Question about Sony Televison & Video
Rdr-dc100 locked Hi, my tray won't open. It says locked on the front of the player?? Anyone know why this is??
The child lock is on. Press the power off until just the time shows in the display. Then press and hold the stop button until the display shows "unlocked". You should be able to open the tray now.
Posted on Dec 22, 2012
5 Suggested Answers
  • 586 Answers
SOURCE: cannot open dvd tray as it is locked
    DVD must be stuck in it. And it needs mechanical adjustment. Contact any expert nearby to you.
Thanks for using FIXYA!
Posted on Apr 26, 2009
  • 945 Answers
SOURCE: welcome screen locked, tray doesn't open, pwers off rdr gx330
The manual for your dvd is on the sony website
http://esupport.sony.com/US/perl/model-documents.pl?mdl=RDRGX330&LOC=3
Go to F&Q and see disc stuck.
Posted on Oct 19, 2009
  • 109 Answers
SOURCE: The tray on player won't
It sounds like there is something inside the dvd player, that isn't supposed to be there, that is keeping the tray from retracting fully. Try unplugging the unit and gently turning it upside down and giving it a little shake. Not too hard. This might jar the item loose, you will hear it knocking around. If you do knock something loose turn the unit so the front is pointing up and let the foreign object fall to the back of the unit where it hopefully won't interfere with the operation of the mechanisms inside. If you don't hear something come loose, remove the screws on the bottom, sides and back of the unit to remove the top cover. Make sure you have unplugged the power before you do this. take a look and see if you can find something jammed in the track or the gears for the tray. If you do gently remove the item with your fingers or a pair of needle nose pliers. Once removed replace the cover and away you go. If there is nothing blocking the tray and the mechanism, you probably have a gear system to close the tray. At some point someone must have pulled fairly hard on the tray causing the gear teeth to jump, check and make sure they aren't damaged or stripped. You are going to have to them either remove one of the gears (or pull it up so it can turn without turning any other gears) push the tray back into the fully closed position and replace the gear. Once you have done this you will want to test to make sure the tray will function properly. Place the top cover back on, but don't secure it with the holding screws in case you need to open it back up again, plug the unit in and test the tray. If it works unplug it and secure all the screws for the cover and away you go. Otherwise you are going to have to play with the gears till it is back in the proper starting position. If your hearing some strange noises and its not working, then the gears are probably badly stripped. You can contact the manufacturer and see if they can sell you some spare parts or direct you to someone who can replace it. Though at this point simply replacing the unit may be less expensive.
Posted on Jul 26, 2011
  • 8457 Answers
SOURCE: Sony RDR-GX360 won't respond to
Try unplug,replug the unit back like about an hour later for the unit for resetting itself back to factory setting.If getting the same result the unit might have a shorted motor drive for the disc tray.Or shorted control panel on the unit itself.Well,this thing a basic DVD player only wright?If u can tries take it aparts and check out tries to repair it ur self that great.If u tries the shops,not worth it.Trash it.These basic DVD player only are very cheap now.U can get one brand new like $40 dollars.
Posted on Aug 11, 2011
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
DVD/CD disc opener won't workGetting
Usually the tray has to be opened and inspected and if lucky it can be realigned--if not parts may be hard to find as they usually do not sell individual parts for the mechanism.
Nov 05, 2012 | Televison & Video
Monitor doesnt want to open
SEE THIS CAUSES AND FIX IT. God bless you
Service a DVD player disc tray:
  1. Open the housing by removing mounting screws and anything blocking the tray. Press the open/close control to the extend tray, then unplug the unit. To remove a clip-on tray front, brace the tray and slide the panel to one side.
  2. Unplug cables between the front panel and the interior. Remove any screws securing the front panel and remove the panel. If it won't move, check beneath it for clips or additional screws.
  3. Remove the hold-down on top of the disc tray and gently pull the tray out of the player. Clean the travel rail and guides with a swab dampened with denatured alcohol. Lubricate lightly with white lithium grease.
  4. Remove the drive belt (using gloves or tweezers) to inspect for dirt, water, or damage. Clean with a lint-free cloth moistened with denatured alcohol. If the belt is damaged, replace it.
Oct 01, 2012 | Dual XDVDN9131 Navigation system with DVD...
I have a samsung blu ray player and the tray won't
The timing gear is out of sync, to reset the gears requires training and skill that cannot be explained on this site, you need someone that knows what they are doing, or the gears will end up getting stripped making matters worse.
Apr 21, 2012 | Samsung Televison & Video
Philips DVP5140/37 disc tray won't open. Hello! I have tried unplugging from the power source and waiting 10 seconds as their website says to do. I hold down the stop button on the remote 5 seconds...
What could be done is to leave the set Switched ON for many hours even overnight and see how it can change if there is a possible fault on the motherboard, a change of value in electrolytic capacitors.
If there is no result then there is fault in the motherboard and you need to take consensus for an estimate.
Nov 05, 2011 | Philips DVP5140/37 DVD Player
Tray locked on sony dvp-ns77h dvd player
If the Sony DVP-NS77H DVD player displays "TRAY LOCKED" and you can't eject a disc or open the tray, try the following - First turn the unit off. Then, while holding down the eject, play and stop buttons simultaneously (on the front of the DVD player), turn the unit on with the '/O button (also on the front of the player). This released the locked tray for me.
Aug 18, 2011 | Sony DVP-NS77H/S DVD Player
My disc tray won't open the lights turn on and work but the disc tray just won't open. How can I fix this?
hi,
You have to check two things.
1. You have to check the tray loading belt in the mechanism. To see the same you should remove the mechanism.because the loading belt is beneath the cd tray. As it is cyberhome it will be very difficult to remove the mechanism for an user. if your capable for doing the same then make try. Because you have to remove the top cover then the back panel, then the mechanism. Take care the mother board is attached to the mechanism.
2. You have to check the cyberhome dvd player will show this type of complaint if the Spindle motor is faulty (oppen or short ). Spindle motor is one on which the cd rotates. It will not cost a lot.
ok
May 05, 2011 | Cyberhome CH-DVD 300 DVD Player
My sony dvp-sr200p, disc tray is not opening?
Hello
Try the mechanical release;
Look for a very tiny hole in front of the drive; use a paper clip poke through that hole, apply a little pressure and push. The tray should pop open.
there might be a panel that covers the tray, and you won't see the tiny hole. If that's the case, just use your fingernail to pry open the panel, which most likely will pull out (not off), and you'll then see the hole. Once you push the straightened out paper clip into the hole, the tray should come out enough for you to pull it out the rest of the way.
Sometimes the CD drive doesn't open because the case is misaligned. Try pressing on the center portion of the drive when it is attempting to open!
Apr 11, 2011 | Sony DVP-SR200P DVD Player
Televison & Video Logo
183 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
