Question about Vacuums
Need replace filter bosch gl-50 vacuum cleaner
How to replace microfilter
GoVacuum1
  • 6 Answers
SOURCE: Bosch Vacuum Cleaner: I changed
Greetings from GoVacuum.com,
It sounds like you may have a bad thermal switch inside the machine. Most vacuum cleaners have a switch connected to the motor, so if the vacuum cleaner is running hot, it will shut off to prevent any damage to your motor. You did all the right things by checking the bag, making sure the hose was NOT clogged, and replacing HEPA filter.
Most of the time on canister vacuums, the reason is caused by a clog in the hose, or somewhere in the powerhead. If you're sure that there is no clog anywhere, it is going to be the thermal switch on the motor.
Here's a link to the parts schematic for the Bosch upright vacuum. I hope it helps you in determining how to access the thermal switch. A word of warning to you before you try it, this is a very tough vacuum cleaner to work on, you may want to bring it in to a vacuum repair shop, as this is not an easy repair.
Here's the link;
http://www.essco.net/Customer/SchematicFrame.asp?FileName=Turbo%20jet%20upright.pdf
Please let me know if you have any other questions,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Posted on Aug 18, 2008
  • 389 Answers
SOURCE: Filters for panasonic vacuum cleaner MC-E468
Hi! Sometimes really hard to remember which of these models is which, so please forgive me if this is not a complete solution.  I'm pretty sure you will find there are two filters.  The first is a foam filter, and is located at the bottom of the bag compartment.  It pulls out to the front, and is washable (of course it must be completely dry before re-use).  The second (and here I'm on less secure ground) is a HEPA filter, and is located behind a removable panel on the front of the bag compartment door.  The HEPA filter is not washable, but rarely if ever needs to be changed unless the machine has been used for vacuuming a lot of extremely fine dust. I hope this helps, and I value your feedback. Please remember to rate my response.  Good luck!
Posted on Feb 24, 2009
johncaman
  • 201 Answers
SOURCE: filters on Kenmore Magic Blue vacuum cleaner
Yes, you do... only the 'motor protection filter' in the bag compartment is meant to be user cleaned.
Here's a manual, with a parts diagram near the end, if it's of use.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0408631.pdf
Please rate if this helps :)
Posted on Mar 05, 2009
ukvacfan
  • 328 Answers
SOURCE: need to replace the belt on my bosch vacuum
If the Bosch model is the AV series or has the similar hose down the front, check the reset button just below the main slider power on control in the handle.
Posted on May 08, 2009
  • 8404 Answers
SOURCE: Motor Brush for older model Filter Queen
Is there a Johnstone Supply in your area? How about an ACE Hardware. A vacum repair place? Sewing machine repair place?
If you have the data, ACE or Johnstone should be able to help you. Don't discount other electrical supply places. You will not get help at a big box place.
When I Googled "Filter Queen parts", I found lots of places on the WWW. There must be something close to you.
Give it a try. Let me know if this works for you.
a
Posted on Sep 21, 2009
Hi , I am looking for a Vacuum bag and filter for my Rowenta Vacuum cleaner Model number:RO1767R1 Type: VC20PE3 Ref. number : RO1767R1/4QO-3312R.
Here's one source for the ZR0039 01 paper bag and microfilter for the RO1767R1 compact canister vacuum: https://www.alza.co.uk/rowenta-zr003901-d308208.htm?catid=18850976 . This is a 6 pack of the bags. This vendor also has the Wonder Bag for this model: https://www.alza.co.uk/rowenta-compact-wb305140-wonderbag-d308211.htm?catid=18850976 . I can't find a source for the HEPA filter version (ZR0041 01).
This store has other locations. You can also find the vacuum bags here: https://www.alzashop.com/rowenta-zr003901-d308208.htm?catid=18850976 .
I hope this helps.
Jun 03, 2016 | Rowenta Vacuums
Tip
Fed up having to buy new filters for your vacuum?
Over the years I've lost count of how many companies stop selling replacement filters for their long deceased production vacuum models or that filter replacements are becoming increasingly difficult to source. There are usually universal "microfilter" replacements which are easy enough to find and cut to size, but if you can't be bothered to do that, there are ways around to renew your existing filter even if the manufacturer or the user manual states that the filter cannot be washed.
