Question about Cannon Office Equipment & Supplies
When trying to copy black document, paper is coming out blank
    Sergeant:
  • 264 Answers
It is quite possible that the black ink cartridge is empty. Kindly check for the same
Posted on Oct 27, 2008
What are the commands to initialize scanning lamp or unit or what unit or part is faulty due to which not copying instead giving blank paper.
Make sure the document you are trying to copy is face down on the glass. This and more should be explained in the owners manual.
Feb 27, 2016 | Office Equipment & Supplies
IR400 copier print to black copy
Not at all certain what your question refers to. The Hp Image Runner 400 is a black & white copier. What do you want to do that you are unable to do? Have you previously been able to do what you wanted with this copier, but can no longer do the same? What happens when you try to copy a document? Does the copy come out blank, or all black? Are you getting a large black area on a 8.5 x 11 inch sheet of copy paper when you attempt to copy something that is smaller in size, and therefore wasting lots of toner? Please explain your problem in detail, or no one will be able to help you. Thanks
Nov 24, 2014 | HP Office Equipment & Supplies
Copies come out blank.
several possibility of problem are:
- empty toner (you must check it)
- moist paper (solution = the copies which come out blank return to paper case, to use again. it is mean to use not moist paper)
- lifetime of the drum is over.
Jun 21, 2011 | Canon PC-1060 Black and White Copier
How do u load paper? front or back side up?
Hi, It dosen`t matter how you load paper, Copy paper are blank on both side, now if you are reusing paper with prints on one side then you do it by trial and error.
Now if you meant how to load document on top, then that`s a different story, most fax machines require that you put the document face down. I would suggest that you make a copy from a document face down and if it comes out ok, fine, if the copy comes out blank then you need to put the document face up instead.
Hope this helps.
Mar 13, 2010 | HP 1040 Plain Paper Inkjet Fax
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
How to copy with Epson SX 100 pleaae?
first of all on the printer.then place the document to be copied (the orignal)on the scanner glass.then press the option button copy on the printer.then press in which mode you want.if you want the document to be copied in colour press the colour button on the printer.if you want the document to be copied in black press the black button on the printer.and place the blank paper in the paper tray ,thats all.
Feb 25, 2009 | Epson Stylus Multifunction Inkjet Printer/...
How do I stop a black line appearing on the copy of an original document
Try this- Make sure the whole glass area of the copier is covered with white paper,
ie. lay the document face down, and any glass area you can still see- cover with sheets of blank white paper
Good luck
Nov 26, 2008 | HP Office Equipment & Supplies
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Greg Cann
Greg Cann
Iqbal Husain
Iqbal Husain
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
