Question about Home Security
My adt key fob does not work with my liftmaster garage door opener
Since installing the liftmaster 8550 garage door opener, my ADT key fob will no longer open the garage door.
  • 11 Answers
SOURCE: Sears Craftsman Garage Door Opener Wireless Keypad Model and a LiftMaster Chamberlain Professional Garage Door
I had the same frustrating dilemma with my Craftsman LiftMaster garage door and Keypad, Model 139.53754-01 (dated 10/06; and has the # 315 MHz).
To resolve “the dilemma”, grab your keypad, climb up on a ladder to access the garage door opener’s motor unit. On the right side of the motor unit, remove the white plastic casing by pressing buttons on each side and pulling down. This will expose the programming area, and for our purposes, the “Learn” button.
1. On the motor unit, press and release the “Learn” button. The Learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the ENTER button when the motor unit lights blink. The code has been “learned”/stored/activated.
Good Luck, and I Hope this Helps!
Gail
For possible future reference:
How to change an existing, known PIN
(Changing an existing PIN can be done with the wireless remote keypad, and does not require access of the motor unit.)
From the keypad:
1. Enter the four digits of the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
2. Enter your new 4-digit PIN and press Enter. The motor unit lights will blink once when the PIN has been “learned”/stored/activated. Test by entering the new PIN, and pressing Enter.
Posted on Jun 24, 2008
SOURCE: Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Posted on Jul 25, 2008
  • 25 Answers
SOURCE: change code on keypad for model 61WD liftmaster garage door opene
is it little buttons on the remote change the buttons on the back of your operator to the same has the ones inside your remote. or if it's a newer one you can hold the square button of the back of the operator in for 8 secs. then after that you push the button and let go and then push the button on your remote. done
Posted on Jun 11, 2009
  • 3197 Answers
SOURCE: I have a Liftmaster 1045-6 garage door opener. It
The first thing you should do is make sure it is plugged in and then plug a lamp into the socket to make sure you have power.
Posted on Jul 10, 2009
  • 3197 Answers
SOURCE: I have LiftMaster garage door model 41A3039 and
To program the keypad, first unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Posted on Jul 13, 2009
How do ADT alarm systems work?
ADT is the largest provider of the home security system. It is a well-known brand in the world and everyone knows about this company. It works that sensors are triggered, they send a signal to your security system control panel, which will alert your ADT monitoring station and there is the two sensor pieces are in contact with each other while the door/window is closed. When they are opened, the sensors separate and an alarm is triggered. It is the best home security provider company as other home security companies. I fixed home alarm system in my home from this company.
Feb 13, 2018 | Home Security
I have a home security system Simon 3 that was at one point under service with ADT. It is no longer has service with ADT. I like that it was notifying when the doors were opened, but the battery low...
Try powering down the system completely and powering it up with the battery first, that's how I do it. If the alarm goes off again you can try entering 2580. Be careful doing that! If for some reason that system is still be monitored you could end up with the police at your door. It might be a good idea to call ADT and give them your address just to confirm the system is no longer being monitored. Hope that helps!
Jan 08, 2015 | New Home Security
We had a burglary at home, pressed the panic button for the alarm to be sounded, this did not stop the thieves and we had no reaction from ADT. A Go-Cart and Trailer was stolen, and ADT refuse to settle...
Get a Moultrie trail camera put it where the thieves can't see it, in a tree or blue bird box with the front of box open, get them on camera, day or night, take ADT.off your place, big money racket. walmart has them for about 100.00 bucks, cheapest way to catch a crook. --Moultrie m80 gamespy --
Sep 30, 2013 | Telco Adt Security System, Cable And Conn...
Trying to reprogram my 387lm to my 8550 liftmaster
Its not compatible with an 8550 of it has a yellow learn button....you will need to locate an 877max lm keypad
Apr 11, 2013 | Chamberlain Liftmaster 387lm Wireless...
How to reset master code on adt alarm system without original master code
try 1234,just for kicks and giggles. if that does not work, I need to know system type.
Dec 01, 2012 | Home Security
Adt wants 500+ dollars to repair phone communication failure and defective sensor(warranty) and add seccond key pad and 2 more window sensors in same service call. any way to get parts and leave adt
Communication failure will clear itself once your phone lines are restored. Try arming your system and opening a door to set the alarm off, a forced signal will usually clear a communication failure. As far as parts, you can get them pretty cheaply from a local Alarm Company or dealer. Give them a call, most local, small dealers are fair and helpful. Easy to install yourself as well.
Nov 19, 2010 | GE Home Security
Hi! Just had ADT install security system and it is a Simon XT. Door units, motion sensors and control unit are in house. They also put a motion sensor in garage, which is detached. My understanding is...
My understanding is that GE does not produce a wireless interior siren any longer. So if yo want to get a siren in the garage a wire will have to be run from the Simon 3 to the location in the garage where you would like to place the siren. PS ADT will not run wires to a detached garage. GL
Nov 16, 2010 | GE Security Simon 3 Wireless Home Security...
Have ADT 3000 series alarm system - would like to set it to max
adt sw3000 panel does not support max button on key pad. best solution would be to have ADT tech reprogram Zones so windows are perimeter zones(instant when armed away or stay) and motions interior follower (instant when no perimeter zone was triggered first). doors stay exit/entry.
Feb 25, 2010 | GE Security Simon 3 Wireless Home Security...
We just moved into a house and it has an alarm system that has westinghouse on it. There are sensors on every door and window down stairs. We have no idea how to turn it on and get it set up.
Call an alarm company like ADT. If they can use it they will. it will require some minor reprogramming and they will check all sensors, if the use it. 1-800-ADT-ASAP.
Feb 01, 2010 | GE Security Simon 3 Wireless Home Security...
Home Security Logo
306 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