You see, any filter can actually be washed - if it is a single cloth filter - as opposed to a micro pleated section of many layers sewn together. If you have such a filter, a single cloth filter which the user manual says cannot be washed, this is a blatant lie. Remove the motor filter as normal (usually found at the bottom where the paper bag goes) if it is embedded with dirt and wash under a hot tap of water with either household washing up liquid or soap. Once the filter has been completely cleaned, place the filter into a pillow case and chuck into an electric dryer on a low heat. Instead of waiting 24 hours normally for a filter to dry to room temperature, you'll cut your waiting time by a day simply by allowing the gentle heat from the electric dryer to circulate around the pillow case which holds your vacuum cleaner filter. Once the filter is completely dry to the touch and does not feel damp in any way, install back into the vacuum cleaner.
I have also done this with HEPA paper filters which apparently are not washable according to the manual, and to stop the plastic cartridges from bouncing off the walls of your electric clothing dryer/tumble dryer put an extra towel or cloth into the pillow case to minimise damage. What is then revealed is a new, dry and clean filter which can be used again instead of spending lots of money trying to source a new one.
At the same time, if your vacuum cleaner has a soft bag, take it off and put it into the washing machine to give it a clean lease of life - but you won't need to put it into a pillow case to dry in the electric dryer - simply chuck the bag in to ensure it gets dried properly before putting it back onto your vacuum cleaner.
on Nov 16, 2007 | Sebo Automatic X1 Bagged Upright Vacuum
Why has the vacuum cleaner lost power?
If by power loss you mean loss of suction power then I would check and either clean or replace ALL of the filters. Check and clean the rotating brushes and make sure all of the tubes are clear. Almost all suction loss is down to some form of blockage to the air passing through the cleaner and unless the air can pass freely through and exhaust properly, it will not pick up efficiently.
Jan 01, 2016 | Bosch Vacuums
I want to know WHY my HEPA filter and cover blow off my unit with force each time I turn the unit on and start sweeping...Help?
Vacuum cleaners actually blow air through the filtration system. Over time particles will block the pores in the filter which doesn't allow enough air to pass through it and pressure will build up behind the filter and has to go 'somewhere'. Either clean the filter or replace it, and be certain to properly reinstall the assembly before turning it on.
Jun 13, 2014 | Shark Navigator Lift-Away Professional...
I can't get replacement bags for my Bosch Premium 1300 W vacuum cleaner.
Greetings from GoVacuum,
Your Bosch Premium canister vacuum cleaner uses Bosch Style P Bags.
We carry 2 different types of Bosch Type G bags for your vacuum cleaner.
We have the genuine Bosch Bags Available for Purchase Here;
Bosch Type P MEGAfilt™ Super TEX Vacuum Cleaner Bags
And also in bulk buy here;
3 Pack Bundle Pack of Bosch Style P Vacuum Cleaner Bags Part #BBZ52AFP2U
And we also carry a generic paper style bag that doesn't filter as well as the cloth Bosch genuine bags, but is suitable if you don't have any breathing issues or allergies in your home. Here are the Bosch generic P bags;
Bosch Type "P" Canister Vacuum Bags Generic
I hope that this information was helpful to you. If this helped you, please be sure to rate this as helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of my answer.
Feel free to email me at chris.jones@govacuum.com if you have any questions or need further help with your Bosch canister vacuum.
Thank you so much,
Chris Jones
GoVacuum.com
Feb 22, 2010 | Bosch BSG81313UC Premium Bagged Canister...
Filter queen masjestic vacuum cleaner has a light that should light up when the filter needs changing, it doesnt want to light up. I dont think its burnt.
That is a overhead light not a filter light. If your waiting for the light to come on before changing your filter or haveing the vacuum serviced your going to kill it. Every time you empty the container you should replace your white filter come and ONLY use genuine filter queen cones the aftermarket cheap-os will burn up your vacuum.
Aug 10, 2009 | Bosch Vacuums
Bosch Vacuum Cleaner: I changed bag. Cleaned out all suction hose and hepa filters, however, my 1450 w 12 amp upright vacuum cleaner will die after five minute run - overheating. Please advise.
Here's the link;
Chris Jones
GoVacuum.com
1-866-468-2288
Aug 16, 2008 | Bosch Vacuums
Vacuums Logo
89 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
