Question about Sirius Satellite Radio Audio Players & Recorders
How to operate 2008 Mercedes e350 Sirius radio
2008 e350 Mercedes Benz
4 Suggested Answers
SOURCE: My Sirius radio, factory installed in a 2008 VW
I hope this post finds everyone well who is having difficulties with Sirius Radio's trouble shooting advice to reactivate service. I tried to reactivated my service and had experienced all the problems that everyone has had on these forums. This is what works. It took me a lot of phone calls and I want to get the word out to everyone (regardless of Make, Model or Year of Vehicle)
First, a soft reboot does nothing and there is no such things as 'reseting' the electric system in your car. Second, there is no such thing as a 'hard' reboot to your sirius radio. All a soft reboot will get you is cold legs when you have to hold your car door open for 30 seconds in the middle of winter. All a hard reboot will do is cost you a lot of hard earned money at the dealership. Best case scenario is that your dealer replaces your entire radio and charges you $500+.
WHAT YOU NEED TO DO: Call Sirius Customer Service and ask for Technical Support. Explain to them you are having difficulty obtaining an activation signal. The technical support technician did the following (and it was the most intelligent thing I heard from Sirius)
1. Go turn on your Sirius Radio and tune to Channel 184.
2. The technician put a "dummy" ESN in on my account, refreshed and then re-entered my original ESN back into my account and then re-sent the activation signal. **NOTE** Make sure you write down your original ESN number before you ask to have them do step #2....there is no way for them to recover your original ESN if they put in the 'dummy' ESN and refresh.
3. Within 10 seconds of putting doing step #2, my Sirius Radio said, "Updating Channels" and worked great.
Takeaway from My Experience: I believe that once you let your Sirius Radio Service relapse and/or do not renew your subscription, a signal/frequency is sent to your radio to block service or reactivate your service. The problem must be an internal issue on Sirius where the only fix to stop this signal is to completely clear (or zero) out your original ESN, enter a dummy ESN, refresh and then re-enter your original ESN and then send the activation signal.
I hope this helps everyone.
Posted on Jan 07, 2011
SOURCE: connect sirius fm adapter to 2008 honda civic sedan radio
Yes. Factory installed radio.
Posted on Jun 19, 2008
SOURCE: sirius radio reset on dodge ram 2008
I have the same problem. When Sirius sent me a new "update" signal, I lost more channels. They don't have any idea. Did you figure out how to reset?
Posted on Jul 06, 2009
Battery die n I Chang it now my radio on 03 e320 don't turn on
When your car battery is exchanged, your radio will become de-programmed. The way to resolve your problem is to raise the volume to midpoint, you should hear hissing coming from speakers. Then reset all your stations, and the clock.
Jun 08, 2016 | Mercedes E-class E320 E350 E500 E550 E63...
Intake manifold torque specs.
It is criss cross from front to back around 15 foot pounds so snugging them with a ratchet should do the trick
May 17, 2014 | 2008 Mercedes-Benz Mercedes Benz C Class
Where is the cd changer at
It should be hanging from the rear package tray if the car is equipped with one.
May 05, 2014 | Mercedes E-class E320 E350 E500 E550 E63...
La Senal de ESP de mi E350 4Matic mercedes benz esta encendida y dice que el ESP no funciona?
Reinitialize the system. Close all doors. Start the engine and apply the brake. Turn steering to full left lock and hold for two seconds, turn to right lock for 2 seconds, return to center. Repeat that procedure a couple of times. Move car forward and/or backward at least 30 feet. If there is no reset DTC and no stored or registered DTC, the MIL should go out.
May 01, 2014 | 2008 Mercedes-Benz Mercedes Benz E Class
I have a 2009 Mercedes Benz E350 & need to find the fuse for it. My command radio gives me a message device unavailable.
if i'm not mistaken, there are two fuseboxes in that car maybe three. the two i know for sure is the one under the hood in the black housing and the other is under the passenger side rear seat.
Sep 25, 2013 | Mercedes E-class E320 E350 E500 E550 E63...
E350 2008 navigation fail to connect
Usually navigation and other services are dependent on the owner subscribing to the service. If you've just purchase the vehicle it will probably require you to subscribe to that service through Mercedes or their affiliate.
Jan 10, 2013 | Mercedes E-class E320 E350 E500 E550 E63...
How do you change the time on the analog clock in the 2008 Mercedes E350?
if you have the command display adjust the time on command then it will automatically take by instrument cluster if your car don't have the command you must set it by using multifunction switch on steering wheel,
Nov 13, 2010 | 2007 Mercedes-Benz E350 4Matic Wagon
TRYING TO RESET E350 2008 SERVICE C EXCEEDED
1) Turn key to position 2.
2) Press/release the R button to show the next service due light. Release button.
3) Turn key to Off.
4) Press and HOLD the same R button to view the service light, THEN, within 2 seconds, turn key to position 2.
5) Wait up to 10 second and the light will reset to show new service .
Let me know if this worked.
Apr 09, 2010 | 2008 Mercedes-Benz Mercedes Benz E Class
Where is the battery location for E350 2008 mercedes?
most cars have the battery under the bonnet, some modern cars may have a large plastic cover covering them, some mercedes have the battery located in the boot (under carpet etc) and some are located underneath the rear seat base.
Nov 22, 2009 | 2007 Mercedes-Benz E350 4Matic Wagon
687 people viewed this question
Top Sirius Satellite Radio Audio Players & Recorders Experts
John
John
Colin Stickland
Colin Stickland
Tom Chichester
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
