Question about Coffee Makers & Espresso Machines
Cuisinart burr grind and brew overflow - Coffee Makers & Espresso Machines
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart Grind and Brew will not emply all the water
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Posted on Sep 29, 2009
dutchman05
  • 487 Answers
SOURCE: Cuisinart Grind and Brew 10
the problem is your drip stop at the bottem of your filter holder.
Check that pls and let me know
Posted on Aug 17, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Posted on Dec 17, 2008
SOURCE: Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Posted on Jan 16, 2009
dougpopo
SOURCE: cuisinart burr grind and brew coffee maker
The hopper between the burr grinder and where coffee chutes into the filter is jammed with coffee powder...
First, take out the filter holder and carafe, and place a freash empty filter on the pot base to catch stuff.
Next, take out the beans holder and look for the release lever in the lower left section. Sliding it to the left slides open the door, where you'll probably find loads of powder. You can poke your finger through to get the majority, then use the cleaning brush to get it really clean.
Thanks what fixed mine! (I notice I have to do this about once every few months.)
Posted on Aug 03, 2009
I need instructional video for the Burr Grind&Brew 12C 900 seriesDGB
Here you go. this link should do the trick
www.wholelattelove.com/cuisinart-dgb-900-grind-brew-thermal-carafe-12-cup-automatic-coffee-maker/
Oct 03, 2017 | Coffee Makers & Espresso Machines
We have a Burr Grind & Brew 12-cup, programmable Cuisinart. Even with the vinegar solution, it seems to clog more than we expected. We have a water softener. Tired of making 8 cups and only getting 5...
you must physically remove the lime.
first remove the spray head and then brew the coffee in an empty waste container.
remove all the lime as much as you can.the hot water force the lime to go out .
IF YOU HAVE DELIMING SPRING THEN IT WILL WORK GREAT
thanks
please rate my work
Sep 05, 2011 | Cuisinart GRIND AND BREW COFFEE MAKER
Coffee does not go from grind to brew basket. Plugs..must clean every time
Try running some unflavored panko breadcrumbs or rice through it. That will clean it up and remove any oil that's causing sticking. Try to use less oily coffee in the future to avoid this.
Feb 03, 2010 | Cuisinart Supreme Grind DBM-8 Electric...
Dgb-900 series. Keeps making a snapping sound rather than brewing coffee
used a pointed bottle brush to go up the coffee grind channel to the
burr grinder and kept turning it until I could feel the burr move. A large
clump of compressed coffee beans came out. Have had no problem
since.
Nov 30, 2009 | Cuisinart Coffee Makers & Espresso...
Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart burr grind and brew coffee maker
Sep 09, 2008 | Cuisinart Supreme Grind DBM-8 Electric...
Coffee Makers & Espresso Machines Logo
1,067 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
