Question about Brother CS-8060 Computerized Sewing Machine
Wont Run!!! the display shows F7 and the machine wont run. there is nothing about F7 on the manual.
I need an answer
Posted on Nov 10, 2009
My sewing machine wont RUN. The needle goes up and down but the material wont move along.
under the foot around the needle, there should be two rows of what look like teeth, these pull the material through and there will be an adjustment mechanism on the machine. Try leaving the foot up while you run the machine, you should see the teeth going up and down; if they are it is most likely just a case of setting up the amount of pull. I think it is adjusted with the wheel that sets the length of stitch.
Apr 07, 2016 | Sewing Machines
Serger wont budge..hums when step on foot pedal
Motor is locked down. Do Not Energize! take to factory certified service repair person. You will burn up motor or even worse "start a fire" if you try to run it. something is binding motor, this could be many different things.
Nov 08, 2015 | Singer 14SH654
Mu Juki machine with a Sc-800 control just beeps a few times when it turns on but wont run. I pulled a cover off the front of the sc-800 control box and saw E 0001 displayed inside... Any suggestions...
hi there
E0001 means:
1 - power plug or plug socket loose re plug securly
2 - power switch terminal is loosed or removed
3 - contact of power plug wection is not good correct the plug socket
best regards
ashraf abozid
aabozid@hotmail.com
Sep 15, 2010 | Sewing Machines
Motor grinds but nothing moves
your bobbin winder is engaged check it and make sure it is off
May 21, 2009 | Euro-Pro 7500XH Mechanical Sewing Machine
Machine stopped running, its getting power but wont run.
I would take it back to your service tech or choose another. It may be something simple that needs replacement, like a new cord. (or . . .)
Also, before thinking of buying a new machine, I would get another opinion.
Feb 17, 2009 | Husqvarna Viking 1
Are you sewing or embroidering? If you are embroidering, the machine automatically stops and shows scissors in the window, for you clip the jumpstitch. Then just push the "Run/Stop" button.
Dec 13, 2008 | Husqvarna Rose
Touch Tronic 2001 singer Brand
Hi, I have this same machine (I have 2 actually) and I LOVE this machine. There is a reset button underneath the machine - press that and chances are everything will work like normal again. And yes, these machines are repairable. I needed new gears on mine in January - it cost around $120 but it was well worth it. This machine will run forever. I looked at buying a new one and they are cheap plastic and in my opinion not worth it. Good luck!
Jun 12, 2008 | Sewing Machines
Janome 8000
I took my machine in with the same problem and they told me the display was bad. They told me that they did not make this part anymore. Try and find a parts machine.
Mar 16, 2008 | Janome 8080 Computerized Sewing Machine
Brother CS-8060 Computerized Sewing Machine Logo
138 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
