Question about Bissell 9400 ProHeat Upright Wet/Dry Vacuum
Micro switch Bissell 9400 brush won't turn
Where is the microswitch located? brushes won't turn
CompuGuy44
  • 432 Answers
SOURCE: Bissell Velocity Vacuum brushes stopped
The brush bearings wear out on these things. I know I replaced mine twice before buying new carpet. I've had it for 10 years,
You can order these parts on the Bissell website:
http://www.bissell.com/Products/p/CleanView+Brush/product.aspx
http://www.bissell.com/Products/ak/replacementparts/p/CVPT+II/product.aspx?%23=Detail#Detail
http://www.bissell.com/images/UserGuides/35934_804.pdf
Posted on Mar 30, 2008
SOURCE: brushes do not turn
You should see if the brush belt is broken. I broke mine you can find the part at walmart or on bissell.com
Posted on Sep 02, 2008
SOURCE: brush will not turn
Possible Solution: I had the same problem with my Powerforce vacuum. Please take note that I AM NOT a vacuum cleaner repairman, nor have I played one on TV. Try taking your beater bar out, and if it looks similar to the one pictured (Model#203-1195), get a cresent wrench. Look at the end of the beater bar one will be squared on the sides to hold the shaft inside statonary. Take the wrench and adjust it to fit the nub on that end. Grab the bar in the center, and turn the end with the wrench. Mine popped and came loose, then it could be turned by hand. A little light oil allowed to run into the end cap, turn it up and spin it a few times to let the oil work down the inside and put it back on. Mine works fine for now. Good Luck!!
Posted on Mar 16, 2009
  • 29 Answers
SOURCE: bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
Posted on May 29, 2009
heatman101
  • 43501 Answers
SOURCE: MY BISSELL PROHEAT WONT SUCTION
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ffuutr
Posted on Sep 30, 2010
I replaced both belts and still the brushes won't turn
Hello, this is Ava with Think Crucial.
You may need to clean your roller brush first and try to see if this would resolve the issue. If not, then most likely your roller brush needs to be replaced.
You may order replacement parts for your Bissell directly to us. This is our Bissell replacement parts: http://www.thinkcrucial.com/collections/vacuums/collection-filter-fits-vacuum-bissell
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Oct 11, 2016 | Bissell Brushroll Proheat 2X 8920 9200...
Troubleshooting
Hi Janet. Thank you for asking this question. Your vacuum wasn't designed with a brush on/off switch so having the brush continually spin is normal for your vacuum.
Jun 29, 2013 | Bissell 3576 CleanView II Bagless Upright...
Bissell bagless 6583 brush won't turn after new belt
Sorry to hear about the difficulty with the brush. If your brush does not turn by hand freely, then your brush needs to be replaced.
Here is a quick link to order a new brush:
http://www.bissell.com/parts/?id=9143&sc=part&partid=17048&cid=ccsocial
Mar 20, 2013 | Vacuums
Bissell powerforce brush won't turn when powered
Hey, you may want to have check if the brush turns by hand without the belt in place. If the brush doesn't turn manually, you'll need to replace the brush.
Here's a quick link to the BISSELL website to assist you.
http://www.bissell.com/default.aspx?cid=ccsocial
Feb 12, 2013 | Vacuums
Water won't stop spraying water 9400 bissell
Hey, you may want to have a Qualified Technician at a BISSELL Authorized Service Center inspect your machine.
Here's a quick link to locating one of our Authorized Service Centers in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 27, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
The brushes on my Bissell 9200 have stop rotating. The microswitch near the wheel seems to be OK. How can I troubleshoot the problem?
If the belt is still OK and you can turn the brush by hand (make sure the power is off when you try) then there is only the drive motor and the power switch left in the circuit. Bissell's are very simple machines and you can easily remove the topc over with about 6 screws so you can get at the insides and spares are easily obtained.
www.bissell.com
Sep 29, 2009 | Bissell 9200 Upright Vacuum
Brushes not turning on 8920 2x Bissell
Brushes are switched on by lowering the handle which activates a micro-switch located inside the lower part of the machine. Vacuum must be running as well. The DC power for the brush motor comes from a Bridge rectifier located on the PC board located in the handle. I have drawings that might help you.
petedcurtis@gmail.com
Nov 26, 2008 | Bissell 8910 ProHeat Clear View Upright...
Brushes do not turn
Sep 02, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell 9400 Carpet Cleaner
I assume you checked the belts to see if any cogs were stripped of of the belt. If ok, then I wuld suspect the brush roll motor, it is any inexpensive part and doesn't take much for it to fail. Undo the top so you can get to it and unhook the belt and see if it still shuts of, if it does, ten replace it, it it doesn't, then there is a problem with brush rolls or belts.
May 13, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Bissell 9400 ProHeat Upright Wet/Dry Vacuum Logo
139 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
