Question about Onkyo HTR500 Receiver
Onkyo HT-R500 amplifier protection circuitry activated
When I power on, it shuts off immediately. I only see 3 fuses and they are all intact. Any suggestions?
  • 2 more comments
  • Anonymous Dec 19, 2008
    Shuts off immediately after i turn the reciever on.
  • Joe T.
    Joe T. Jan 13, 2009
    I changed all the fuses, and still wont keep power on, rather hooked up or not. I hate to drive 75 miles to a service center when the prob could be fixed myself.
  • petpilot Feb 08, 2009
    I have the exact same issue - my HT-R500 receiver (disconnected from all speakers) shuts off imediately after pressing the power button. Please let me know if you find out what the problem is and how to fix it. I'll do the same.
  • Oddysey Mar 02, 2009
    same problem but ....... mine started doing this when i saw smoke come up from it ! it wasn't even on when it happend only in stand by.
    when i opened up the top cover ( if you do this be careful there are comparators in there that hold 500w of voltage ) i noticed that one of the heat sync's was broken and cracked ( twords the front of the system ) i asume that it goes into protection mode if something is wrong .
    Problem Solver:
  • 15 Answers
U have a short.
remove all speakers cables and turn it on, if remains on and u can up the volume do the next.
1: turn it off.
2: connect only 1 speaker cable (each time to see if the short is in one speaker or cable)
3: turn it on, up the volume.
this way u must be able to see what cable or speaker have the problem.
if still the same prob the short is inside.
i put a answer of a prob where cant up of 41 check the cleaning method.
Good luck
Posted on Jan 12, 2009
Av receiver HT-R500 just keeps shutting itself off?
Too much voltage going in the receiver or you have the wrong size fuse in it.
Aug 24, 2012 | Onkyo Audio Players & Recorders
This site said it was free - then there is a charge? I am getting a "Protecting" message when I turn on my receiver - then it shuts off....What does this mean and what should I do?
It means the receiver senses excessive heat, or a short at its outputs. Disconnect the speaker wires and see if that helps. If not, get it to a Tech. If it turns on, figure out which speaker path(s) was causing the problem and resolve it.
The manual.
http://www.retrevo.com/support/Onkyo-TX-SR601-Receivers-manual/id/365ag212/t/2/
Power shuts off immediately after power on.
• Amplifier protection circuitry is activated. Remove the power cord from the outlet immediately. Contact your Onkyo service center.
Jan 13, 2011 | Onkyo TX-SR601 Receiver
Power shuts off immediately after power on, amplifier circuitry has been activated for a Onkyo HTR500. how do fix the problem? do I change the fuse.
If you disconnect the speaker wires from it and it still happens, you should get it into a technician to look at it.
Dec 28, 2010 | Audio Players & Recorders
Onkyo ht-r500 no speakers attached goes directly into protect mode, standby light blinking..
I have a HT-R520 - First thing stated in the manual is 'Do Not Apply Power to the System Until All the Speakers Are Connected to the Receiver.' This practice avoids any hot connects to the speakers. As with any high-outpiut system connecting spreaker wires to the system while in operation can spike the speakers as well as the amplifier curcuits. Hook up your speakers first and give it a try. Good Luck!
Jul 14, 2009 | Onkyo HTR500 Receiver
Power will not stay on
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Apr 21, 2009 | Onkyo HTR500 Receiver
Blow right speaker channel - ONKYO TX-SR506
There is some way to change a protection (fuse?). No. The fuse usually was not broken. How long did your amp turn on?
3 seconds (DC protect) OR immediately shut down (Over Current protect)? How to confirm?
1.Unplug the amp.
2.Remove the metal cover.
3.You will see a long vertically installed pre-amp board mounted next to those large power transistors fixed by 12 screws on a large aluminium heat sink.
4.Remove this long vertically installed board mounted by 2 screws.
5.With 2 screws removed, just pulling this board out and hold it with one hand.
6.Plug the amp and switch it on.
7.If your amp stays ON forever, the problem is from this long board.
8.If switch off at once, the problem is from power amp board.
Try the above- mentioned steps. I will tell you what to do next. Just search you tube for SR600 cap replacement. I have written an email here. Write an email to me if you want to fix this amp.
Sep 30, 2017 | Onkyo HT-SR800 System
Onkyo ht-r500
I found the manual sometime back...try 3Xdouble-u dot eserviceinfo dot com
Aug 06, 2008 | Onkyo HTR500 Receiver
My Onkyo Receiver TX 601 is turning itself off
Several things can cause this: Loud signal passages can momentarily draw high currents at the mains, especially if you have unit plugged into power stripe with other equipment. Or if unit is plugged into isolation transformer, current draw may exceed output of transformer. Too many speakers hooked to output or if one is bad (partially shorted due to overheating)
Apr 04, 2008 | Onkyo HTR500 Receiver
Onkyo HT-R500
Unit has circuitry problems, take in for service
Mar 14, 2008 | Onkyo HTR500 Receiver
Power shuts off immediatly after power on
you may have to many electronics plugged up to one circuit in your house. try plugging the sound system into a different socket and that might help.
Oct 31, 2007 | Onkyo SKS-HT500 System
Onkyo HTR500 Receiver Logo
1,295 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
