Question about JVC AV-48WP30 48" Rear Projection Television
JVC AV_48WP30 Screen loses color, everything is in like negative color
I had the convergience issue a few months ago and had that fixed, now I have an issue where the screen just goes into negative color. For a while the screen would go like this for a few mins. and then come back normal...but now I can't get it to come back. I have tried to reset but there is not change. Any ideas? Thanks.
    Novelist:
  • 132 Answers
Sounds like shading, caused by convergence IC or bad solder connections in convergence circuit. Check the CONVERGENCE GALLERY for shading.
JVC design is generally reliable. It is extremely unlikely that you would have 2 unrelated failures.
If you are in Canada, email me.
easyab
Posted on Nov 04, 2008
The convergience is off(screen is different colors) &I don,t have the remote that goes with it (broken). Where can I get the remote for the tv because a universal wouldn't work?
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 03, 2011 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 problem starting up
The old video card has seen better days, methinks. All those symptoms lead one to conclude it needs a 'substitute' to enter the field, or call a long TV time out(too much pro and super bowl isms, eh?)..
Are you planning on doing this yourself?
Feb 11, 2008 | JVC AV-48WP30 48" Rear Projection...
The tv looks like it is in 3d. when i try to adjust the convergiance the plus signs on the left are bent
do not play with this tv replace the stk ic chips and the resistors around the stk chips ,cant miss em about 2 inches big with heat sinks on them.
Sep 11, 2010 | JVC AV-48WP30 48" Rear Projection...
Split color red blue
THE JVC AV48WP30 convergence repair kit from www.tvrepairworld.com usually will fix that issue. The kit contains the parts and the CD with detailed instructions.
Sep 28, 2009 | JVC AV-48WP30 48" Rear Projection...
Purple and Green Streaks
If lcd set the issue may be with the T con board which is responsible for video and any aberrations that you see on screen.
Mar 24, 2017 | JVC AV-48WP30 48" Rear Projection...
Convergence problem wiht jvc av 48wp30
Bad chips...There are a ton of cheap fakes out there....Or bad resistor...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 29, 2008 | JVC AV-48WP30 48" Rear Projection...
What's the difference between AV-48WP30 and AV-WP74
They are both the same size screen. (48" diagonally)
width: 106.3cm
height: 59.8cm
C-Dog
Feb 01, 2008 | JVC AV-48WP30 48" Rear Projection...
Red lines on screen
REPLACE THE CONVERGANCE IC"S.STK392
Dec 23, 2007 | JVC AV-48WP30 48" Rear Projection...
Jvc Av-48wp30
try unplugging for a few seconds the plug it back in
Jul 11, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
126 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
