Question about Pioneer VSX-D2011 Receiver
Pioneer VSX-D2011 loses memories
Memorie
3 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: Station Memory Loss Pioneer VSX-108
If you turn it off MANUALLY the power is physically cut from the mainboard where the memory is stored and it is lost. If you use the remote it puts the unit into a standby mode which retains the memory.
Posted on Sep 13, 2007
Gurudristi
  • 98 Answers
SOURCE: My pioneer VSX D2011 cuts to standby when playing music
Your receiver is basically going into protect mode.
Are you pumping up the volume when you connect the TV?
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate. Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck and have a great party!! Thanks for using FixYa!
Posted on Mar 12, 2009
Losing configuration
I am not sure there is nothing that I can fined on the user manual but if you talk to your nearres electronics shop and see if there is any thing they can do
Jan 28, 2014 | Pioneer VSX-D514 Receiver
Tip
Loose memory
My receiver lose the memory after of power cord stay disconnected about seven days. Any body now where is the backup battery?
on Sep 01, 2008 | Pioneer VSX-D810S Receiver
Pioneer VSX 454 loses station battery needs replacement where is it located???
Memory is not held by a battery. It is usually held by a capacitor that provides the micro with voltage. Not that easy to change.
Jan 04, 2013 | Pioneer VSX-454 Receiver
Stereo without sub woofer how this setting
i have -VSX-D2011 when i want to stereo mode the sub woofer is automatic
play in stereo mode and disturb
i check all setting and much time waste on manual instruction
Stereo mode play only two front speakers if any one have knowledge about setting please help with advance thanks
Jun 26, 2012 | Pioneer VSX-D2011 Receiver
How to change chanels from 7.1 to 5.1?
Install and configure the last 2 speakers IAW the manual.
May 15, 2011 | Pioneer VSX-D2011 Receiver
I have the Multi Channel VSX-D2011 which is fine when used at low volume. As soon as the volume rises to a fairly normal level the amp cuts out and switches off. Any ideas?
Hiya,
First try checking all the speaker cables and speakers. Listen to them all make sure they are all playing when playing softly, if not there could be a short in the speaker cable/speaker causing it to protect. Another way, disconnect them all and connect one at a time, test it etc, when the fault re-occurs, in that line.
If thats not it then sorry will have to go to a tech as it sounds like protection is kicking in or PSU fault
Jul 07, 2009 | Pioneer Audio Players & Recorders
Pioneer VSX-516-S/K amplifier - loss of sound in speakers
This sounds like the amp has a system memory problem. The chips inside your amp that deal with it might be faulty or they loose the information due to a power loss, often caused by memory retention capacitors.
You can tell that to the repair man and see what he says, but personal I would go to another, try contacting Pioneer for a recommended engineer in your area.
Apr 09, 2009 | Pioneer VSX-516-K/S Amplifier
Mar 11, 2009 | Pioneer VSX-D2011 Receiver
Popping noise and loss of sound
Check the preamp Coupling Capacitor, which might have lost its value, or might have leaky dielectric.
Feb 24, 2008 | Pioneer VSX-D409
The problem is IC 701. I looked it up as far as pricing and it costs around 78 dollars. I am not planning on replacing it as it is not worth it.
Sep 11, 2007 | Pioneer VSX-108
Pioneer VSX-D2011 Receiver Logo
96 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
