Question about Kenwood KAC-9102D Car Audio Amplifier
Overheating I think this is the problem it overheating but how do i fix that?
  • Nick Latham Aug 28, 2006
    Its shuting down when the amp gett hoter than hell
  • J_Money Apr 16, 2013
    same problem with mine, amp is getting suuper hot in the truunnk & is going into protection mode which causes the music to sound lower then displayed on the head unit.
    Problem Solver:
  • 6 Answers
I need some more information. What is it actually doing to make you think that it is overheating?
Posted on Aug 24, 2006
My laptop runs good for about an hour then shuts off. I think it's over heating. What is the best solution to fix this?
If it is just overheating then you can do a couple of different things:
1) Make sure you use the laptop with plenty of space around it so it has air to the fans.
2) Buy a cooling platform designed to help with overheating.
Also, you may need to do a complete diagnostic to make sure everything is still good. Overheating can burn up the transistors quickly.
Apr 12, 2011 | HEWLETT-PACKARD Presario CQ50-210US...
Where do you put engine coolant? I think mechanic
If the car is overheating it is not just cause the coolant is low. There is a leak somewhere in the system this must be fixed first.
Dec 24, 2009 | 2004 Lincoln LS
My truck is showing me a code on the dashboard that says: ENGINE HOT A/C TURNED OFF, air blows but the A/C doesn't. How can I fix this? thank you
A/C turns off when the engine overheats, if it isn`t actually overheating, your coolant temp. sensor could be bad, which would make the computer think that it is too hot.Look for overheating first then check that sensor if not overheating.
Oct 26, 2009 | 2007 Chevrolet Silverado 1500 2WD
Radiator is overheating chaned thermastat still
water pump is the problem,you will find the the water pump impellor has broken or come loose from the shaft,you going to have to replace the water pump
Oct 19, 2009 | 2000 Volkswagen Jetta TDI
Im thinking about buying a disco there is a
Hi
One simple piece of advice. If you are thinking of buying this particular Discovery - don't.
The reason for this is that although potentially this is an easy fix and is likely to be a thermostat that needs replacing (jammed shut) - there is a risk that the jeep has been running for some time with this overheating problem. At least you don't know how long it has been driven like this.
The risk of driving an overheating engine is that the cylinder head could be warped and even if you resolve the overheating issue - other serious engine damage may already have occurred.
This could easily turn into a very expensive mess. If I was to view a car with an overheating issue like this I would simply walk away. Even if the head is not warped there is a higher risk of a head gasket blowing at some point and this again involves considerable expense in labor terms.
There are plenty of good Discoverys out there. My advice? Keep your money in your pocket until you find one.
Hope this helps. Please do rate this answer. Thanks.
Aug 16, 2009 | 2001 Land Rover Discovery Series II
1998 aurora overheating
I had the same problem and tried several things that didn't help. A friend introduced me to a Northstar mech. that explained the real problem. Internal engine relief was faling which created overheating between cylinder sleeves and engine block creating blow back pressure in cooling system. There is a fix for this. The mechanic helped me with the problem and car is running once more... Anyone thinking they have a head gasket, intake gasket, or thermostate problem should look at this fix.
Jun 01, 2009 | 1999 Oldsmobile Aurora
Acer Aspire L100 overheating
You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
Dec 22, 2008 | Acer Aspire L100 PC Desktop
Kenwood KAC-9102D Car Audio Amplifier Logo
137 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
