Question about LG Washing Machines
Lg wm2233hw will not spin
Will not wash or spin with a load of clothes in it check drain pump its ok draining good
SOURCE: washing machine not spinning or draining water
I have the same washer, WT-R801. Does the machine stop all together when the spin cycle arrives?, if so check the pump on the drain. Mine was burnt out. Its available for $61.00 delivered from Adelaide. Steve.
Posted on Mar 31, 2008
JOE LLAMA
  • 26 Answers
SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Posted on Apr 01, 2008
  • 86 Answers
SOURCE: tricity bendix BIW103W spins badly, clothes still too wet.
Hi, Your problem is very common and very easy to fix. You will first need to strip the machine down and remove the motor. Once you have done this then take off the motor carbon brushes, These are the little things in cases on the side of the motor casing. These should be at least 1" long! you will find that this is not the case and they will need replacing to resolve your problem. The parts should not cost anymore than around £20 for the pair.
Good luck any problems get beck to me............................
Posted on Mar 18, 2009
  • 30 Answers
SOURCE: washing cycle is ok but wont spin
check carbon brushes on motor
Posted on Jun 09, 2009
SOURCE: For LG WM2233HW, Error Code OE. Already check
Replace the water pump. Because the water can not pump out, the machine idles for a while then stops with the error code OE. The technician said, the drain hose should be hang high before curse down to the drainage so air can not go to the hose.
Posted on Jun 24, 2009
Cloths come out wet after spinn
The water drained out ok? If yes, the timer is telling the motor to reverse and run in the drain spin direction and it is likely ok. If the draining is slow the clothes could come out wet, if the belt is cracked or streatched the clothes could come out wet. If the motor is not running through the entire spin/drain mode the timer could be at fault.
Will Not Spin
• Check for unbalanced load.
• Check for broken or slipping belt.
• Does the house drain system accept water from
machine?
• Check for blocked drain hose.
• Check for binding tub seal.
• Check for partial engagement of brake assembly.
• Check for obstruction between tubs.
• Check for broken impeller on pump.
Jan 02, 2012 | Amana NAV5800A Top Load Washer
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
Water can't out from macshine went i want to wash
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
Jun 21, 2011 | LG WFT1071TP Top Load Washer
Does not spin clothes very good. clothes are still very wet.
heatman101
Apr 29, 2011 | LG WM2050CW 40 cu. ft. Washer
I LG machine is not spinning. It is able to wash and rinse cloths but not spin them. Could you please let me know what could be possible issue.
heatman101
Sep 28, 2010 | LG WFT1071TP Top Load Washer
Clothing still wet after spinning
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 03, 2010 | LG Washing Machines
Good Morning Sir/Ma'am, We own an LG WM2233HW with an "error code of OE" which means "Drain hose is bent or clogged" and/or "The drain filter is clogged". I have checked both. I straightened the drain hose...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!! !
Aug 30, 2010 | LG WM2233H Front Load Stacked Washer /...
Washer will not drain or spin
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 07, 2010 | LG WM-2277HW Front Load Washer
For LG WM2233HW, Error Code OE. Already check drain hose and filter, all clean. Try different cycles, TUB CLEAN, SPEED WASH. Same error code. No drain.
Jun 19, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
21 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
