Question about SanDisk 4GB microSD High Capacity Memory Card
My 4gb sandisk sd card shows 30.1mb.please give me the right solution to recover it.
shbuckler
  • 126 Answers
SOURCE: Doesn't load
The reader may need re-iinstalling. or the port you are putting it in is incorrect,. try another stick to test the port or try the memory card in another PC to confirm the stick is OK
Posted on Dec 25, 2008
bunnydawg
  • 5158 Answers
SOURCE: my 4gb scan disc sd card wont format
http://www.sandisk.com/Retail/Default.aspx?CatID=1668
I believe sandisk makes a special program to format their cards
Robert
Posted on Jan 26, 2009
saqeb
  • 47 Answers
SOURCE: Can't format SanDisk 4GB SDHC Card
try to download HpFlash. and format your drive using that software. Your problem will be solved
Posted on Jan 27, 2009
SOURCE: I have a Samsung G600 and yesterday bought a
Did you format it?
Posted on Aug 03, 2009
  • 33 Answers
SOURCE: problem with the sandisk 4gb micro sd card. my
some comp cant read the card a cheap fix is go to radio shack and get a reader/writer card its a usb connnection and should work for it did for me even my printer couldn t read my 4 gb
Posted on Aug 10, 2009
Forgot my memory card pasword
To format your SD card you need the following SD card, SD memory card adapter, SD card reader on your P.C. first insert the memory card into card adapter, insert the adapter into the P.C, click start>my computer> Secure Digital (SD) card and then navigate into the folder named system folder, open the sub-folder MMCstore and you should be able to see your password and recover it, If you want to reset your password you should just format SD card by clicking start> right click on my computer and select manage> Disk management > go to your SD card, right click on it and select format and then start format.
Jan 10, 2013 | SanDisk 4GB microSDHC Memory Card
How to recover a 4GB Memory Stick vitual memory?
Files gone? What might suit you is 4Card Recovery. It can recover movies, music, pictures and other files very quickly.
How to Recover Photos Videos off SD Card after Formatting Unformat SD...
Jul 28, 2012 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
I want recover my photos in my 4GB SDHC Sandisk Memory Card
click start control panel administrative tools computer management disk management right click on your 4gb drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
i found best results tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
If you need more help with this post a reply
hope this helps you
May 07, 2012 | SanDisk 4GB Secure Digital High Capacity...
4gb card showing 30.1 mb unable to format
my sd card is of 2gb but its size is showing only 45.6 mb
please give me solution on sandip.955@live.com or on 9560709358
Nov 10, 2011 | SanDisk 4GB microSD High Capacity Memory...
SanDisk 2GB microSD Memory Card not working
SaveMyUsb.com can recover data from most flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 18, 2010 | SanDisk 2GB microSD Memory Card
Sandisk 2gb sd card unable to to format and shows 30.6mb.how to recover the data
Hi
Please follow these steps to recover the data from your memory card.
1. Go to http://www.recovermemorycards.com/
2. Download the software from the website.
3. Install it on your computer and recover the data from memory card
Jul 30, 2010 | SanDisk 2GB microSD Memory Card
Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
May 15, 2010 | Pentax Optio S50 Digital Camera
Sandisk SD memory card problem
same thing happened to me. I bought a program called search and rescue from Compusa and was able to recover all files and saved to my hard drive. Yes it does sometimes happen to memory cards. How it happened, not sure, but i recovered..good luck art
Mar 15, 2007 | SanDisk ULTRA II 4GB Compact Flash Card...
SanDisk 4GB microSD High Capacity Memory Card Logo
82 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
