Question about Welding Tools
Where is the oil pressure switch on a miller bobcat 225 g plus
I suspect the oil pressure switch is bad , where is it located ?
  • 100 Answers
SOURCE: i own a miller bobcat 225 nt where can i buy a
miller for less.com
Posted on Feb 15, 2010
  • 81 Answers
SOURCE: battery location.......dahhhhhhhhhh
Hi Louis, the battery sits on the bottom of the unit, just inside the rear right side service door.
if you were to look at the machine from the back, it would be located right in the middle on the bottom of the unit.
Posted on Jul 02, 2010
  • 23 Answers
SOURCE: I have a miller bobcat
clean your contacts your gap should be .008 its like points in a car
Posted on Dec 17, 2010
luis_david
  • 407 Answers
SOURCE: Can i power this unit with my old Miller Bobcat
If your Hobart Mig is less than 250 amps then yes you can, bobcat 225 will give you10000 watts and you require at least 8000 watts for the hobart.
Posted on Jan 09, 2011
  • 18 Answers
SOURCE: Bobcat Miller 225 won't start.
Check the oil safety switch maybe it is bad. It will stop running if low on Oil or wont start.
Posted on Feb 19, 2011
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and forth to high then to low idle?
The unit may need recalibrating the idle/run setting. Instructions found in manual at 8-6 (subaru engine) and 9-5 (kohler). Idle speed around 2200rpm. Simple screw adjustment. PDF manual here :- http://www.millerwelds.com/om/o4434l_mil.pdf
Aug 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
Location of oil switch onan motor miller welder
Hi Martin,
I do have this site that has manual for you in order for you to locate it and its function as well. Hope it helps.
https://www.millerwelds.com/pdf/spec_sheets/ED4-4.pdf
Apr 26, 2014 | Bobcat Miller 225 Welder Generator 907209...
Would like to know how much a used bobcat migwieldier costs?
Depending in the city you are in. Here in N California the average price for the Miller Bobcat 225 is 3,425.00. Try your local Praxair Distribution welding store.
If this was useful please vote.
Feb 23, 2011 | Bobcat Miller 225 Welder Generator 907209...
Battery location.......dahhhhhhhhhh
Jun 24, 2010 | Bobcat Miller 225 Welder Generator 907209...
Miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
May 06, 2009 | Miller Welding Tools
Welding Tools Logo
296 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
