KENWOOD KR-V8030 SPECS
OUTPUT IN WATTS PER CHANNEL RMS
I have had this exact Receiver and this is taken right from the specs. in the manual, "120 watts per channel RMS" at 8 ohms - this is in Stereo mode (2 speakers) only". When surround sound is used, "75 watts RMS for Front and Center speakers and 15 watts RMS for rear (surround) speakers. From experience, the Stereo only mode is definitely stronger/louder than when switching to Surround. Most newer receivers are the same wattage regardless of mode.
Posted on Apr 03, 2014
3 Suggested Answers
SOURCE: I want to find out
I have the same receiver. When I asked the same question at a stereo store about 12 years ago, I was told it was listed at 55 watts/channel.
Posted on Mar 14, 2010
  • 35 Answers
SOURCE: I WAS GIVEN A KENWOOD STEREO VIDEO RECIEVER
From the info I looked at it appears to be 110 watts per channel at 8 ohms.
Posted on Jun 20, 2010
Having trouble under standing rms with speakers. Some speakers rms is per speaker and other are for both speakers.I am looking for soundstream speakers that would be 150 rms per speaker. Thanks
rms is a method of measuring power (wattage) delivered from an amp to a speaker. In almost every case, wattage capacity of speakers is quoted PER SPEAKER. Likewise wattage output is quoted per amp output channel. Assuming a you plan on a single speaker on each output channel of your amp, you should be in good shape if your speaker wattage capacity equals or exceeds your amp's output rating. I've never seen speakers rated as wattage per pair.
(rms is the dominant way of measuring average watts of an ac sine wave signal)
Apr 23, 2017 | Car Audio & Video
What is the wattage per channel on a Kenwood receiver KSR-A5030
The power output is 60 watts per channel RMS into 8 Ohms.
Oct 01, 2014 | Kenwood Audio Players & Recorders
What is the actual watts per channel @ 8-ohms and 4-ohms on the Behringer PMP3000?
Those specs would be right - I have this same board but the amp was fried by a previous owner. I pulled the amp board out and tossed it and use the mixer now to drive an external amp. Great board. This amp is rated at 1200W "peak", bridged into an 8ohm load. That would equate to about 900W RMS bridged into 8ohm or 450 per side into 4ohm loads per side. You can't daisy chain all 4 speakers....impedance would be too low. You can run two of your 8ohm speakers per side - that results in a 4ohm load per side for the amp. That would give you amp delivery of 450W per side. Your speakers are rated to handle more than that so you're fine. For the record.....you could run one speaker per side no problem....just lower power output.
Aug 16, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
What is the total WATT output on the Sony MHC-G101 mini hi-fi 3 CD changer, dual cassette home component system? I misplaced the owner's manual, and I want to know how much power it has. // Tks
According to page 24 of the manual, it delivers 11 Watts RMS (route mean squared) per channel into 8 ohm speakers.
Elsewhere in the manual, you'll see references to "15 watts per channel" and as much as "25 watts per channel". The 15 watt value is valid when putting up with some 10% THD (total harmonic distortion), this value is 11 times higher than the .9% THD value given for 11 watts per channel. You tolerate .9% THD now, but you wouldn't want to listen to anything with 10% THD. The 25 watts per channel is what they call "Music Power". Watts is an electrical term, "music power" is not. You could use it to compare other devices that only offer "music power" values, but the best indication of how it will perform is based on watts in RMS, into an 8 Ohm load (most speakers are 8 ohms). The lowest THD values are best.
From the manual:
AUDIO POWER SPECIFICATIONS
POWER OUTPUT AND TOTAL HARMONIC
DISTORTION:
With 8 ohm loads, both channels driven, from
70 - 20,000 Hz; rated 11 watts per channel
minimum RMS power, with no more than
0.9% total harmonic distortion from 250
milliwatts to rated output.
I hope this helped!
Nov 23, 2010 | Sony MHC-G101 Shelf System
What is the output of the 451s rms power
Dynamic Power Rating (measured at 14.4V):
  • Bridged Into A 4-Ohm Load: 450 watts x 1
  • Per Channel Into A 2-Ohm Load: 225 watts x 2
  • Per Channel Into A 4-Ohm Load: 115 watts x 2
Apr 14, 2010 | Rockford Fosgate Punch 401S Car Audio...
How many total watts does this system have
Well... It consumes 240 watts of electrical power total so take the audio power specifications with a huge grain of salt, as no audio device puts out in audio power anywhere near what it consumes in electrical power. Heat produced is power consumed, too and nothing is 100% efficient.
In the specs below the only information useful for comparison is in the line I highlighted with >>> <<<<'s as it conforms the closest to the industry standard practice of using:
"X watts into 8 ohms (standard load) from 20 - 20000 hz plus or minus Y db at no more than .0Z% distortion"
The better amps specify vanishingly low distortion specs (0.0x% vs 0.x%) at the cost of being able to claim higher wattage. But they guarantee cleaner sound at the claimed levels.
JVC is being tricky with their choice of a 40 hz lower limit. THAT is the power hungry end of the spectrum. 20 hz is normally the lower limit stated.
"Output Power .............At Stereo operation
Front channels .............55 watts per channel, min. RMS, driven into 4 ohms at 1 kHz, with no more than 0.9 % total harmonic distortion. (IEC268-3/DIN) 30 watts per channel, min. RMS, driven into 8 ohms at 1 kHz, with no more than 0.9 % total harmonic distortion. (IEC268-3/DIN)
>>>>> 30 watts per channel, min. RMS, driven into 8 ohms, 40 Hz to 20 kHz, with no more than 0.8 % total harmonic distortion. <<<<<
At Surround operation
Front channels .............50 watts per channel, min. RMS, driven into 8 ohms at 1 kHz, with no more than 0.8 % total harmonic distortion.
Center channel .............50 watts, min. RMS, driven into 8 ohms at 1 kHz, with no more than 0.8 % total harmonic distortion.
Rear channel .................50 watts, min. RMS, driven into 8 ohms at 1kHz, with no more than 0.8 % total harmonic distortion."
Mar 02, 2010 | JVC RX-554V Receiver
Power output
2 x 75 watts RMS per channel (2 x 100 watts peak)
150 watts RMS bridged into a 4 ohm load
Jan 03, 2010 | Jensen LXA300 Car Audio Amplifier
Hi i have two 10'' jenson xs sub and they are about 6 years old and i was wondering wut amp size i should buy to run them.
I believe these are 4ohms, if so buy a 2ohm stable monoblock amp, that puts out 250-300 watts RMS, and connect your subs to it in parallel, don't pay attention to peak watts, look at RMS watts, or continuous watts. If they're 2 ohms, buy a 2 ohm stable 2 channel amp that puts out 125-150 watts RMS per channel, and 250-300 watts total or bridged RMS output. And connect them normally, on sub per channel... hope this helps, as far as brand recommendations, MTX, pioneer, Alpine, Kenwood... Good luck
Sep 20, 2009 | Jensen XS-1010 Car Subwoofer
607 people viewed this question
 Grubhead
Grubhead
