Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE range model JGBS10BEH2BB to convert from LP to NG
Changed orfices for burners ®ulater burners work fine what do I do so the oven works
  • 6 Answers
SOURCE: oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Posted on Dec 20, 2008
Master_Tech
  • 770 Answers
SOURCE: JGBP28SEM1SS LP GE Range
have you tighen it down until it wont turn anymore this needs to be done on a LP gas model going from Natual gas
Posted on May 11, 2008
MNTECH
  • 1543 Answers
SOURCE: Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Posted on Jan 06, 2009
jumptrout51
  • 3361 Answers
SOURCE: oven burner makes a popping or whistling sound during baking cycl
STOP>>>>STOP{>>>STOP>>>
You have a gas leak in the oven.
Get this fixed immediately.
Posted on Feb 21, 2009
  • 89 Answers
SOURCE: GE gas range model JGBS10BEH2BB oven and broiler
you need to check the ignitor even if the ignitor glows it might not be pulling enough amps to call for gas replace the ignitor and this should take care of the problem
Posted on Aug 28, 2009
Convert dfg200 from gas to lp
being this is a commercial oven you will nee3d to go to a commercial parts purveyor to get the conversion parts,on residential units the orfices are included with the range when new for conversion at any time,the gas orfices need to be changed on the top burners,then the orfice spuds in the oven bake and broil units need to be turned down onto the orfice for conversion,your commercial parts person will have the steps with the conversion kit to do the change-over
Nov 24, 2012 | Blodgett DFG200 Stainless Steel Gas Double...
I like to conver my american range v. Broiler. Giro infrared burner to lp gas
that simple, all you can do it go to place where you can buy a LP orfice and LP regulator and remove all NG orfice and regulator out and install all LP orfice and regulator you ready to go for LP..
Jun 15, 2011 | American Range Ovens
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
Prpane back to ng. Changed top burner apertures. Is there anything else I should do for the gas supply
The range burner orfices need to be changed to the natural gas ones. I am assuming when you say "apertures" you are talking about the burner orfices. If so then you have already changed the range burner orfices. There is also a orfice that usually needs to be replaced for the oven burner and top broiler burner (if you have a top broiler). And then there is usally a pressure adjustment required on the appliance gas regulator. This is usually adjusted by simply removing the regulator cap and turning over the spring tension plug inside and then re-installing the plug and cap.
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Recently purchased Frig. gas stove.Want to convert from natural gas to Lp.Do you remove spud and insert Lp oriface in spud then screw spud back onto line?Lp oriface is a lot smaller than oriface for...
Not really sure which model you have but when converting the over, ether bake or broil burner you tighten down the orfice cap. If you remove the burner off the oven valve you will notice that you can put a wrench on the orfice cap. Just tighten snuggly. If you over tighten you will crush the orfice under the cap.
Dec 22, 2009 | Frigidaire Ovens
Convert back to natural gas
the burner orfices will have to be changed ans pressure reg / some have either /or reg / just turn lever to the fuel you are using . but always change the orfices to gas or lp . blk is lp copper nat gas .. you can probably do it with out the instructions it's very simple .. if the other set of orfice's are not in or on range then order them for your model . ..mm
Dec 12, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
May 11, 2008 | GE JGBP40 Gas Kitchen Range
Cannon Rhapsody LPG Gas open Fire sooting up of burners
well its my experience that ranges don't come lpg they are all made natural gas but you convert them to lpg after purchase now if the lpg conversion isn't done properly then they soot like crazy proper lpg converson is to change the spuds on the burners and to turn the orifice over in the pressure regulator do you still have your owners manuel if so consult it on converting gas range to lp then check to see if every thing was done right on the pressure regulater there is a square cap you take it off and there is a round part that on one side says lp on the other says ng this changes the pressure that the regulator as ng and lp operates at different pressures and the regulator has to be set for what you using like i said im not familiar with your brand or model but i do know the problem if the range did come ng then you need to make sure the conversion most ranges aren't lp because there is not that big a market for it read the plate on the back will tell you if it was made ng or lp serial plate on front may say also most of the time it is beside the bottom drawer on the range
Jan 18, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Swithed to LP
did you change the ovens burner orfice?if not theres your problem.
Dec 25, 2007 | Maytag MGR4451ADS Stainless Steel Gas...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
24 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
