Question about Makita Saws
Where can i buy a new drive belt for my Nutool 0134A Bandsaw ?
New Orange Drive Belt
4 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: Looking for the var-speed drive belt for a
Have you tried these folks? Here's a site where you can download a manual, and somebody at the discussion forums there might have a better idea for the belt...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 05, 2009
  • 4088 Answers
SOURCE: how do I remove drive belt on 10
Loosen the motor mounting bolts and slide the motor forward until the belt is slack. When you replace the belt, slide the motor back until the belt is firm, but has about 1/2 " movement up and down at midpoint between pulleys. Recheck after tightening the motor.
Posted on Feb 13, 2010
  • 4088 Answers
SOURCE: Will Delta Belt fit Mastercraft Band Saw
If you still have the old belt, take it to a well equipped hardware or auto parts store for a replacement. If the previous belt is missing, you will need to measure the pulley 'V' width at the top of the 'V', the center to center measurement of the two shafts, and the outer diameters of the two pulleys. Hope this helps!
Posted on Jun 25, 2010
Nutool belt sander, how do l tighten up the sanding belt as it keeps on slipping off to the side? Terry
the belt will be tight but the front wheel needs realigning with the drive pulley
there is a small lever of adjuster screw on the side that by moving it when the belt running you can get the belt back to run in the correct position
Jun 09, 2017 | Tools & Hardware - Others
I have a very old Nutool NTG6L which is a combined grinder and 2" belt sander. Is it still possible to buy new sanding belts for this machine or is it too old?
I suggest doing a search on eBay. Depending on where you live, you may need to find them in another country. A Google search might help first but I found these on eBay Ireland.
2 Pack Of 3 Sanding Belts Nutool Nu Tool NTG6L 6130 Bench Sander
Nov 29, 2014 | Tools & Hardware - Others
How to replace the drive belt on a RIKON10-320 Bandsaw?
Check your manual. If you don't have, go to bandsawmanuals.com and see if they have the manual for your band saw. Replacing drive belt is easy, the same process on how you install belt on other saws. I saw a video on youtube about, I suggest you watch band saw videos.
Sep 01, 2014 | Saws
Drive belt replacement
Sometimes, its due to quality problem. Well, not quire sure if www.bandsawparts.com
have the drive belt that you are looking for. You may try to give them a call .
Dec 18, 2012 | Rikon 14" Bandsaw Model 10-320
Where can i find a drive belt for bandsaw 28560
You should be able to get a belt at Woodcraft or order it on line from them. I would recoment this belt.
Reduce vibration in any of your belt driven machines with the Power Twist Link Belt!
Jul 21, 2011 | Delta Saws
Apr 15, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
The belt p/n 0100623 broke - need instructions on how to replace it - we have Bissell ProHeat Powersteamer
I just replaced mine last night. 1) take off the top belt cover. 2) take the water and cleaning solution tanks out then lay the unit on the side so the bottom of the cleaner is facing you (water and solution may leak out so you might want to do this on an old towel). 3) On the same side of the machine as the belt cover but on the bottom you'll see an orange piece (at least it is on mine) that is held in with one philips screw. Take the screw out then slide the orange plastic piece out (might need a pliers to help). 4) there is a black cover over the brush belt that has a tab on it. Pull on the tab and the brush roller on that side will come out of its place. 5) You'll see a cogged belt that drives the brushes. Just slip that off the drive on the machine. You don't need to take it out completely - just off the drive. 6) Slip the new belt (p/n 0100623) in and on to drive. It goes "inside" of where the cogged belt goes. 7) Slip the cogged brush belt back on. 8) push the brush roller and black belt cover back into position. 9) slide the orange plastic piece in place (make sure the belt cover is held in place by it) and screw it back on. 10) flip the cleaner so it is on its wheels again. 11) pull the new belt over the metal drive and manually get it kind of centered. Make sure it isn't touching any protruding plastic. 12) plug in the cleaner and quickly turn it on and off while looking at the new belt. You should see it self center. 13) put the top belt cover back on 14) insert water and cleaner tanks. 15) get to work.
It'll take less than 10 minutes to make this fix (less than 5 probably).
Jun 19, 2008 | Bissell Vacuums
Broken transmission belt
Hi There, Is it the main drive belts from the motor to the tech drive? If it is the are very easy to replace by taking out the tech drive. If it's a belt inside the tech drive unit you will not be able to buy the belts anyway as they are classed from kirby as a sealed unit. Hope this helps Chris www.elidistribution.co.uk
Aug 26, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Saws Logo
311 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
