Question about Acer Computers & Internet
Bad ntkrn1pa.exe file
I have a boot file error in windows/system32/ntkrn1pa.exe and do not have a repair disk
hughv
  • 196 Answers
SOURCE: startup problem
From: http://www.computerhope.com/issues/ch000646.htm If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps. 1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue. 2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key. 3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console. 4. Select the operating system you wish to fix, and then enter the administrator password. 5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32 6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file. 7. Type exit to reboot the computer. If you only have a restore CD, this probably won't work. You should just start the restore all over again, if this is the case.
Posted on Jun 05, 2007
hughv
  • 196 Answers
SOURCE: error 0000218 cannot load the hive; \SystemRoot\System32\Config\Software
Try System Repair:
http://www.techspot.com/vb/topic8356.html
Posted on Dec 21, 2007
s2dak_jr
  • 42 Answers
SOURCE: boot up issues
The only solution to your problem is to consult a nearby repair shop. They have all kinds of CDs needed to bring your computer back to life.
Cheers................
Posted on Jan 18, 2008
kyo_ajis
  • 68 Answers
SOURCE: hijack taskmanag and hijack regedit removing
to repair it you need to install autorun eater.
download here: http://www.softpedia.com/get/Security/Secure-cleaning/Autorun-Eater.shtml
install and it will scan.
also suggested to install avira, bitdefender or mcafee(trial also work).
after install.
restart: press f8 you will enter safe mood. in the safe mood you will see a icon on your taskbar name by mcdonald(the autorun eater software. right click and selct repair task manager, right click again selecr repair regedit and do the same thing select repair folder option.
after that wait untill about 30 minutes(autorun eater to finish scan)
to repair other like no desktop icon download the repair utilities here:
http://www.kellys-korner-xp.com/taskbarplus!.htm
Posted on Jan 27, 2009
  • 56 Answers
SOURCE: 0XC00000E9
try cleaning your Cd.
Failing that you could borrow an operating system disk to get windows up and running and then get all the drivers etc from your restore disks
Posted on Mar 09, 2009
HP Color Laserjet 5550dn printer connected in network configured through server, showing error 0xc0000005 while clicking on printer properties in any client system?
You have hacked or infected files on your computer.
Check your BCD and do the below fix if necessary (at your own risk)
In Windows open CMD as Administrator and type BCDEdit and enter, if your Windows Boot Loader Path is xOsload.exe then you need to remove some files and repair your BCD.
NOTE: you will need to re-activate Windows afterwards, so make sure you have your Windows 7 key handy.
Boot to Windows Repair - Command
Del D:\Windows\System32\xOsload.exe
Del D:\Windows\System32\xNtKrnl.exe
Del D:\Windows\System32\Drivers\oem-drv64.sys
attrib c:\boot\bcd -h -r -s
ren c:\boot\bcd bcd.old
bootrec /rebuildbcd
Oct 14, 2016 | HP Office Equipment & Supplies
How can i reinstall the ntoskrnl.exe when it is corrupt
Assuming a couple of things:
1. Your OS is Windows XP
2. This is the error message you are getting -
"Windows NT could not start because the following file is missing or corrupt:
Winnt_root\System32\Ntoskrnl.exe
Please re-install a copy of the above file."
To reinstall notskrnl.exe, do this:
  • Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
  • After the setup files are finished loading press R to repair using Recovery Console.
  • When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
  • Login to the Administrator account by typing the password for this account, and then press ENTER.
  • At the recovery console command prompt, type the following command, and then press ENTER:
    For Uni-Processor systems: expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
    For Multi-Processor systems:expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
    Note In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
  • If you receive a prompt to overwrite the file, press Y.
  • Type exit, and press ENTER at the command prompt.
  • You should now be able to boot up properly.
  • Oct 14, 2013 | Dell LATITUDE Computers & Internet
    HAL.DLL is missing or corrupted, xp doesn't boot
    if it was running for more than 30 hours, it wasn't doing much. You can try copying hal.dll off of a known, good-working XP pc, and replace it with the one on your broken PC. It's better if you extract it from i386 folder but grabbing it from another pc should work fine.
