Question about Amana AOCS3040 Electric Single Oven
Amana Electric Oven Issue
I have an amana electric oven (only 4 years old). For some reason when i set it to bake, the oven never reached the desired temperature. Yet I can put it on clean and the heat generated off the oven seemed to be normal when I set it to clean.
Do you have ANY idea of what this could possibly be? I'm not sure if the model I selected is the correct one.
Thanks
  • soluvly Oct 31, 2008
    The model number for the oven is aer5715qaq
  • soluvly Nov 10, 2008
    My problem turned out to be a faulty baking element. We found one for 37.00 and my husband put it in. Now it works just fine. The old element had a section in it that looked like it had been cut. So we are happy now.
My oven never reaches the proper temperature sitting for baking. Controls for the oven only is push buttons. How can I adjust this. This has been going on since I have bought the Amana
Posted on Nov 08, 2008
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
Amana oven doesn't heat
IS it gas or electric? If it's gas, you may need to have a technician regulate the air and gas. If it's electric your t-stat may need to be replaced. Hope this helps! :>)!
Aug 14, 2009 | Ovens
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Oven heats unevenly and does not hold temperature
Can you replace the elements?
May 12, 2017 | Ovens
Amana Convection Wall Oven Model AOCS3040 Does Not Heat in any Mode
sure its possible, sounds like you've blown an over limit thermostat behind stove, gets too hot and for safety reasons cuts off unit untill replaced
Feb 11, 2008 | Amana AOCS3040 Electric Single Oven
Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Amana AOCS3040 Electric Single Oven Logo
351 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
john mabry
Are you an Amana Oven Expert? Answer questions, earn points and help others
