Question about Kitchen Appliances - Others
I have a kenmore waffle baker #632-64692 does it have to be greased before used?
Do I have to grease it before I use it?
5 Suggested Answers
SOURCE: Looking for Owner's Manual
It appears to be available at kitchenmanuals.com.
Posted on Feb 16, 2008
jyackle5
  • 8197 Answers
SOURCE: Owners Manual for Toastmaster Rotating Waffle Baker #TMRWB
Here is the manual that you are looking for.
http://dl.owneriq.net/0/0575c102-ef0d-44ef-969a-69c02c10575d.pdf
Good Luck and Please Rate FixYa!
Posted on Dec 28, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: I have an old kenmore
It might be, but "worth repair" is mainly up to you to decide. It depends on several things, mostly cost. Can you buy a new one that does what you want for $50 or so? Then you're probably better off doing that than trying to get your old one repaired. Even if you can find a shop that services small appliances - a rare thing today - minimum labor will be at least $20 just to check it over. Then there is the cost of parts, which may not be available at all for an old appliance. A cord is not likely to be a problem, but a rattle might mean some piece inside has broken off; if it's part of the case then there probably won't be parts available.
On the other hand, if you can't find something new, or this one has features you love and you think it's worth the cost, then it's definitely worth the repair. See what kind of money is involved, then decide.
Posted on Dec 02, 2010
SOURCE: Seasoning Waffle Baker and Grill
BEFORE FIRST USE
1. Remove the cooking grids if possible. Wash them in hot, sudsy water, rinse, dry thoroughly,
and replace them in the unit.
2. IMPORTANT: Condition the non-stick cooking surfaces with a light coating of cooking
oil before first use. Do not use non-stick cooking spray to "condition." Brush the oil
onto the cooking surfaces or wipe on with a paper towel. Be sure to coat the cooking
surfaces as this will reduce sticking. Wipe off excess oil with paper towels. The first
waffle may absorb excess oil and appear greasy. If so, discard it.
BAKING WAFFLES
1. Be sure the Cooking Grids are securely attached with the waffle sides showing. Close
the unit and plug the cord into a standard electrical outlet.
2. Turn the control knob to WAFFLES. The signal light (A) will
come on to indicate the unit is heating. Use the pre-heat time
to prepare your batter (see "Recipes"). When the signal light
goes out (from 5-8 minutes), the unit is ready.
3. Open the unit and pour about 1 cup of batter (for a 4 waffle waffle maker) onto the lower
cooking surface. Spread the batter toward the edges using a
rubber spatula for even waffles.
4. Carefully close the top. Keep hands away from the unit as steam may escape when
baking begins. The signal light will come back on and may cycle on and off during
baking. Cooking time is 3-8 minutes depending on the type of batter/ingredients you
used, and which waffle iron you own. Average is 5 minutes. The hinge between the sections is designed to be loose. This allows the waffle to
rise evenly and for steam to escape during baking. You may also notice steam moisture
on the sides or near the handle. This is normal. AVOID OPENING THE UNIT DURING BAKING AS THIS MAY CAUSE WAFFLES TO STICK OR BAKE POORLY.
5. When waffles are done, the signal light will go out. Open the top and remove the
waffle using a rubber or wooden spatula. Be careful not to scratch the non-stick finish.
You may want to have a plate nearby when removing waffles in case they separate as
this unit is designed to semi-cut waffles into 4 sections. If sticking occurs, lightly re-oil
the cooking surfaces. You can make additional batches right away - no need to let the
unit cool down. Keep the lid closed between cooking batches to preserve heat.
6. When all waffles are baked, turn the control knob to OFF, unplug the cord, open the
unit, and allow it to cool.
Posted on Jan 20, 2013
User guide kenmore waffle baker
We need the Model # to look it up for you. Thanks.
Feb 14, 2015 | Kenmore Kitchen Appliances - Others
Need manual for toastmaster waffle baker 442a
Here's a manual for model W252 which is similar to your model.
Mar 04, 2013 | Toastmaster 442a Waffle Baker Model 295...
Looking for used "Sunbeam Waffle Baker & Grill" with Radiant Control w/removable plates. Had one back in 1954. OR...Toastmaster Model #269 "Waffle Baker".
I have a Sunbeam Radiant Control Waffle Baker and Grill with original care and instructional booklet dated 1954,
Jun 08, 2010 | Sunbeam 3852 Waffle Maker
Waffles sticking in a Salton wm-4.
Salton wm-4! one of the oldest waffle maker. The waffle is generally known to be difficult to clean. I would only advice you should always grease the plate before use. This helps make cleaning easy. You can also check our post on The Best Waffle Maker in 2017 The best waffle maker 2017 Easy buying guide Kitchenutilitypro
Sep 24, 2017 | Salton WM4 Waffle Maker
I have a Betty Crocker belgian waffle baker and I can't find my manual with the recipes in it - I need the recipe for the belgian waffles that is in the manual.
2 eggs, 2 cups all purpose flour, 1/2 cup vegetable oil or 1/2 cup ( 1 stick) margarine or butter melted, 1 3/4 cups milk, 1 T. granulated or brown sugar, 4 tea. baking powder, 1/4 tea salt.
Heat waffle baker. Beat eggs with wire whisk or hand beater in medium bowl until fluffy. Beat in remaining ingredients just until smooth. Pour about 2/3 cup batter onto center of hot waffle baker. Bake about 5 minuted or until READY light goes off. Remove waffle carefully. About 3 1/2 cups batter.
Makes 10 4-inch Belgian waffle squares.
Nov 26, 2009 | Betty Crocker Kitchen Appliances - Others
Waffles drying out and sticking
Try getting a teflon coating for your cooking surface.
Jun 03, 2009 | Sunbeam 3852 Waffle Maker
How does the ready light work on the toasymaster waffle baker
Depending on what you have it should turn green when ready to cook, ten the light shuts off when you put the waffle mix in then when waffles are down it turns green again
Feb 07, 2009 | Toastmaster Kitchen Appliances - Others
Wolfgang puck swivel waffle baker... power just goes out..
there is a small overheat fuse that blows , no parts made ........ CALL HOME SHOPPING ! tell them what you think of there products ! if everyone did this , you might see longer lasting stuff offered
Nov 29, 2008 | Wolfgang Puck Rotating Waffle Baker -...
Sticking waffles
use cooking grease before you use it other wise it will stick
Jul 12, 2008 | Waring WMK300 Professional Belgian Waffle...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
