Question about Philips TV Tuner Video Capture PCI Card - Phillips Digital (652101138177)
TV keeps turning itself on and off, onto standby
My television keeps switching itself off, but not fully, so that it is on standby. Sometimes it will switch itself back on again too. The red standby light flickers, its as if someone with a remote control is pressing buttons! The problem started when I moved the TV into a different room, it was not damaged in any way through moving. The television is approx 5 years old and tre problem has got progressively worse, in that every time it is switched on now, it more or less immediatley switches itself back off again.
  • 1 more comment
  • clairecannon Nov 29, 2007
    my tv is the same. It always switches itself off to standby so we will have to switch it off fully with the power button and then on again. this has been goin on for about 16 months now since we were given the telly. however the problem is getting worse and now we constantly have to keep switching the telly back on. please help !!!!! our tv is a 32in toshiba not sure of the model number... thankyou
  • bengalbart Aug 01, 2008
    My Evesham 42'' tv keeps switching itself off and on like someone is pressing the standby button on and off, this happens about every 10 minuets
  • franhomeloan Sep 15, 2008
    The tv goes on to stand by when I turn it off and on it comes on but after a couple of minutes it goes back to stand by
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Posted on Apr 22, 2008
My Hitachi L42VC04UB replaced a failed power board .The television comes on and after a short time it shuts down and the standby light in the front of the television flashes blue and red .This happe
Well either the TV's main (or other) board overloads the power board and it shuts itself off or the power board itself shuts itself off for whatever reason or the main board shuts off for whatever reason.
With the setup you have I'd say it's probably going to be difficult to figure out which one it is.
You will want to have yet another board - either main or power - to eliminate one of the two most likely possibilities.
What did you do with the original power board?
If you keep it you can probably send it to us for repair....or if it's cheap enough just buy another one.
i don't think there's an easier and affordable way to narrow it down than using a third board.
www.coppelltvrepair.com
Oct 08, 2012 | Televison & Video
When i switch my tv on it turn's itself to standby, i can switch it back on again but it just keep's switching itself to stanby after a couple of minutes.
You need a live input source to the port that the TV is set to, or turn on the tv and switch input to a live input source, anything else and the tv shifts to standby.
Oct 13, 2010 | Televison & Video
TV will not switch out of standby
Unplug,replug the tv an hour later,let the tv reset itself,might work again.
Apr 26, 2010 | Philips Magnavox 27MS343S 27" TV
Tv switched itself onto standby and now will not turn back on. tried unplugging it and plugging it back in but it still won't come off standby. when you press the button on the remote it goes green for a...
unit seems to go into protect mode.Theres very little that can be done..There is good chance unit needs to be checked at a repair shop.Try to find one that is authorized for your particular brand if possible
Aug 05, 2009 | Televison & Video
TV switches itself off after 1 minute standby flahes red to green
there seems to be a possibility that your ballast might defective.. i recommend you replace it. It might not have enough voltage to keep up with the new lamp
Jul 02, 2009 | Sony Televison & Video
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
Set wont turn on red light just keeps blinking
this is a malfunction of the power supply block (inside your TV-device),or over load of it.please contact the nearest repair shop.
Aug 08, 2008 | Sony Televison & Video
Philips 29PT9418/69G
A qualified tech will need to practice visual acuity technique! Look at power supply circuit for signs of stress,dis-coloration and/or bad connects.Check for bad 47mf/25v cap in area of stress.Replace BC-327-25 xistor w/BC-328 and replace BC-337-25 w/BC-338,if present in your set's chassis style.
Sep 25, 2007 | Philips 25PS40S 25" TV
Televison & Video Logo
541 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
