Question about Skagen 202LSXM Wrist Watch
Where can i find extra band links for skagen 202lsxm watch
SOURCE: skagen mesh band shorten
just solved the mystery...U probably have too ..by now....but just in case..
here is a fun link to the solution by an actual user....was actually inspired by him...coz like I said I had mispaced the manual...
http://www.amazon.com/review/product/B0000C9ZBX/ref=dp_top_cm_cr_acr_txt?_encoding=UTF8&showViewpoints=1
I just used my nail file and lifted the locking mechanism and moved it forward...Now I can sleep better tonite....!
Mrs Martin
Posted on Dec 27, 2008
escapement
  • 2334 Answers
SOURCE: How to adjust Skagen watch band.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 10, 2009
escapement
  • 2334 Answers
SOURCE: Skagen watch 105LTX band adjustment
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Mar 24, 2009
escapement
  • 2334 Answers
SOURCE: Cannot find Skagen watch band for model 433LSLB
Follow this link and find what you are looking for:
http://www.skagen.com/service/home.fx
Rate me, please.
Posted on Jul 22, 2009
  • 103 Answers
SOURCE: Can't find replacement mesh watch bands for Skagen watch
try this website its directly to skagen! they can replace your band.
http://www.skagen.com/service/orderWatchBandParts.fx
Posted on Aug 04, 2010
Skagen 202LSXM. Why did it stop working?
The replacement battery could have been installed incorrectly.
Oct 12, 2015 | Watches
I NEED TO FIND A REPLACEMENT MESH BAND FOR A WOMENS SKAGEN WATCH.
A company that is a US distributor for Skagen (Denmark company) will sell you a replacement band. Mesh bands are $15 plus shipping.directions and address are here: http://www.skagen.com/service/orderWatchBandParts.fx
Feb 28, 2011 | Skagen Signature Mesh watch
Inability to remove link segment from skagen watch
I finally found instructions at: http://emea.skagen.com/service/watchBandSizingChart.fx and was able to remove the links.
Mar 07, 2010 | Watches
I need a replacemnt mesh band for the skagen 281LSS
go to skagen.com they have cheap replacement bands for your watch you can even send it in and they will send it back to you like new.
Aug 05, 2009 | Skagen Signature Mesh watch
Skagen ladies watch mesh band coming apart
As SKAGEN have their own traiding rules you will not be able to get watch band in shops or even at the dealer otlets.
All I can do is to give you a link to send to Skagen a required part doc:
When the page is open click on PARTS REPLACEMENT FORM and give all the details asked.
Rate, please.
Jul 22, 2009 | Skagen 355LGSC Wrist Watch
Rate me, please.
Jul 22, 2009 | Skagen Signature Mesh watch
Jun 13, 2009 | Skagen Signature Mesh watch
Size watch bracelet
your band is Skagen Signature Mesh
http://www.skagen.com/service/watchInstructions.fx#adjustment
Dec 26, 2008 | Skagen Watch
Skagen 202LSXM Wrist Watch Logo
69 people viewed this question
Top Skagen Watches Experts
Jerry Greenberg
Jerry Greenberg
Gary Nitowski
Are you a Skagen Watch Expert? Answer questions, earn points and help others
