Question about Campbell Hausfeld FP209499 3 Gallon Air Compressor
3 gal 100 max psi campbell hausfeld SH2100 won't start..also tried connecting directly to power outlet. cannot find reset button. Model FP204900
Worked fine fore and just stopped.absolute no power tried different outlets and also tried connecting directly without extension cord.
5 Suggested Answers
SOURCE: Need new pressure regulator for Campbell Hausfeld
Friend had some pressure regulators and one of them fit. It is also a step up from a direct replacement OEM part. Thank you for your responce to my question.
Posted on Feb 01, 2010
  • 885 Answers
SOURCE: Campbell Hausfeld 13 gal air
Your problem is most likely because of damage to the valve plate or piston & cylinder. If one or both of these are not working properly you'll get partial pressure and the unit won't turn off because the tank never comes up to full pressure. Things to check for are damage to the reeds on the valve plate, they could be bent from overheating or broken from use or wear or damage to the piston seal which can cause damage to the cylinder. If any of these aren't sealing properly the air pressure will come up to a point where the air leaks out faster than it goes into the tank. Without your particular model number I don't know which parts to recommend but if you contact Campbell Hausfeld they'll help you get the right parts.
Posted on May 12, 2011
  • 1388 Answers
SOURCE: Campbell Hausfeld Air Compressor 1.8hp
You compressor is listed as being oil free. The only liquids that could possibly leak out of the motor (if still from factory condition) is black substance from overheated capacitor/s or grease from a failing bearing. Remove capacitor covers and check for failed cap. Motor bearings will become noisy before failure. Capacitors are available from motor repair shops and many times on ebay. Replace with same uf rating and same or higher voltage. Some caps are larger /smaller with same reading (notice size so cap cover will fit). Good luck
Posted on Jul 11, 2011
  • 643 Answers
SOURCE: I have a campbell hausfeld 2 gallon 135 max psi
No Fuse However this model is known for having the switch go bad. You can check it with a meter or Continunity tester with the unit unplugged
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya
Posted on Aug 12, 2011
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
My campbell 0.33 runs but won't built a pressure
Check that the drain cock on bottom of tank is shut off,or leaking.?
Jan 28, 2013 | Campbell Hausfeld 0.33 HP 2-Gallon 100 PSI...
I have a campbell hausfeld 2 gallon 135 max psi compressor suddenly stop working, when i turn the switch on, and making sure its plugged into a "hot" outlet, nothing happens, no buzzing, no sound...
Aug 12, 2011 | Campbell Hausfeld 2 Gallon Air Compressor
Campbell Hausfeld Air Compressor 1.8hp 135 max psi 20 gal wl611800aj the prob is there is a fluild leaking from the motor
Jul 11, 2011 | Campbell Hausfeld 1NNF5 Air Compressor,...
Campbell Hausfeld 13 gal air copressor, when I trun it on it won't build up max pressure and won't shut-off One of the gauges reads 40 PSI the other reads 60 PSI.
May 12, 2011 | Campbell Hausfeld 13 - Gallon Air...
Need the connection for the wand hose to the pump for Blue Max Gasoline High Presssure Washer stock No: PW2200/03435
Your pressure washer is sold under various brand names, however I believe that it is made by campbell hausfeld. Parts are here:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/campbell-hausfeld/PW2200
Take a close look at the pump diagram to make sure it looks like yours. Good luck
Nov 10, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
My compressor runs way too long to fill up to 150 PSI. It fills up quick to 120 PSI then just takes forever to get to 150 but finally does. It's only 1 year old with very little use. 17 gal, 1.1 horse,...
The pressure switch should be at the factory setting of about 120# max. Not to be hurtful,but what you discribe is normal. Even a 2 HP 220V is minimum for a compressor.. You go by the CFM Rating. You and I can not afford a two thousand dollar 12 CFM Unit. Your compressor is simply too small, to do much. It is pushing against tank pressure so much,after 90# that the reed valves can't hold it. Set it at 100 to 120. It is not designed to run up to 150 max. Now if it is,an oiless compressor , it won't last long. My Campbell- Hausfeld lasted 31 years. Got a new one two years ago
Mar 13, 2010 | Air Tools & Compressors
their web site is chpower.com can order on line if not to old can check warranties also they can direct u to service location in ur area
Feb 01, 2010 | Campbell Hausfeld Air Tools & Compressors
I need an owners manual.
plz follow this link and choose your model and get the manuals.
http://www.chpower.com/webapp/wcs/stores/servlet/XItemDocuments?storeId=10051&langId=-1&catalogId=10001&findModel=FP2080
i hope u will get the solution.
Oct 29, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
Campbell Hausfeld FP209499 3 Gallon Air Compressor Logo
337 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