    Aug 09, 2012 | Microsoft Windows XP Professional
    Hijack taskmanag and hijack regedit removing
    after install.
    Jan 27, 2009 | Dell Latitude D600 Notebook
    I have deleted svchost.exe from windows xp
    To complete part one, follow these steps:
    1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
      Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
    2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
    3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
    4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
    5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
      copy c:\windows\system32\config\system c:\windows\tmp\system.bak
      copy c:\windows\system32\config\software c:\windows\tmp\software.bak
      copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
      copy c:\windows\system32\config\security c:\windows\tmp\security.bak
      copy c:\windows\system32\config\default c:\windows\tmp\default.bak
      delete c:\windows\system32\config\system
      delete c:\windows\system32\config\software
      delete c:\windows\system32\config\sam
      delete c:\windows\system32\config\security
      delete c:\windows\system32\config\default
      copy c:\windows\repair\system c:\windows\system32\config\system
      copy c:\windows\repair\software c:\windows\system32\config\software
      copy c:\windows\repair\sam c:\windows\system32\config\sam
      copy c:\windows\repair\security c:\windows\system32\config\security
      copy c:\windows\repair\default c:\windows\system32\config\default
    6. Type exit to quit Recovery Console. Your computer will restart.
    Dec 02, 2008 | Microsoft Windows XP Home Edition
    Error: windows root>\system32\ntoskrnl.exe
    Issue: NTOSKRNL.EXE is missing or corrupt.
    Related errors:
    Below is a listing of the full error message that may be related to this error.
    Windows NT could not start because the below file is missing or corrupt:
    C:\Winnt\System32\Ntoskrnl.exe
    Cause:
    1. Keyboard issue
    2. Miscellaneous corruption
    3. Corrupt boot.ini file.
    4. Missing boot.ini file.
    5. Missing or corrupt ntoskrnl.exe file.
    6. Windows NT installed on a partition bigger then 7.8GB
    7. Corrupted hard disk drive or severely corrupted Windows.
    Solution: Keyboard issue This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
    Miscellaneous corruption Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
    Corrupt boot.ini file This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer. Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
    Missing boot.ini file Microsoft Windows XP users: If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648. Microsoft Windows NT and Windows 2000 users: To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
    1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
    2. In the setup menu, type R to start the repair.
    3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
    Missing or corrupt ntoskrnl.exe file If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
    Windows NT installed on a partition bigger then 7.8GB If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below. OS Loader v4.01
    Disk I/O error status=00000001
    Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
    Please reinstall a copy of the above file. If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
    Corrupted hard disk drive or severely corrupted Windows Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
    5. Once at the recovery console type chkdsk /r
    6. Once completed type exit and see if issue is resolved.
    If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186. Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
    Oct 18, 2008 | Computers & Internet
    How do I...
    Related errors:
    Cause:
    Keyboard issue
    Solution:
    Keyboard issue
    OS Loader v4.01
    Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
    ACER DESKTOP COMPUTER
    Related errors:
    Cause:
    1. Keyboard issue
    best regards wish u give me a good rate ^^
    Aug 15, 2008 | Acer Computers & Internet
    Desktop Error Message
    Probably this is a spyware, use a good anti spyware or do the following:
    Run Process Explorer (right click on task bar>task manager>Processes) and Kill the Following Processes:
    wscript.exe
    dxdlg.exe (kill this one first)
    Run Autoruns and under logon tab, remove
    C:\WINDOWS\system32\wscript.exe C:\WINDOWS\system32\boot.vbs
    Search for entries named wproxp and remove it
    Remove the following files from your PC:
    C:\WINDOWS\system32\dxdlg.exe
    wproxp.exe (Most probably in your system32 or windows folder)
    Jul 06, 2008 | Computers & Internet
    Computers & Internet Logo
    165 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
