Question about Refrigerators
Whirlpool ARC 4110 fridge freezer problem
Fridge is warm while freezer remains frozen. just ditched a load of food. Have tried turning up thermostat, unplugged and started it up again. Motor is kicking in when the door to fridge or freezer is opened but not cooling down fridge compartment.
dididsaythat
  • 291 Answers
SOURCE: SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Posted on Oct 12, 2007
fridgetech
  • 473 Answers
SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Posted on Nov 16, 2007
  • 231 Answers
SOURCE: Whirlpool fridge/freezer ARC 7050
see if you can remove panel inside freezer to see if its full of ice all over condenser .Even if you already defrosted for 1 day..If its full of ice ..Then the DEFROSTER COIL is not working and not melting the ice on condenser and then stoping the cycle therefore compressor will stop running..Also there should be a a couple of thermal switches on the condenser(two wires) if this is bad then there is no cycle..goodluck
Posted on Dec 06, 2007
  • 958 Answers
SOURCE: Candy frost free fridge freezer
you can decrease the setting of your thermostat for a start.
tnx 4 using fixya,
drcool
Posted on Sep 07, 2008
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
Ice maker quit working
Brenda, try the following.
1. disconnect power from the wall.
2. open fridge and freezer doors and leave them open for at least 5-6 hours. salvage foods you can.
3. after a few hours you will see a puddle of water under the fridge.
4. clean the floor and the fridge and freezer of any collected water.
5. power up the fridge and set at recommended level say 4.
6. you will hear humming noise. Let the fridge and freezer cool.
7. dont overload food.
good luck
Apr 08, 2014 | Whirlpool : GX2FHDXVY 22 cu. ft. Bottom...
Electrolux Side by Side Fridge-Freezer ESE6108WA - freezes food in the fridge
hi its sound thermostat problem not click off when the temperature reach to the set point ,need to replace it.
May 14, 2012 | Electrolux Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Refrigerator freezing food
Fridge thermostat dials are often problematical due to the ones that are numbered 1 to 10, is 1 the warmest or the coldest as the number is lower? Some companies put 'warmer' and 'colder' which avoids confusion. My advice, put it in the middle '5', and leave overnight, check the temperature in the morning with a fridge thermometer. Then change the thermostat dial to 8, and check it the next morning with a thermometer. The next day put it on 1, and leave overnight, check the temperature in the morning. If the thermostat has gone, all three morning temperatures will be the same.
You mention 'or as your website suggests', you know we are not Frigidaire or anything to do with the retailer? We are Fixya, people just like you, helping others. I am a caterer, and just happen to know about fridges. I get them repaired professionally, but always ask for a full explanation of what went wrong. We recently had a sandwich storage fridge that was freezing food, and it was the thermostat that needed replacing.
The things you did, cleaning the coils, will actually make the fridge run colder. The Defrost Thermostat is unlikely to be the problem, as when they don't work, the evaporator, the part that is where the chilled air comes from turns into a block of ice. When that happens, air can't pass through it and the fridge warms considerably.
Due to the damage this freezing is causing with your water and filter, I would suggest you call a service engineer and get it fixed professionally as you will be swapping out parts that are fine. Correct diagnosis is the key, and they will also check the gas pressure at the same time. Consumers can't work with refrigerant gas, it is *******.
Mar 14, 2017 | Frigidaire Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
This unit is used in a garage as a 2nd unit. It
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Whirlpool 25.2 cu. ft. Side-by-Side...
Refrigerator is not cold (50);freezer is working; vents not blocked. What can I do? Fan is working, & compressor does kick on.
Nine out of ten times it turns out to be a defrost issue. What most people dont understand is the refrigerator gets its cool air from the freezer. If the evaporator coil in the freezer becomes a block of ice then the airflow from freezer to fridge section is blocked. The block of ice along with already frozen foods in the freezer compartment help to keep those foods frozen. Therefore you assume the freezer section is fine. However, the lack of cool airflow to the fridge side quickly turns that 38 degree air into 50 degree air. You could try unplugging the fridge and leaving doors open for 24 hours, this will thatw the evap coil. Plug it back in after the 24 hours, and within 12-24 hrs everything should be cool. If the fridge continutes to cool for about 3-6 days and then fails again, you certainly have a defrost problem. This is long winded, but hope it helps
Mar 01, 2010 | Refrigerators
Amana Model #TX20NBW FREEZES food in the fridge AND leaks water
Sounds as if the thermostat setting is too high.
Not a good idea to pour warm water into the fridge while its going, but then again.Most drain tubes exit over the compressor into a container sitting atop it. But I've since learned there are now fridges that don't have compressors now? You should also check the door seals, you can do this with a sheet/piece of newspaper
inserted between the door and fridge, go around both doors, you'll soon know if the seals need replacing.
Oct 03, 2009 | Amana ATB2135HR Top Freezer Refrigerator
Freezer is frozen fridge is warm
Your model is most likely the Profile Artica style. Most times the defrost heater is burned out behind the rear of the freezer wall. Manually defrost and look at the defrost heater to see if burned out. That model possibly has the glass covered defrost heater and will be easy to spot if burned out because the element is inside a glass tube, If you replace the defrost heater also replace the defrost thermostat, Please send me your model number located near floor of the fresh food compartment door seal and kick plate, Thanks Sea Breeze
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer is not staying cold. The freezer is on but its not staying cold enough to keep the food frozen. The Ice maker switch is turned on but ice is still melting. Turned the control to coldest but still...
Sounds like the evap. fan motor is not turning. What is the freezer temp. have you measured it ? What about the fresh food section, (fridge compartment).
Anyway, try this. Hold the door switch in the closed position with the freezer door ajar and see/listen for the fan coming on. If you can't be sure, the best way to do this is to first turn the thermostat all the way to the "off" postion, and with the freezer door ajar and holding the door sw. closed (pushed in). turn the thermostat back on. (you may need to turn off then back on first if your arms aren't long enough) You should hear the fan motor start.
NOTE; you may hear the compressor overload "click" off if trying to start it right after shutting down, this is normal (under short cycles or manual restarts). You may also hear the condensor fan motor run (under the fridge by compressor) this too is normal. try to indentify the freezer fan (evaporater fan motor) running or not.
good luck.
Sep 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
121 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
