go to the GARMIN folder and rename the file gmapprom.img (this is the main map file) to 1gmapprom.img
reset the device and it will load the costa rica map.
when you need to use the base map again, undo the renaming.
Dec 15, 2009 | Garmin nuvi 255W GPS Receiver
I have a nextar X3-01,bought in Canada I would
This unit only contains the maps for the United States and Canada, and it doesn't appear to have any more maps available for it. You could call the manufacturer, but it looks like there aren`t any maps for Costa Rica for this device.
Sep 13, 2009 | GPS
Garmin gps failure
Bought a PN-60. Purchase download for costa rica, will not download software. Did a auto detect, no dive found. This is a new cable and the usb port has port has been checked with other devices. Stuck in Costa Rica with a use gps. Cost of shipping this back is not cheap.
Mar 31, 2008 | GPS
Washing Machines Logo
245 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
