Question about Kenmore Elite 45986 Front Load Washer
Dishwasher wont fill up but can hear the motor....
Do you know how to fix this>
The light is on but wont fill with water was alright yesterday
Posted on Nov 03, 2008
  • fiver1234 Nov 03, 2008
    were is the fill valve
    Sergeant:
    Champion:
  • 324 Answers
Dishwasher? could be the fill valve bad. or the float switch is stuck in the up position.
MY DISHWASHER WONT KICK INTO WASH CYCLE CAN HEAR THAT IT WANTS TO BUT DOESN'T ..IT WILL FILL AND DRAIN AND DRY...CHECKED DRAIN AND FILTER CLEAR
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump.
First though, do you hear a quiet sound of a motor starting once the unit has completed filling with water ?
( it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Viking...built by "Asko"...are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver )
If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely.
This unfortunately is common with Asko built dishwasher`s and it is a case of being a victim of their own design.
What happens typically is the ball-bearings from the upper rack holders ( which are plastic which fatigues due to heat and fall apart ) fall out making their way into the sump, hence breaking the wash impeller from the motor.
Let me know what you find and I'll try and help you move forward from there.
Good luck,
Macmarkus :)
Aug 26, 2010 | Viking 24 in. Professional Series VUD141...
My Asko dishwasher is not producing water
Hi, Welcome to FixYa. Based on your description that the dishwasher is indeed filling with water but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump. First though, do you hear a quiet sound ( it will be super quiet if the wash impeller is broke so you have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver ) of a motor once the unit has completed filling with water ? If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely. Let me know what you find and I'll try and help you move forward from there. Good luck, Macmarkus :)
Aug 02, 2010 | Asko D1796FI Built-in Dishwasher
Fdb126rbs2 fills and drains fine but does not
DO YOU HEAR THE MOTOR START OR HUM AFTER THE WATER FILLS? IF IT RUNS CLEAN YOUR FILTER AROUND THE BOTTOM OF THE LOWER SPRAY ARM INSIDE. LET ME KNOW IF YOU HAVE MORE INFO.
Apr 25, 2010 | Frigidaire 24 in. FDB126RB Built-in...
My dishwasher starts fills water and never starts wash cycle?
If you hear a hum when it should be washing, the motor has seized. Replace motor. If it fills with water and stops quite, run it through a test using the tech sheet under the bottom panel to access. These dishwasher have had issues with the motor.
Oct 09, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Dishwasher makes squeeling noise when filling with water
if the dishwasher is only filling when u hear the noise it could be a bad water valve or if you are lucky it could be the screen in your water valve is dirty, however if it is filling and washing at the same time and you hear a noise like sqeeling it could be your motor, before u replace the motor. check the water valve or screen on valve may be dirty
Sep 16, 2009 | Frigidaire 24 in. GLD2350RC Energy...
Dishwasher fills up and then stops
the cycle for all dishwashers is 1/pump out for approx ! minute 2/ fill. 3/circulation motor, so the problem is the motor is jammed(can you hear a humming sound? or the motor is faulty and will require replacing
Jul 08, 2009 | Dishwashers
Sprayers Will not work.
so what is the problem fills but wont spray
Dec 10, 2008 | Maytag MDB9600A Jetclean II Built-in...
Neff S4752
I had the same problem with mine. I ended up having to pull the dishwasher out from under the counter and tipped in on it's face. My problem was apparently with the pump motor. It would come on, and I knew this because I could hear the hum. Well when I pulled the dishwasher out from the counter I noticed the motor was extremely hot, which to me says there was a block in the pump's way. I pulled the motor by loosening the set screw, 10mm with a 1/4in socket wrench and extension, which is located on top of the motor. First you have to disconnect the power by squeezing the tabs together and pulling upward. After that a quarter turn counterclockwise will unlock the motor. Pull the motor back and check the screens and impeller. I cleaned the screens and manually turned the impeller. Put it back together by doing the steps in reverse, clean up any spilled water thoroughly before plugging it back in and re-plumbing. That solved my problem, good luck.
May 09, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kenmore dishwasher
whatlight are on ?does waterneter and then just quit? do you hear the motor humming?
Feb 22, 2008 | Dishwashers
Kenmore Elite 45986 Front Load Washer Logo
Ron Lankford
Archaeology
Archaeology
reliableservice
