Question about Kitchen Appliances - Others
Where can I purchase a spout filter for breville jk123
Plastic spout filter
2 Suggested Answers
SOURCE: filter for breville kettle jk155
Contact Breville on 0161 652 1211 and they will mail out one
Posted on Feb 26, 2009
The GE GFWH2400LOWW I own won't drain.
Could be something lodged in the pump
Jan 03, 2014 | GE GFWH2400LWW Washer
I am trying to replace an old delta monitor 1300 diverter spout. It seems when I take off the spout it has a threaded part in the middle of copper pipe . The spout itself has a plasticinsert with threads....
Tub spouts are pretty much interchangeable although you may find the replacement spout cannot be installed easily because the threaded copper stub does not extend far enough to engage the threads inside the spout.
Nov 28, 2013 | Delta Faucet Delta T13422 13 Series...
Young living aria diffuser not misting
I am having the same problem. I have no misting at all, only music and colors. I am going to try moving the glass spout so it's opposite the plastic spout--i read that somewhere. I'm also going to start over again with filtered water. I had gotten into the habit of just reflilling and adding more oils. hope this works and helps you too!!
Nov 27, 2012 | Young Living Aria Ultrasonic Diffuser
When lever on tub spout is pulled up for shower use some hot water still comes out of the tub spout...reducing water pressure and temperature of water coming out of the shower head... Tub spout does NOT...
2 things can be happing here depending on the age of the tub spout. If the spout is more than 5 years old, you may need to replace it. if not that old then you may have a screen filter blockage in the shower head itself. remove the shower head from the shower neck and see if there is anything in the filter. while you have the head removed, try the tub spout again and see if problem continues. this should guide you in the next step to either replace the tub spout or just clean the shower head screen filter. Hope this helps.
Dec 29, 2010 | Cifial 295.604.625.SO Polished Chrome...
I have a Delta shower assembly with a pull-down diverter. When I engage the diverter for the shower, half the water seems to make up to the shower and the other half is forced through the back of the...
One of 2 things is happening. Either the o-ring is shot, or you have a hairline fracture of the plastic around the brass adapter. The o-ring is a #18, but if there's a crack in the plastic you'll need to replace the spout.
Oct 03, 2010 | Delta Faucet Delta RP17453 Pull-Down...
The water from the dispenser tastes like plastic. Could it be the filter and where is it located?
If there is an inline filter, replace it. They have carbon in them, which loses its effectiveness in a relatively short time. Most people go way too long without replacing the filter. Ideally you should replace it at least once every 6 months.
Whether there is a filter or not, dump the ice, and let the water on the door run for 30 minutes. You could put a little piece of flexible tubing on the spout and put a bucket on the floor. You can buy the tubing at about any hardware or building supply. Usually, a 3/8 od, 1/4 id clear tubing will fit on the spout. But sometimes you would need a 1/2 od x 3/8 id. It is real cheap. Otherwise you can stand there with a cup for half an hour.
Nov 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
American Standard Colony Soft gooseneck kitchen faucet leaks base
at the spout near the base is an echeion ring. turn this counterclock wise then pull up ring to expose the neck,pull spout straight up.this echeion cap holds on the spout to the base there are plastic parts inside so be careful when pulling apart.
Jul 13, 2009 | American Standard 4275.550.002 ColonySoft...
No water from water spout
See if there is a sediment screen at the inlet to the filter from the faucet and see if it's obstructed or clogged. Obviously, make sure you are using the correct filter cartridge and that the filter discharge is also clean.
Mar 22, 2009 | Hotpoint HSS25GFP Side by Side...
Shower spout
There is a threaded stem that passes through the spout and attaches to the white plastic diveter valve. If you are starting from scratch (everything apart), you can put it back together in this order:
1) Place the white plastic diverter inside the spout. the circular side with the black round washer should face the the wall side of the shower (mating up against the threads for the water pipe).
2) The stem can now be inserted from the top and into the notched section of the white plastic diverter valve. The threaded end of the stem shoud be outside of the spout (from the top side).
3) A round black washer fits over the threads. It should sit right where the threads end. Dont push it all the way on to the unthreaded portion of the stem.
4) Screw the threaded knob onto the threads.
Should be ready to install now. Including the spout itself, there are 5 parts and are configured in this order from top to bottom.
1) Female threaded knob (the knob for operating the spout)
2) Threaded stem (threads on top)
3) Round black washer
4) Spout
5) Whit plastic diverter valve.
Mine leaks when I turn on the shower, thus reducing shower pressure. I looks like a poor design to me. The stem is not a tight fit in the spout and this allows the diverter to "wobble". The washer on the diverter valve does not seat tightly and allows water to leak out the tub spout when showering. I would replace the spout.
Jan 30, 2009 | Price Pfister 01-311 Shower Head, Tub...
Kitchen Appliances - Others Logo
48 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
